Rumble Strip Noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by mechengr322, Jul 9, 2022.
  1. Jul 9, 2022 at 6:11 PM
    mechengr322
    mechengr322 [OP] Member
    2002 4WD Tacoma
    Hello, my 2002 4WD manual transmission Tacoma started to make a noise like it is going over a rumble strip. The noise will come and go as I drive. My tires are balanced and the alignment is good. I feel no vibration at the wheel. Any ideas what is causing it?
  2. Jul 9, 2022 at 6:26 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Possibly the rear wheel bearings.
  3. Jul 10, 2022 at 10:43 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I have had the surface on the road cause this issue sounds like something is going to fall out.
    What do you mean Come and Go ?? What seems to effect your noise ?
    Road speed , Rpm the gear your in?
    Does it make the noise in gear and out of gear ? Clutch depressed or released ??
  4. Jul 10, 2022 at 6:52 PM
    mechengr322
    2002 4WD Tacoma
    The noise will happen on any road and starts around 40 mph. Sometimes the noise just stops but momentarily and starts again.
  5. Jul 10, 2022 at 6:53 PM
    mechengr322
    2002 4WD Tacoma
    How do I check the rear bearings?
  6. Jul 10, 2022 at 6:59 PM
    Bivouac
    Harmonic Vibration caused by the rpm or road speed or air movement under the truck.
    To Check for rear wheel bearings. jack the truck up support with jack stands.
    Look for leaks at the rear wheel seals I back off the brakes slowly spin the wheel feeling for any rough spots on both sides.
  7. Jul 17, 2022 at 1:18 AM
    mechengr322
    2002 4WD Tacoma
    Thanks for your help. It was a wheel bearing. Unfortunately, it was the front right which was replaced two years ago.
    Deathbysnusnu likes this.
  8. Jul 17, 2022 at 3:36 AM
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    Check your heat shields on the catalytic converter and around the exhaust. I had a bolt rust away on the converter that held the shield in place that would vibrate like hell when accelerating. Normal idle it quieted down. My nephew who is a mechanic grabbed my exhaust and shook it hard and the rattle was noticed. I missed it when I did a visual inspection. Everything seemed to be in place, but it wasn't. I was worried my torque converter was going bad. It was an easy fix.
