Rugged Terrain tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sgmstr, Mar 14, 2020.
  1. Mar 14, 2020 at 11:07 AM
    sgmstr
    sgmstr [OP] Well-Known Member
    Considering RTs over ATs or MTs. (more aggressive look over ATs with less weight that MTs and wears better than MTs)
    I understand losing some MPG over AT tires. How does RTs impact acceleration (heavier than ATs)? Is it much noticeable over ATs? Seen some review on second gens that they can be sluggish. What about the turd gens?
    Any tire recommendation for 265/75/16 with stock suspension and pros/cons for each? Currently looking at Toyo Open Country RT.
  2. Mar 14, 2020 at 11:10 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    whats an RT tire?
    twitchhero likes this.
  3. Mar 14, 2020 at 11:11 AM
    Infidel1920
    Infidel1920 Well-Known Member
    Patrick
    Wurtsboro NY
    2016 Tacoma TRD Sport
    Door sill plate vinyls (Blazing Blue) Glovebox vinyl inserts (Blazing Blue) Super bright LED interior lights AC vent blazing Blue surrounds CNC Machined Grill (Blazing Blue letters) Tailgate Vinyls (Blazing Blue) Engine shroud Vinyls (Blazing Blue)
    Never heard of RT
  4. Mar 14, 2020 at 11:12 AM
    sgmstr
  5. Mar 14, 2020 at 11:13 AM
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    Ah yes, the classic marketing wank category creep.
  6. Mar 14, 2020 at 11:15 AM
    sgmstr
    So not worth considering? they weigh less than MTs and appears to have better grip than ATs.
  7. Mar 14, 2020 at 11:16 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Nitto ridge grappler may be perfect for you
  8. Mar 14, 2020 at 11:18 AM
    BillsSR5
    bill
    2014 SR5
    what predominately kind of driving are you doing?[​IMG]
    Malvolio likes this.
  9. Mar 14, 2020 at 11:28 AM
    sgmstr
    Use as DD. All stock. Weekend camping mostly off pavement with use of rear locker time to time. Some mud and creek crossing.
    Want better grip than ATs. willing to sacrifice mpg but not so much on acceleration as it is already slow.
  10. Mar 14, 2020 at 11:29 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Cooper ST Maxx will do everything you want.
  11. Mar 14, 2020 at 11:30 AM
    sgmstr
    Thanks. At 61lbs i would go with MTs.
  12. Mar 14, 2020 at 11:31 AM
    sgmstr
    Yes. That is an option
  13. Mar 14, 2020 at 12:22 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Sounds like you need ATs....
    Lt. Dangle, That one old guy and Wixo like this.
  14. Mar 14, 2020 at 1:11 PM
    sgmstr
    How do you determine that? just curious. :thumbsup:
  15. Mar 14, 2020 at 1:17 PM
    TrailYeti
    TrailYeti Well-Known Member
    Portland, Oregon
    05 TRD OR on SCS F5’s & 315/75r16’s
    Check out Cooper Discoverer AT3 XLT’s. I ran them and was impressed. About as aggressive as an AT will get.
  16. Mar 14, 2020 at 1:17 PM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Cooper Stt pro are better than the st maxx. Great for everything and meaty. Or the wildpeak at3 are a good tire. Get in E load though. The SL is poop
    Wixo likes this.
  17. Mar 14, 2020 at 1:18 PM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    RT = all terrain tire with a more aggressive side wall. End of story......
    I just took off a set of Nitto Ridge Grapplers in 265 size. They were good tires. I went back to the KO2 when I upgraded to 285s. I like the KO2 better
    Jukeboxx13 likes this.
  18. Mar 14, 2020 at 1:22 PM
    sgmstr
    I would consider it. Unfortunately, not available in the size I'm looking for.
    TrailYeti[QUOTED] likes this.
  19. Mar 14, 2020 at 1:23 PM
    sgmstr
    I think they have deeper tread and heavier, most of the time.
  20. Mar 14, 2020 at 1:25 PM
    TacoTime850
    2019 DCSB 4x4
    KO2 is a lighter tire than the RG. Both are available in C and D load. I think the RG tread is like 1/16th deeper, depending on the size and load rating. You can’t tell the difference side by side.
    Actually I just remembered that the RG is also available as a P rated. Those are like 10 lbs lighter than even the KO2
    Wixo likes this.
