Rubber Wiper Blade Insert Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chandler1215, Mar 2, 2020.
  1. Mar 2, 2020 at 12:57 PM
    chandler1215
    chandler1215 [OP] Well-Known Member
    2016 Black Tacoma TRD Off Road DC
    I’ve searched online looking for an answer can’t find it. Is there an OEM wiper blade insert, just the rubber piece itself, to replace the wiper? Not the entire housing just the blade.
  2. Mar 2, 2020 at 1:12 PM
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    I don't know about OEM, but you can buy aftermarket "refills". I like silicone, so I bought PIAA silicone refills. The issue is that the original rubber inserts are wider than usual for the length. To get around this (at least for the PIAAs I bought) you need to buy longer refills and then trim them to length yourself. Effort-wise, this is a non-issue, and you can use whatever brand/style you like.
  3. Mar 2, 2020 at 1:17 PM
    muffyinva
    muffyinva Well-Known Member
    Reid
    Lynchburg, VA
    2019 Cement Tacoma DCSB OR
    Pretty sure my local dealer has them. You might check yours.
    AZ Pete, eurowner and na8rboy like this.
  4. Mar 2, 2020 at 1:34 PM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
  5. Mar 2, 2020 at 2:21 PM
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    Deano12 and chandler1215[OP] like this.
  6. Mar 2, 2020 at 5:11 PM
    CanesFan95
    CanesFan95 Well-Known Member
    Florida
    Currently Shopping...
    Never understood this. I get new wipers at Wal-Mart and they're the full metal and rubber blade. But you're saying there's a way to get just the rubber part only and replace it?
    PvilleJohn likes this.
  7. Mar 2, 2020 at 5:15 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Yes the OEM blades do the best job and last the longest. When there worn just go to your dealer and buy the refills, it's just the rubber strip. There about 15 bucks each but well worth it.
    eurowner and Tacoman97 like this.
  8. Mar 2, 2020 at 5:45 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    I think I sold 12 sets of refills in 20 years and all of them were returned. OEM would be the answer, but for 5 bucks more, you get the whole deal....
    Zim
  9. Mar 2, 2020 at 5:50 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    This ^^
    I tried to buy the best silicone beam blade at Walmart, and they just don't compare to OEM. Returned them and order a set of oem refills from Ebay.
  10. Mar 2, 2020 at 6:08 PM
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    I still have the original blades on my 2017. OEMs are awesome.
    TacoSportTRD and Lucifer1 like this.
  11. Mar 2, 2020 at 6:25 PM
    TacoSportTRD
    TacoSportTRD Well-Known Member
    Michigan
    2017 TRD Sport AC 4x4 V6 Barcelona Red
    I also have the original on my 2017. I've never seen any wipers last this long.
    Steve Urquell[QUOTED] likes this.
  12. Mar 2, 2020 at 6:42 PM
    Steve Urquell
    I picked up a couple pair of new Goodyear Assurance blades dirt cheap a couple years ago at a flea market. Still hanging on my garage wall and no plans yet to change my OEM.
    TacoSportTRD[QUOTED] likes this.
  13. Mar 2, 2020 at 6:50 PM
    TacoSportTRD
    Michigan
    Me too, well I bought 3 set's of AC Delco blades with frames for free after rebate and they are still sitting in the shipping box.
  14. Mar 2, 2020 at 7:03 PM
    Dc2tacoma
    Dc2tacoma Well-Known Member
    I’m in sunny California where it never rains and the rubber part is cracked and leaves streaks. 2017 also.
  15. Mar 2, 2020 at 7:29 PM
    Steve Urquell
    Lot of things in Cali cause cancer. Rubber prolly got it.
  16. Mar 2, 2020 at 9:07 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    Replaced stock wipers with Trico Force blades. A little pricey but do great in all weather. I usually replace wipers once each year. I kept the OEMs so maybe I’ll get a set of new inserts next time.
    CusterFan likes this.
  17. Mar 3, 2020 at 2:47 AM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    My 2017 still has the OEM rubber also.
    No signs of cracks or significant wear.
    Also it helps that my windshield is ceramic coated and I use the wiper spray at least once per day.
    cammerv8 likes this.
  18. Mar 3, 2020 at 4:04 AM
    chandler1215
    My 2016 blades are finally starting to come apart. I’m not mad though they’ve lasted 5 years almost. My 2009 accord also had the blade refills and they lasted me about 7 years before needing replaced
  19. Mar 3, 2020 at 5:45 AM
    chandler1215
  20. Mar 3, 2020 at 6:06 AM
    Papadave418
    Papadave418 Well-Known Member
    I agree with the thought that OEM are a higher quality blade. I decided to replace mine as I have 75k on my truck and they are perfect. When it comes to safety and being able to see in bad weather, I’d rather save money some other way. Yeah Walmart might make a cheaper replacement blade, but is saving a couple bucks on windshield wipers really where you want to save money? For me seeing the road is pretty darn important, and personally my experience is that the OEM’s are the best
    AthensTac likes this.
