Rubber Bumpers for gas door and under center console.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cair1205, Jun 3, 2018.
  1. Jun 3, 2018 at 10:29 PM
    Cair1205
    Cair1205 [OP] Member
    99 PreRunner
    Anyone know where I can get the actual rubber numbers that go where the door closes for gas?
    Also, I just purchased my 04 double cab and I'm curious to know if there's supposed to be some bumpers of some sort under the center arm rest that lifts up. Know where I could get those too?
  2. Jun 3, 2018 at 10:45 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I replaced mine from ones I picked up at ACE hardware.
    Mr_Taco_Taco and Cair1205[OP] like this.
  3. Jun 3, 2018 at 10:46 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  4. Jun 3, 2018 at 11:03 PM
    Cair1205
    99 PreRunner
    Thanks, hopefully will last me a long time it's only got 89,000 miles on it.
    Double Deuce and Sidney Vicious like this.
  5. Jun 4, 2018 at 12:02 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    NICE! That's low mileage. What did you pay for it?
  6. Jun 4, 2018 at 12:07 AM
    Cair1205
    99 PreRunner
    $11K told the guy I'd be right back went to the bank and came right back and picked it up
  7. Jun 4, 2018 at 7:35 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    For the gas cap door
    For the center console
  8. Jun 4, 2018 at 12:51 PM
    joeficsit
    joeficsit Well-Known Member
    Texas 'Yall
    PreRunner with transfer case in
    Dude, that's awesome!
    What site did you use to find the part numbers?
    I can find most parts on most of the available site online, but some of the smaller items I have trouble with.
    Looking for the shift boots (both the 4x4 and the auto) that attach to the underside of the shifter assembly for an automatic transmission truck.
  9. Jun 4, 2018 at 7:19 PM
    jammer
    Ben
    Bentonville, AR
    Hey, glad to help. I’ve ordered numerous small, hard to locate parts from the site below.
    I’ll send you another link tomorrow from my laptop that I use to acquire part numbers.
    I know the bushings you are referring to because I replaced them in my auto.
    I’ll include the parts # as well tomorrow.
    https://www.toyotapartsdeal.com/
  10. Jun 5, 2018 at 5:15 AM
    Cair1205
    99 PreRunner
    Thanks for the help man!
  11. Jun 5, 2018 at 6:40 AM
    jammer
    Ben
    Bentonville, AR
    Here is a link to the site that I use to gather part numbers from. Works best in you key in your VIN number. I then go to the site I gave you above and do a search with that number.
    Be careful man....it's a slippery slope when you see all the things you "could" replace.
    http://japan-parts.eu/toyota/us/200.../powertrain-chassis/3312_shift-lever-retainer
    I read your comment again about the "shift boots" and this may or may not be what you're referring to. The automatic shift bushings (plastic) are what I replaced to tighten up the play in the shift lever.
    I did replace this rubber boot while I had it apart.
    Part #90385-11003 refers to the diagram below (shift linkage bushings)
  12. Jun 5, 2018 at 8:35 PM
    joeficsit
    Texas 'Yall
    Thank you so much for the help!
    I'll try not to go too crazy.
  13. Jun 5, 2018 at 8:53 PM
    joeficsit
    Texas 'Yall
    All this because:
    Transfer case is in, (manual J shift) need to seal the floor better than what I've currently got.
  14. Jun 30, 2018 at 1:40 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    Worth bumping I ordered part number 9008454010 for the console bumpers. I always thought something was missing, but couldn't find anything in a parts diagram. The console now sits level.
  15. Dec 17, 2022 at 10:29 AM
    dcoffing
    dcoffing New Member
    2001 TOYOTA TACOMA 3.4L A/T 4WD DOUBLE CAB DLX
    I just got a 2001 Tacoma 4x4 dual cab and I was looking to find these exact bumper cushions below the console! I got them ordered in and now for the life of me I can’t seem to figure out a way to install these little guys. Simply pressing from the top of the cushion just deforms it and it won’t seat and lock in the hole. After feeding the small rubber thread through the hole I can’t grip it well to pull it and lock it in to the hole that is such a tough position . I found some small pliers that if I work hard enough I can grip it but when pulling I am afraid it is putting too much pressure on the rubber and it will break off?
    UPDATE: I finally got them in. I used some 90 deg needle nose pliers and put just a drop of silicone oil on the rubber bumpers. And I pulled until they just popped in place.
    Mr_Taco_Taco likes this.
  16. Dec 30, 2022 at 9:58 PM
    Mr_Taco_Taco
    Mr_Taco_Taco Member
    I was going to say I made a soapy water solution of dawn dish soap and water to get mine in.
    Didn’t it feel great getting that first sucker to go in the hole?!
