Rubber brake hoses....OEM or Aftermarket??
Discussion in '1st Gen. Tacomas (1995-2004)' started by yarb71, Sep 15, 2020.
  1. Sep 15, 2020 at 6:38 PM
    yarb71
    yarb71 [OP] Well-Known Member
    Im a stupid ass and ripped the outer rubber casing in the drivers side brake hose from the caliper up to where it hits the hard line.
    Do i go with OEM lines at $70 each or some aftermarket duralasts at the local autozone for 24 bucks each?
    Shop says i should do both at the same time to due to fatigue and even braking.
    Bring my own hoses and they will do them 65 bucks per side. Not horrible....and i hate doing brake line shit. I aways mess up the fitting or the bleeder or end up hating myself. Cold weather state so everything is corroded to hell and back.
    Surely the aftermarket ones meet spec so why not?
    Taco critter likes this.
  2. Sep 15, 2020 at 6:58 PM
    02hilux
    Planet: EARTH
    65 for labor per side with you providing the parts, that's crazy! DIY
  3. Sep 15, 2020 at 7:01 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I would buy the OEM and do them myself . YouTube a video if you need to see how to .
  4. Sep 16, 2020 at 1:48 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Wow I need to charge more $130.00 to change 2 brake hoses and bleed the brakes .
    Then added expense for broken rusted fittings .
    Till this is done it could get very expensive .
    If you can`t do the work you pay the price.
    I hope every thing works out.
  5. Sep 16, 2020 at 5:10 AM
    yarb71
    yeah i might give it a shot. THe lines alone are going to be over $130 bucks which is nuts. 2 1 foot hydraulic hoses....
    My biggest fear is getting the bleeders loose or the lines at the hard line. Both are fucked from 16+ years of heat, -30 degree temps and road salt. THat hardline is in the stupidest place ever where you cant get to it as well. I suppose i should give it a shot. I have the line wrenches and ability.....i am just so tired of fucking with this thing.....and waiting on parts.
    ANyone have a parts manual handy? I cant seem to find the banjo bolt part number for each side. They are not listed at mcgeorge on the diagrams. Mine are likely garbage. So rusted they dont even look like a bolt head any longer.
  6. Sep 16, 2020 at 6:32 AM
    02hilux
    Planet: EARTH
    For about, or less then $130, you can buy Crown lines from Marlin and get all 3 (2 front and 1 rear) stainless steel. Better made hose then factory rubber imo.
    If you need new banjo bolt, there shouldn't be an issue with napa brand or what your local auto parts have. If the hard line end gets damaged, you can cut the hard line as close as possible to the end (buy a spare hard line from napa with matching thread/size) and use the end than re-flare the hard line.
    I recommend soaking both ends with atf or some sort of penetrating oil every couple of hour for at least a day or so, if it's really bad. Then try to break them loose that way. Need help? YouTube will be your friend. Changing brake lines and bleeding them is pretty much the same for all vehicle, there's nothing special about these tacoma.
    Good luck.
  7. Sep 16, 2020 at 6:39 AM
    yarb71
    yeah...ive done them on several cars over the years here. Shit show....but its doable. Lots of soaking and heat and time. I will check into those lines. Looks to be about 97+ shipping for that kit for stock length and the .50 clips and washers. Thats not bad.
    Still need the banjo bolts for the front calipers...and the stock part numbers for those. I might call my local dealer for those and have them add it to the pile of crap i need to go pick up from them.
  8. Sep 16, 2020 at 6:44 AM
    02hilux
    Planet: EARTH
    They have them for stock application as well, but buy what you preferred. Just another option.
  9. Sep 16, 2020 at 6:53 AM
    yarb71
    THanks for the option. They do look nice. Comes out cheaper than the OEM ones with the discount at mcgeorge and has the hardware (clips and junk) included. I might go this route.
  10. Sep 16, 2020 at 8:00 AM
    yarb71
    local dealership wants $8 a piece for the banjo bolt.........geez....
    looks like
    ~145 bucks with shipping for 2 OEM lines out of mcgeorge
    or
    ~120 with shipping or so from Marlin....for the crown stuff.
  11. Sep 16, 2020 at 9:28 AM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    I would check out Rock auto. They have the best prices.
  12. Sep 16, 2020 at 9:33 AM
    yarb71
    yup...which is why i asked about aftermarket vs oem parts. I could be done for around $50 from Rockauto.....but also i dont want crap. Maybe that wasnt clear per my original post.
  13. Sep 16, 2020 at 9:53 AM
    petecarlson
    petecarlson Well-Known Member
    2002 4X4 DC TRD
    A bunch of the ones from rock auto are random universal ones with extra brackets on them.
  14. Sep 16, 2020 at 9:54 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    When in doubt with breaking those hardlines free, use some heat.
  15. Sep 16, 2020 at 9:59 AM
    yarb71
    yup...that usually works. I have found that will get your fitting to spin free from the hardline but almost always the hardline will twist at the fitting due to corrosion and then you have a broke hardline to recreate and fight with.
  16. Sep 16, 2020 at 10:26 AM
    yarb71
    hey if i do order the ones from Marlin ill probably get some of those neat Marlin Crawler turtle decals :)
  17. Sep 16, 2020 at 10:42 AM
    02hilux
    Planet: EARTH
    That's probably standard business practice, free advertisement.
