RPM raises when brake pressed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mile0tacoma, May 4, 2018.
  1. May 4, 2018 at 7:34 PM
    Mile0tacoma
    Mile0tacoma [OP] Well-Known Member
    Hank
    Mile zero Alaska Highway
    2019 & 2018 Tacoma
    Mine has level kit, 34" tires, wife's truck is all stock
    Noticed this morning after I started truck that when I stepped on the brake the engine rpm raised about 200. Took foot off and it drops to normal. Stepped back on brake and engine rpm goes up, after driving a bit it does not repeat this. Only after I first start it up it does this. Anyone experience this?
  2. May 4, 2018 at 7:42 PM
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    When I first start the truck and I do anything that has a draw the RPMs rise. Break, turn steering wheel, turn fan on. I think that's fairly standard. Our car does that same thing when we first turn her over but not once the engine's been turning the alternator for a bit: does it with steering wheel, fan, lights, but not with breaks.
    2016Tacoman likes this.
  3. May 4, 2018 at 7:57 PM
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Mine does it too. I'm not concerned.
  4. May 4, 2018 at 8:07 PM
    EastVanTaco
    EastVanTaco Well-Known Member
    2017 super white Trd Sport DCLB
    mine does this all the time... basically revs up slightly when im in reverse and trying to park ina tight spot up against a wall. I realized its only when i turn the wheel. even the slightest touch of the wheel.
  5. May 4, 2018 at 10:13 PM
    Scotty Dosent Know
    Scotty Dosent Know Well-Known Member
    2017 Tacoma DCSB
    A lot of cars do this. My civic will do it when you turn the steering wheel.
  6. May 4, 2018 at 10:23 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    Cold starts will have different settings than warm starts or warm engine.
  7. May 4, 2018 at 11:25 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I dreamed of having an automatic engine rever when pushing the clutch while braking to a stop in order to help keep my engine from stalling on my “68 carborated BMW. So I developed the three pedal push- one foot on the clutch, and the other one on both brake and gas pedal by keeping the heel on the brake while my toes pushed the accelerator. Concider yourself lucky to have such a finely engineered vehicle that it does all that for you! :)
    Actually, I wonder if you are mistaking this for brake assist? - could your tranny (auto?) be simply brake assisting by automatically downshifting while you are stopping or slowing down?
  8. May 5, 2018 at 12:53 AM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    That's the idle control valve compensating for the extra load.
    danny15l likes this.
  9. May 5, 2018 at 5:53 AM
    Kingair84
    Kingair84 Well-Known Member
    Wisconsin
    2016 Double Cab TRD Off Road 6 speed MT
    Rad Industries skid plate, trd pro grill, rigid DOT Fogs
    Mine does that too. I think it has something to do with being an off road model and having the electronic brake booster. I’d assume it requires more power to run the pump so the engine rpm goes up.
    OnHartung'sRoad likes this.
  10. Aug 2, 2018 at 5:11 PM
    Joisey
    Joisey Well-Known Member
    When you depress the brake pedal you artifically increase engine vacuum, which causes the idle to temporarily rise. Cold engine vacuum is lower than hot engine vacuum because the pistons and cylinders have not warmed up to size.
  11. Aug 2, 2018 at 5:11 PM
    Tehkoema
    Tehkoema Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    normal.
