RPM drops while driving?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757yotas, Sep 29, 2016.
  1. Sep 29, 2016 at 9:51 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    RPM drop while driving
    I recently did some work on my truck, new fuel filter, oil, oil filter, valve cover gaskets, spark plug tube gaskets, intake mainfold gaskets, MAF sensor cleaned, throttle body cleaned, and cleaned some dust and dirt off the air filter. About a week ago it started to drop rpm while I drive once i get to speed and the rpms come to the normal 1500-1600. They drop down to 1000-1100 and i can feel it aswell as watch the rpm gauge drop. I am getting no DTC codes or check engine light. I am stuck and have no idea what to check next. Maybe PCV valve? Thanks for any help
  2. Sep 30, 2016 at 12:02 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No CEL or lost power just the RPM dropping to 1000 - 1100 when cruising? Does it run and drive normally?
  3. Sep 30, 2016 at 8:54 AM
    757yotas
    Virginia
    2007 TRD Sport
    It idles fine and runs fine over 2000 rpm. It only starts to drop rpm to 1000 and jump back up to 1500 once i am up to speed (45 mph) and cruise at that speed. It seems to do it more when the car is cold and does it less once it is warm
  4. Sep 30, 2016 at 2:37 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    I'd first suspect the throttle position sensor on the accelerator pedal. Sort of like the wiper on a fuel level sending unit in a car can have bad spots where the wires wear through if the tank is always kept at the same level of fuel. Nothing else comes to mind when you have no check engine light and no stored trouble codes and the engine runs fine at other rpm levels...
    JSU likes this.
  5. Sep 30, 2016 at 3:40 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I was wondering if what you are seeing is the transmission hunting between lockup and not locked. Which will show up as the RPMs change.
    Clearwater Bill likes this.
  6. Sep 30, 2016 at 3:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    Like @Jimmyh suggests, this was a very common issue back when lockup converters came into play in the '80's. Made some city driving pretty annoying.
    Experiment. Try driving just a bit slower, and just a bit faster, and see if the effect stops.
  7. Sep 30, 2016 at 5:26 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    Being that you are experiencing the problem at around 45 mph, I agree with Jimmyh, as that's the speed that the torque converter locks.
  8. Sep 30, 2016 at 9:26 PM
    RobertHyatt
    Robert
    Birmingham AL
    Only fly in the ointment is that MY 4.0 does not drop 500 rpm when the torque converter locks up. That indicates a TON of slip which seems unreasonable. One missing piece of data is "does the speed drop when the RPM drops?" I had assumed "yes" but if that is wrong, then the TC (or a transmission that is improperly shifting up and down) might be more likely.
  9. Oct 1, 2016 at 6:45 AM
    Pigpen
    Northwest Montana
    2nd gen?
  10. Oct 1, 2016 at 9:53 PM
    757yotas
    Virginia
    2007 TRD Sport
    Found out it was my intake manifold gaskets! Changed them today and the issue was gone. Ill be changing the pcv valve this coming week just for a piece of mind its changed out. Thanks for all the help!!
  11. Oct 1, 2016 at 10:23 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    In your OP you said you had changed them already...
    Unaccounted air getting in after the MAF causing a lean fuel mixture.
    Good you found it.
  12. Oct 1, 2016 at 10:29 PM
    757yotas
    Virginia
    2007 TRD Sport
    I did change them but not with new ones just ones in "better" shape. I overnighted some felpro ones from Amazon and the issue seems to have cleared up. Huge head ache gone now!
  13. Oct 1, 2016 at 10:47 PM
    Jimmyh
    SC
    2012 Prerunner SR5
