Rough shift between 1-2: '22 Tacoma TRD-OR 6MT
Discussion in 'General Tacoma Talk' started by southwestorv, Apr 29, 2024.
  1. Apr 29, 2024 at 8:09 AM
    southwestorv
    southwestorv [OP] Well-Known Member
    2022 TACOMA TRD OFF ROAD 6-SPD
    Good morning friends.
    I'm trying to decide if this is a problem or not. I have a 2022 Tacoma TRD Off-Road 3.5 V6 6-speed manual transmission. I am the original owner, and it now has 47,000 miles on it.
    My concern: shifting between gears 1 and 2 seems rough to me. It always has, but I figured it would iron out with miles and break-in. By rough, I mean that there seems to be a momentary gear grind of sorts before it slips into 2nd, when going from 1st to 2nd. 2nd to 3rd and on up feel normal to me, like they should. I have tried everything, revving higher before shifting, revving lower before shifting, pressing the clutch harder, depressing it less, being more forceful with the shifter, being softer with the shifter, and nothing seems to change it. My concern is that there could be a problem with synchros, or something else, and I would need to get it resolved under warranty (5 years, 60k miles).
    BUT, I thought I'd check here first and see if anybody else has the same behavior from their truck. If it's normal, I can live with it. If it's not, I need to get it checked out.
    When I shift, I do so lightly, with three fingers most of the time, and as it slips into 2nd you can see the shifter bounce/vibrate for a split second between going in, accompanied by a mechanical noise...like a soft grind.
    NOTE: I'm not new to this manual transmission thing. I was raised on a farm, and drove stick shift from the time was 8 years old until today. Manual trans vehicles I've operated/owned: Nissan 720 pickup, 1980 GMC 3500, 1993 Ford Escort (best shifting of them all), 1986 Chevy S10, 1989 GMC Sierra 1500, 1995 GMC Sierra 1500, 2001 Ford F250 Super Duty, 2006 Ford F550 roll deck tow truck.
  2. Apr 29, 2024 at 8:22 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx engine software enchantment, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Change the transmission fluid and go from there. I've found even with new manuals that are broken in, changing the fluid and removing the break in debris will clean up any notchy shifting.
    lots of options and I don't wanna start a oil brand debate so all i'll say about fluid choice is make sure it only says GL4. Not GL5 or GL4/GL5.
    Jakerou and southwestorv[OP] like this.
  3. Apr 29, 2024 at 8:28 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Have you tried double-clutching? (Put it in neutral and release the clutch between gear shifts, so start in 1st, depress clutch, move to neutral, release clutch, depress clutch, shift to 2nd, release). If that smooths it out, that might indicate an issue with the synchros, but I'd start with fresh fluid and make sure you clutch is adjusted properly and is fully releasing when fully pressed.
  4. Apr 29, 2024 at 9:53 AM
    southwestorv
    Ok. I’ll start there. That’s an easy experiment. Because it’s under warranty I’ve had it serviced 100% by the local Toyota dealer. I’ll have them do the transmission service and check adjustment and see how it feels afterward.
  5. Apr 29, 2024 at 11:44 AM
    joba27n
    Nolan
    Alberta
    When I first got my truck it would intermittently lock me out of a 4th gear downshift and the dealer was of no help to me other than saying it take 40k to break in... possible but a long time to not be able to downshift. I changed my own fluid at 10K and it was significantly better so i'm fairly confident it will sort you out too.
  6. Apr 29, 2024 at 11:51 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    Sometimes I'll get a rough 1-2 shift as well, sometimes I don't. Normally if I shift slower it's smoother but it not super easy to recreate
    southwestorv[OP] likes this.
  7. Apr 29, 2024 at 5:48 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    Not uncommon. Mine does it too. Shifting at around 3K RPM or over 4K RPM seems to work. A slight pause between depressing the clutch and doing the shift also works. It's tricky to do every time without just a little grind. And like you it's only the shift from 1st to 2nd.
  8. Apr 29, 2024 at 7:49 PM
    southwestorv
    Ok, it’s sounding more and more like it’s characteristic. But I may as well service the trans and get that out of the way.
  9. Apr 29, 2024 at 7:50 PM
    southwestorv
    What fluid did you use going back in?
  10. Apr 30, 2024 at 6:30 AM
    joba27n
    Nolan
    Alberta
    southwestorv[OP] and Shellshock like this.
  11. May 2, 2024 at 7:12 PM
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
    My truck's 1-2 shift can be rough, usually when I shift it at a lower RPM. I found revving it to 3k RPM or more (>16 mph) before shifting from 1-2 would yield a smoother shift
  12. May 3, 2024 at 11:27 AM
    southwestorv
    Looks we have about the same truck. I’m hoping mine will smooth out after a fluid change, because I tend to ease around, shifting closer to 2K rpm.
