Rough, low idle after removing battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Traveler, Oct 1, 2012.
  1. Oct 1, 2012 at 12:28 PM
    The Traveler
    The Traveler [OP] Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Just so everybody knows, and doesn't freak out like I did yesterday...
    After resetting my battery terminals yesterday while wiring some switches, I turned my truck on and it immediately stalled and died. Started and ran the second time, but did not idle high like it usually does when cold. It was at 500rpm in park, and about 450-400rpm in drive/reverse. The truck was shaking pretty bad, and I got scared thinking I pulled a vacuum line out by accident. Seemed to drive ok, just idled weird.
    After about 15 minutes of driving and restarting the truck, it was running fine again. So if this happens to you, don't panic! :D
  2. Oct 1, 2012 at 12:30 PM
    Large
    Large Red
    x2, mine does this every time I disconnect the battery for more than a few seconds.
    TheDevilYouLove likes this.
  3. Oct 1, 2012 at 2:20 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Takes a while for your A/C to start working again too.
    jfoster92 and TXpro4X4 like this.
  4. Oct 1, 2012 at 4:26 PM
    troy28
    troy28 Well-Known Member
    Capitol of Salty Roads
    Need help
    I assume someone will chime in if I am completely wrong. I believe when you disconnect your battery you also reset your computer for all your fuel and air mapping back to factory. You then have to rebuild the program by satisfying a variety of driving conditions like a 0 - 60mph acceleration, cursing at 60mph for X amount of time, and so on. Once you satisfy all the checks the truck should be back to normal.
    Roostfactor and Shark18 like this.
  5. Oct 1, 2012 at 4:46 PM
    The Traveler
    SoCal
    Yes I believe that's exactly what happens...
    ...and driving in SoCal, I've had my fair share of cursing at 60mph for x amount of time :D
    Roostfactor, Shark18 and Jere like this.
  6. Oct 1, 2012 at 5:07 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    The ECM has to learn again. no worries.
    Shark18 likes this.
  7. Oct 1, 2012 at 6:20 PM
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    I use a 9-volt battery wired to a battery terminal and wires with clips long enough to hook to both the positive and negative battery cables. It keeps enough current in the system to retain the radio pre-sets and helps with the computer re-boot as well.
    Ray
    TXpro4X4 likes this.
  8. Oct 1, 2012 at 6:27 PM
    The Traveler
    SoCal
    Interesting...
    and hey nice avatar! Do you have a Cobra? I just sold mine a few months ago :(
  9. Oct 7, 2012 at 2:27 PM
    Ray
    San Diego
    09 Pre-Runner
    Yep. That's our car.
    Ray
  10. Oct 7, 2012 at 2:36 PM
    Large
    Large Red
    X2 again lol. Houston traffic sucks around the clock.
  11. Jun 30, 2015 at 7:56 PM
    Burna420
    Burna420 New Member
    2012 TRD SPORT
    Hey, I just did the same.. Now my trac off, check engine lights are on.. Had black emissions and it drives at 20-30mph... When I first turned on the truck it had a rough idle then died.. Second time it was rough but stayed running.. Battery had been completely depleted and when we tried to jump the battery.. My "help" had their connection backwards.. The black emissions.. The slow driving.. And the trac off light are freaking me out.. It is due for a tune up doh
  12. Jun 30, 2015 at 10:30 PM
    The Traveler
    SoCal
    Woah, so they applied positive to the negative and negative to the positive? Sounds like it may have blown a few fuses that control stuff.
    I'd be careful driving it. Sounds like it's in limp mode.
  13. Jul 1, 2015 at 5:12 PM
    Burna420
    Burna420 New Member
    2012 TRD SPORT
    Yeah :( they sure did.. My baby IS limping.. Smell something electrical too.. Checked and replaced all fuses that I can get to without taking apart the fuse box.. I did change the alt fuse.. All other fuses are replaced an good.. Starter? Could it be the alternator? It stays at 2000 RPM.. Have to let off the gas a lil for it to gear up.. But in all the fastest it'll go is 45mph.. Everything else is working lights, stereo.. Windows doors.. It's the drive, that's off :/
  14. Jul 1, 2015 at 5:51 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Weird. Never h are if this before. Nor have I ever noticed it on my taco before.
  15. Jul 3, 2015 at 7:23 PM
    Burna420
    Burna420 New Member
    2012 TRD SPORT
    Took my Tacoma into the dealership. Had some codes reset.. The O2? Now it's back to normal.. Although I do need a new airflow sensor.. Started and alternator are good.. But yeah.. Moral of my story.. Hook up jumper cables your dammnnn self
  16. Sep 6, 2016 at 10:37 PM
    hankwhitley
    hankwhitley New Member
    Monterey, CA
    06 Prerunner SR5
    Cleaned battery terminals and the same thing happened...>500rmp idle and some heavy shaking, but never stalled out. Drove fine except when I was stopped on a hill and let off the brake. I rolled backwards about 2 feet before it kicked into drive...almost rolled into the car behind me! Drove around for 15 mins or so, on and off the freeway, and when I pulled in to my garage the idle slowly adjusted back to normal. Hopefully tomorrow she starts up with no problems! Not a pleasant experience, I'll think twice before disconnecting the terminals again.
  17. Sep 7, 2016 at 2:07 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is not normal. It should have already been in drive.
    You might want to check the transmission fluid level.
  18. Dec 10, 2018 at 8:18 PM
    Taco_man_jake
    Taco_man_jake New Member
    Jake
    06 Tacoma *stock*
    NONE
    Hey guys, I am also having this issue, however I drove it for about 10-15 mins and its still extremely rough foor idle, I just replaced the alt and the bat today (junkyard alt, fresh bat) its charging at 14.2 just wondering if anyone has some good news for me i idle at like 150-250 RPM.... really stressful and starting to lose some hair over it.
  19. Dec 10, 2018 at 8:39 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    That's is a really low idle. Also supposed to be charging at 13.8. You sure you put the belt on correctly?
  20. Dec 10, 2018 at 8:53 PM
    Taco_man_jake
    Jake
    06 Tacoma *stock*
    NONE
    yeah I know its on properly 100% I was told by a few friends that its ok for it to be around there it hits 14.2 and dips to around 13.8 fluctuates. and i know the idle is really rough its scarry AF im worried about my poor little truck
