Rough Idle When at a Stop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shaowei, Dec 18, 2012.
  1. Dec 18, 2012 at 9:39 AM
    Shaowei
    Shaowei [OP] Well-Known Member
    New Mexico
    05 Tacoma 4x4 LB
    I have a 2005 double cab with a V6-Auto with K&N AF that has approximately 90k miles. Generally, I love this truck. My biggest complaint is a rough idle (sound and a slight vibration) when I am at a stop, which is frequent in rush hour.
    This is the situation. When the truck is in Park, the engine idles perfectly. No sound or vibration. When the truck is in Drive and I'm stopped, the engine idles roughly which includes sound and a slight vibration. The engine RPM is slightly lower than in Park (which I would expect). If I just barely press on the gas (while the other foot is on the brake) the rough idle disappears. When I begin moving the sound and vibration is usually present until about 15-20 mph. The rough idle occurs nearly 95% of the time, the other 5% is beautiful silence!
    I know without seeing/hearing the idle in real life this is a stretch but would appreciate any ideas to start trouble shooting. Thanks!
  2. Dec 18, 2012 at 9:46 AM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    hows the motor mounts?
  3. Dec 18, 2012 at 10:18 AM
    Rollntoys
    Rollntoys Member
    Upstate NY
    Tacoma TRD Sport
    Stock
    I have 2012 Taco with a 6 and it has an interment rough idle while sitting at stoplights. Usually in drive at a light it idles at 600rpm. For no reason it will bump up to 850rpm and I notice the truck slightly vibrating. Sometimes it will lurch forward as if someone barely taped my rear bumper. I thought it was normal but now it's starting to bug me. After the holidays I'll bring it in to get it checked out.
  4. Dec 18, 2012 at 10:24 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    motor mounts. but its present untill 15mph... weird.
  5. Dec 18, 2012 at 10:28 AM
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    When have the plugs been replaced?? I notice the same rough idle and pinging when I get gas from certain stations, I found a station that my truck likes and have been fueling there regularly.
  6. Dec 18, 2012 at 11:04 AM
    nathan3306
    nathan3306 Well-Known Member
    Nathan
    Charleston AFB, SC
    2012 SR5 DC 4X4
    Mine does that when the AC kicks in. Freakin hate it!
    Both my 05 and 12 have done the same thing. This V6 is no smooth running engine for sure.
  7. Dec 18, 2012 at 12:41 PM
    GoHuskers
    GoHuskers Well-Known Member
    Nebraska
    2012 White DCLB TRD Sport
    Same thing on my '12 sport v6. In park it is ok but slight vibration when stopped in drive. It has less than 3k miles.
  8. Dec 18, 2012 at 1:48 PM
    coyote70
    coyote70 New Member
    Max
    Pittsburgh
    13 TRD sport
    I have a 2013 with 2800 miles that does exactly the same thing, was going to bring it up at my 5000 mi service
  9. Dec 18, 2012 at 2:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If the K&N Filter is lubricated I would guess a dirty MAF Sensor.
    tacofish and 06Tacooo like this.
  10. Dec 18, 2012 at 2:58 PM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    Ya, any of you guys clean your MAF or Throttle Body? Every spring I clean the TB, and MAF and install a new set of plugs. Always runs smooth, even when the AC kicks in..
  11. Dec 18, 2012 at 3:38 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    my 2012 does it with 1,800 miles. a tad disconcerting but if they all do it and the trucks generally last forever it's no big deal to me. i mean, it could be a Chevy.
  12. Dec 18, 2012 at 3:46 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    I had the same lurch in my 2011 DCLB. I was told that it was normal, I just got use to it. On my 2013 AC I don't have the same lurch.
  13. Dec 21, 2012 at 6:13 PM
    Shaowei
    New Mexico
    05 Tacoma 4x4 LB
    Thanks for all the input. I've performed a cursory inspection of the motor mounts and didn't notice anything. I'm planning on cleaning the MAF and throttle body to see what happens.
    Also, I have a new observation. I went to the open the hood when the motor was idling roughly so I put on the park brake and found out that the rough idle only happens when my foot is on the brake. No brake pedal + park brake equals no rough idle.
    I'll keep this thread updated as I learn more.
  14. Dec 21, 2012 at 8:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Sounds like an issue with the vacuum brake booster...
  15. Dec 21, 2012 at 8:30 PM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    This is out of my ignorance of the truck's systems, but could there be a leak in the brake booster's vacuum system which, in turn, causes the engine to stumble?
  16. Dec 22, 2012 at 4:55 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Vacuum leak or tight valve clearance.
  17. Dec 22, 2012 at 12:42 PM
    Shaowei
    New Mexico
    05 Tacoma 4x4 LB
    I hadn't thought about the brake system. Is a leak in the brake vacuum system something that I could diagnose at home or something better handled by a shop? Anything particular to look for?
  18. Dec 22, 2012 at 2:16 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    If there was a leak in the vacuum booster, your pedal would most likely get rock hard and you would most likely have a CEL with lean codes.
  19. Dec 22, 2012 at 2:29 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Mine does that when it's still warming up and sometimes at stop lights since almost new...never got around to figuring out what it was :notsure:
  20. Dec 22, 2012 at 3:14 PM
    Vstrom30
    Midwest
    Mine seems to do it when the temperature drops outside. I never considered it a problem.
