Rough idle on my 07 just started..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KrypticZer0, Jan 22, 2022.
  1. Jan 22, 2022 at 6:24 PM
    KrypticZer0
    KrypticZer0 [OP] Well-Known Member
    Western Idaho
    2007 TRD Sport LB 4x4
    Just noticed when I pulled into my driveway and parked that my truck started jerking a bit and truck began slightly sputtering and shaking. Not bad but definitely noticeable. Truck has 160,000 miles on it. I was going to park it and wait to drive it until I change the spark plugs. Would it be worth it to change the ignition coils? I really don’t want to ruin anything internally in the truck. No check engine light either. Please help!
  2. Jan 22, 2022 at 6:34 PM
    KrypticZer0
    Western Idaho
    Also I am going to recharge my k&n air intake filter and clean the throttle body while I’m in there
  3. Jan 22, 2022 at 6:47 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Change spark plugs and clean your maf. The k&n air filter oil can get on the maf and cause issues. Or it can let dirt through and the maf gets dirty.
  4. Jan 22, 2022 at 6:49 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    No need to change the ignition coils "just because", if you have a bad one change it no need to change them all.
    Main thing to look for is oil in the plug tubes (this indicates valve cover gaskets are leaking), you may want to replace the coil boots depending on their condition.
    Denso OE# plugs are recommended, K20HR-U11 for the 1GR-FE 4.0L V6 (non supercharged) (30K mi recommended change interval), SK20HR11 for the 2TR-FE 2.7L 4cyl (100k mi recommended change interval).
    TnShooter likes this.
  5. Jan 22, 2022 at 6:59 PM
    KrypticZer0
    Western Idaho
    Sounds good that’s what I’ll do. Thank you!
  6. Jan 22, 2022 at 6:59 PM
    KrypticZer0
    Western Idaho
    I appreciate the response. Thank you. I’ll take a look at them when I replace the spark plugs
    Dm93[QUOTED] likes this.
  7. Jan 22, 2022 at 7:05 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I will also note that when you clean the throttle body you may want to unhook the battery for a few min then reconnect it and let it idle for awhile to relearn it's base idle or you may have high idle issues until it relearns on it's own.
    ghardy and KrypticZer0[OP] like this.
  8. Jan 22, 2022 at 7:11 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'd start simple.
    Check to make sure the battery post are clean and free of corrosion.
    A poor connection will cause all sorts of issues with the truck.
    The battery post clamps on our trucks are a know weak link.
    I've been thru this 3 times in 20 years. ( Yet Toyota still uses these shitty battery post clamps)
    KrypticZer0[OP] likes this.
  9. Jan 22, 2022 at 7:31 PM
    Waasheem
    Waasheem
    2007 xrunner
    Spark plugs are recommended at 30k miles so if they’re due, change them.
    I think you should try cleaning the maf sensor first, that might solve the problem. Look in the stickies, follow the instructions to the letter, no short cuts or I’ll use this stuff instead of the Crc maf sensor cleaner.
