Rough idle and a misfire on cylinder #1
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mecano66, Feb 14, 2019.
  1. Feb 14, 2019 at 6:58 AM
    Mecano66
    Mecano66 [OP] New Member
    Denis
    Tacoma 2016 white
    Hi,
    Does anybody know anything about a engine code P11EC00 Cylinder #1 air-fuel ratio imbalance
    (port)
    engine has a rough idle, a misfire on cylinder #1. Data list show A/F sensor out of control, so I
    change it, same code happen, so I change injector on cylinder#1 (port) side. still the same code
    and misfire only on Cylinder #1 . Switch coil and spark plug, still same code... This is on a Tacoma 2017 V6 2GR-FKS
    Any ideas on that?...
    thank you
  2. Feb 14, 2019 at 7:40 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Code came back after you cleared them, after each repair?
  3. Feb 14, 2019 at 7:44 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Have you tested compression?
  4. Feb 14, 2019 at 7:47 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    stun gun likes this.
  5. Feb 14, 2019 at 7:55 AM
    splitbolt
    NW Arkansas
    Here are the sensors it uses to pop that code.
    Main;
    Air fuel ratio sensor
    Crankshaft position sensor
    Related;
    Mass air flow meter
    Engine coolant temperature sensor
    Vehicle speed sensor
    Considering what you've already replaced and how it's isolated...I'm leaning towards a bad port injector.
  6. Feb 14, 2019 at 7:58 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Its a 2017? Warranty? Short of the DI injector having issues, you have eliminated the easy stuff.
    fdbyrne likes this.
  7. Feb 14, 2019 at 8:14 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I'm wondering about this too. I know it's good therapy to wrench one's own vehicle, but if the dealer catches evidence that someone else has been futzing around below the plastic cover, it gives them an excuse to try and deny a future warranty claim. That can bite you hard if an expensive part fails later on.
    Just saying.
  8. Feb 14, 2019 at 10:24 AM
    Mecano66
    Denis
    Tacoma 2016 white
    Thank you guys for your fast respond... Yes light was coming back on after all the repair or parts replace.. To be honest with you all, vehicle is going on and off to the dealer and they don't know yet what will be the next step.. Compression test was done on cylinder #1 and #5 of the same bank.
    #1 Dry test 120PSI
    #5 Dry test 180PSI
    #1 Wet test(adding a drop of oil) 140PSI
    #5 Wet test 200PSI
    Also a leak down test was perform also and no leak from air intake nor exhaust tail pipe, but leak a bit from PVC hose..
    What puzzle my mind is after the leak down test, clear all the code's.. and vehicle drove for 4 days without light to come on. I thought piece of carbon was on the valve and clean up by itself.. but light did come back on after 4 days..
    I just wondering if anyone happen to have a trouble with that code before?...
  9. Feb 14, 2019 at 10:31 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    Well, based on what you have discovered there, a tear down or engine replacement is next. 120 psi is way, way low for a new engine. I would step back and let Toyota do their thing. Do not give them an excuse not to follow through.
    PJTree, landphil and na8rboy like this.
  10. Feb 14, 2019 at 10:32 AM
    na8rboy
    WI
    There shouldn't be more than a 10% difference in compression between cylinders. On any engine....
    landphil, Big tall dave and Flash1034 like this.
  11. Feb 14, 2019 at 1:41 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I'd still want to rule out one of the, if not the, easiest of these potential problems - Crankshaft Position Sensor. That is the X at the center of so many things in your ECU. It's what reads the RPMs and if it's off, you'll end up with a host of issues. In severe cases it can cause stalling but in less severe cases could cause long-term issues like these.
    They are likely to tell you (like they did me) this isn't your issue b/c your 17 wasn't under recall. Nor was mine, Toyota still claims nothing was wrong with mine. there was no question once I replaced it. I caught mine at less than 10k when it started idling really rough and couldn't seem to nail a proper AFR... i'd have nasty rich exhaust frequently and hard idling that felt like it was on the verge of stalling.
    May have zero to do with your issue again, but I'd want to ensure the simplest potential issue had been validated... Worse case, it's a $100 part and 5 minutes to install if you lock your wheels to the left and reach in.
    That said, having the dealer do this in your case may be preferred in the event you do have engine damage
  12. Feb 15, 2019 at 5:31 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    What’s the rest of the story? Has the truck gone swimming and injested enough water to bend a rod?
    And is it off powertrain warranty by mileage?
    Comato$e likes this.
  13. Feb 15, 2019 at 5:36 AM
    Comato$e
    Comato$e Well-Known Member
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    I wouldn’t have touched anything and called a tow truck from the beginning if you’re still within the PT warranty.
  14. Feb 15, 2019 at 7:58 AM
    Mecano66
    Denis
    Tacoma 2016 white
    truck have only done highway millage, no wood or mud or a flood.. millage is only 44,000 miles. I have my own work shop, and the only vehicle I'm working on is Toyota... I have good contact with local Toyota dealer.. That 2017 truck is going on and off to the dealer for that problem, mean time he's coming to my shop having a second opinion.. This site seam to have a lot of experience in Toyota vehicle and truck, so I decide to have a chat with all of you to have your opinion also on that.. Probably I will not be the one that will fix it, We all know its a dealer case.. Vehicle is drivable but rough idle.. Thank you guys for your time !
    Gregw138 likes this.
  15. Feb 15, 2019 at 8:04 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    You have big problems with that low compression in number 1 . They know that .
  16. Mar 14, 2019 at 5:29 PM
    Cleme360
    Cleme360 New Member
    2017 silver Tacoma TRD
    Any up any Update on your Tacoma I’m having same problem same Trouble codes
  17. Sep 28, 2019 at 11:00 AM
    Sandy94
    Sandy94 Well-Known Member
    The Commonwealth
    Toyota Tacoma
    Well, I just started throwing the same code. Took it to the dealer yesterday since is a 2018 still under warranty. I was hoping it was just the sensor upstream from the Cat. It's not. Dealer said they're in contact with Toyota higher ups and won't know anything until at least Monday. I'm pretty disappointed cause I expect a lot from Toyotas. OP how's yours working out?
  18. Apr 30, 2020 at 8:23 AM
    TacomaMax89
    TacomaMax89 Member
    Did you get to the bottom of this? I have a similar problem and am having there following things fixed under warranty. There is an imbalance in cylinders 1 and 3.
    04111-0P193 1EA HEAD GASKET KIT $ 560.14
    13715-0P030 8EA EXHAUST VALVES $ 214.00
    13711-OP030 8EA INTAKE VALVES $ 134.64
    11101-09550 1EA CYLINDER HEAD $ 1110.96
    90250-08028 2EA STRAIGHT PIN $ 4.02
    PARTS TOTAL $ 2023.76
    LABOR TOTAL $ 967.93
    JOB TOTAL $ 2991.69
  19. Apr 30, 2020 at 8:28 AM
    DMP
    DMP Well-Known Member
    Boston
    2018 TRD Sport DCSB 4x4
    Starting to be a common issue it seems. Warranty cylinder head replacement for me at 48k miles on a 2018.
    Adding my warranty parts list.
    Name Part No. QTY
    HEAD SUB-ASSY, CYLIN 1110109550 1
    PIN, STRAIGHT 9025008028 2
    GASKET KIT, ENGINE O 041110P193 1
    VALVE, INTAKE 137110P030 2
    VALVE, EXHAUST 137150P030 2
    FIPG OIL PAN 0029500103 1
    PIN, RING 9025311021 2
    TacomaMax89 likes this.
  20. Apr 30, 2020 at 8:38 AM
    TacomaMax89
    TacomaMax89 Member
    DMP have you seen other feeds with the same problem? I am new to here and trying to find others with the same problem.
