Rough Idle After Valve Cover Gasket Job
Discussion in '1st Gen. Tacomas (1995-2004)' started by kigmob, Dec 16, 2013.
  1. Dec 16, 2013 at 7:11 PM
    kigmob
    kigmob [OP] Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    So I went all out and replaced my valve covers, valve cover gaskets, intake plenum gaskets, cam plugs, spark plugs, plug wires, and a few other things. I also changed the oil, cleaned the throttle body/intake manifolds, and cleaned the MAF/air filter. When I put it all back together and started it, the truck ran great. As it began to idle down from the cold start, it started to sound like it was missing. Once it got to normal idle it really sounded like it was missing. It sounded like a Harley or like it had a cam in it. If I rev it up, it sounds normal. I checked for any vacuum lines not connected but they all seemed to be in place. No CEL as well. I also removed the negative from the battery and the EFI relay for 30 mins to reset the system. Not sure what the problem can be. I leaning towards something with the throttle body. Maybe the IAC valve? I did not remove and clean this. Just wondering why it would act up now? :confused: Thanks for any help!
  2. Dec 16, 2013 at 8:02 PM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Recheck all of your plug wires.
  3. Dec 17, 2013 at 4:45 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    Definitely check your IAC
  4. Dec 17, 2013 at 4:49 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Also check for vac leak
  5. Dec 17, 2013 at 7:56 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Probably left something unplugged.. Check everything. Though harleys do sound sweet...
  6. Dec 17, 2013 at 8:16 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Why did you do the 'gasket job' in the first place? Was there an initial problem?
    You could have one or more vacuum lines connected to the wrong ports. Did you mark them before you disconnected stuff?
  7. Dec 17, 2013 at 8:20 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    how come new valve covers? were the stock ones toast?
    definitely have something hooked up wrong, throwing any codes or check engine light yet?
  8. Dec 17, 2013 at 8:46 AM
    BamaToy1997
    Bill
    Navarre, FL
    Check all your connections to all sensors. Make sure, as mentioned, that you did not connect a vacuum line to the wrong port. Double check your brake booster vacuum line. If you have access to a data reader look at your fuel trim numbers after the engine has warmed up. If the fuel trim is a positive number, the engine is running lean, and you have some sort of vacuum leak. It happens to the best of us, but it is very possible that when you did the intake manifold gaskets, that something was not tightened down properly, or a gasket shifted during installation. Usually a small bottle of propane, and a propane torch tip can be used to find vacuum leaks. Simply turn the propane torch on WITHOUT lighting it, on a low setting, and move the tip around the intake manifold. When you get close to the leak the engine will start to run smoother and may increase slightly in RPMs due to the vacuum leak drawing in the propane into the engine.
  9. Dec 17, 2013 at 9:14 AM
    kigmob
    James
    New Orleans
    I did the job because the gaskets were leaking oil badly. And I took pics of everything under the hood before the tear down.
    I got new valve covers because I cracked one side by over tightening the bolt. I will be checking all connections today.
    I do not have access to a data reader at the moment. However I will check all connections again. Thanks for the detailed response!
    They do sound sweet :cool:
    Will do.
    Will do.
    Will do this also. Would love to fix it without taking the TB off again...
  10. Dec 17, 2013 at 9:59 AM
    kigmob
    James
    New Orleans
    So I checked all connections and then started it up. It did the same thing. Decided to take it for a spin (did not do this last night). After about a 10 min drive around the block and on a small road where I got up to 45 mph, it seems to be idling fine. :confused: However it does seems to be a tad bit high (850-900) w/ no AC. Usually it idles at about 700-750. I'll see what happens from here... Thinking back on it, I may have damaged the TPS while LOADING my TB with intake cleaner. But who knows. I think too much. It seems ok now so I'll let it be and see how it goes..
  11. Dec 17, 2013 at 11:55 AM
    kigmob
    James
    New Orleans
    Spoke too soon. Took it for a drive again and the weird idle came back for a little bit and it threw a CEL. My SG showed P0130, P0133, and P0171. After looking up these codes I'm pretty sure its the front O2 sensor (bank 1, sensor 1). Any other suggestions?
  12. Dec 17, 2013 at 4:10 PM
    kigmob
    James
    New Orleans
    Bump. About to buy the O2 sensor but would like to get any suggestions before. The codes make me think it has to be that O2 sensor. Just weird that it would malfunction after all the work I did which had nothing to do with that O2 sensor..
  13. Dec 22, 2013 at 8:08 PM
    kigmob
    James
    New Orleans
    Replaced the upstream O2 sensor and cleared the codes. All codes cleared except the P0171 code. After some searching, this codes seems to be a pain to fix. I'm guessing (since I had the whole intake apart to install the valve covers) it's a vacuum leak that I have not found yet. Any other suggestions? I plan on replacing the majority of my vacuum lines. Hopefully this helps.
  14. Dec 24, 2013 at 10:17 AM
    michaelw.grey
    michaelw.grey Well-Known Member
    mike
    pensacola, florida
    98 4x4 SR5 3.4L V6 AUTO Ext Cab
    Full ome kit with 882's,icon uca's, line x bed, 32" bfg muds, 2nd gen rims, low pro tool box,
    looking forward to seeing what the issue was
    subd
  15. Dec 24, 2013 at 11:41 AM
    Changeling
    Changeling Well-Known Member
    Maryland
    2001 Tacoma TRD SRD V6 X-Cab Limited Edition
  16. Dec 24, 2013 at 11:49 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
  17. Dec 24, 2013 at 11:55 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
  18. Dec 24, 2013 at 12:10 PM
    Changeling
    Maryland
    Look at it anyway you like.
  19. Dec 24, 2013 at 1:21 PM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    Sounds like kigmob is talking about the maf sensor. Cleaning the maf sensor will probably be beneficial.
    I'm leaning towards a possible vacuum leak after taking the intake all apart. Try getting a can of starting fluid and spray it around vacuum line connections. The engine will idle up a bit if the connection is leaking.
    Good luck OP! Keep us posted. . .
  20. Dec 24, 2013 at 1:35 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Fixed...:D
