Rough Country Vertex Coilovers 3.5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maka702, May 9, 2022.
  1. May 9, 2022 at 11:44 PM
    Maka702
    Maka702 [OP] Member
    2017 Tacoma TRD Sport 2wd
    All LED lighting, TRD PRO Grill, Pop n Lock tailgate actuator, door sill protectors w/ vinyl decals and glove bow.
    20220118_134456.jpg A friend installed the RC Vertex Coilovers 3.5 on my 3rd Gen. The kit came with the forged uca. After the install we noticed that the uca sits very close to the spring. Wondering if anyone has this problem. If I went with 4 inch knuckle that would bring the uca level, otherwise I will end up with a 7 inch lift which I don't want. Can I adjust the springs to give me a true 4 inch lift.
  2. May 10, 2022 at 6:00 AM
    Sweets
    Sweets Well-Known Member
    Indiana
    2023 GMC Canyon AT4X Edition1
    I have the same kit on my Tacoma. I can stick my hand between the springs and UCA and still have another 3/4"+ to spare.
  3. May 10, 2022 at 1:05 PM
    Maka702
    Maka702 [OP] Member
    20220118_134302.jpg Love the kit, just can't get my fingers in there. Do you have the stock spindles on your truck?
  4. May 10, 2022 at 2:52 PM
    Camerasandcoffee
    Camerasandcoffee 900hp short of 1000hp
    Jonathan
    Racine WI.
    2019 Trd Sport
    Relentless Fab hybrid bumper, 2.5” Dobinsons IMS lift, RCI skids and sliders, block heater. Painted FJ Steelies. Was trying to keep it stock, now slowly building for the Wisconsin trails.
    Is that with the truck sitting on the wheels, or still up on the jack?
    7” lift you say? That would require different spindles, diff drop etc.
  5. May 10, 2022 at 7:27 PM
    Maka702
    Maka702 [OP] Member
    My truck is sitting on the ground. I'm not trying to achieve a 7' lift. I'm trying to figure out, if I get 4' spindles to get the uca's to sit level, then I would have to adjust the Coilovers to get the 4' lift. Do you see how close the uca is to the spring.
  6. May 11, 2022 at 4:36 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Hows the ride
  7. May 11, 2022 at 5:42 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I would say the coilovers aren't set up properly. With that angle of the UCA with weight on the wheels, you have next to no downtravel on the suspension so every time you hit a bump, you will smack the spring with the UCA. Maybe try taking some preload off the springs of the coilovers?
    OmahTako likes this.
  8. May 11, 2022 at 5:47 AM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    Down travel has left the chat.
  9. May 11, 2022 at 6:09 PM
    Camerasandcoffee
    Jonathan
    Racine WI.
    2019 Trd Sport
    ^This!^ This just looks like the wrong strut spring combo for what OP wants.
    Travel is maxed out and there is very little thread to reduce the preload.
    OP longer spindles are not going to lower the truck, just fix the UCA angle. My concern is that the CV shafts are maxed out as well.
    (Edit) I would contact RC about your issue. Maybe verify the part numbers you have to make sure it is in fact the right kit and not mixed up with parts for another truck. Tundra for instance
  10. May 11, 2022 at 6:26 PM
    airforceb2cc
    Don
    KCMO
    This is still a 2WD truck…
    Chew likes this.
  11. May 12, 2022 at 3:21 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  12. Mar 7, 2023 at 8:21 AM
    Chief_CNMI
    Chief_CNMI Well-Known Member
    Bryan
    Saipan, Northern Mariana Islands
    2020 4x4 V6 SR5 White
    All lighting are led, wheels, tires, 5100 lift, pro grill, bed light, seat covers, door sill protectors.
    Does anyone know the collapsed and extended lengths measurements on these 3.5" vertex? And maybe also the n3 lifted struts by any chance?
  13. Apr 23, 2023 at 4:35 PM
    Fonzy77
    Fonzy77 Well-Known Member
    California
    2007 White Tacoma
    I have the same thing after my vertex install, where you able to find a way to fix it?
  14. Apr 30, 2023 at 9:23 AM
    Chief_CNMI
    Bryan
    Does anyone know the collapsed and extended length on these 3.5" vertex?
  15. Apr 30, 2023 at 7:23 PM
    goonsquad08
    goonsquad08 Well-Known Member
    Michigan
    ‘12 DCLB Tacoma
    From the internet/search on various retailers sites:
    3.5” lift version
    collapsed: 18.01”
    Extended: 23.12”
    Chief_CNMI[QUOTED] likes this.
  16. Nov 7, 2023 at 4:58 PM
    Only_C_Fans
    Only_C_Fans New Member
    chris
    2007 tacoma Prerunner
    Did anyone ever come up with a fix for this? ive got the same problem after installing on my 07 prerunner
  17. Jan 23, 2025 at 5:09 AM
    BayouTaco22
    BayouTaco22 New Member
    2022 Tacoma TRD Pro
    3.5” RC Vertex Lift
    I know this thread is kinda old, but just my 2¢, when installing the UCA, did you completely tighten down the mounting bolts while the truck was still lifted/on a jack?
