Rough Country Speedometer Calibrator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by alwaysHI, Nov 5, 2018.
  1. Nov 5, 2018 at 10:47 PM
    alwaysHI
    alwaysHI [OP] Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    Hey everyone,
    Today it was brought to my attention by a friend, that rough country released a inline speedometer calibrator for our 3rd gen Tacoma’s. I’m unsure if he saw it at SEMA this past week but here’s the link:
    https://www.roughcountry.com/speedometer-calibrator-90043.html
    Cheaper option than Hypertech. I’m in definite need of a calibrator from larger tires and regear. Just never could justify 240+ shipping to Hawaii for a hypertech.
    Any thoughts? Or any of you made it to SEMA and have any details on this?
    I’ve read hypertech reviews from TW stating to actually measure the tire, and leave gear ratios out of the equation. Just wondering if this product would be similar with the setup.
    Thanks
    GusmanJE likes this.
  2. Nov 6, 2018 at 12:08 AM
    fastmover34
    fastmover34 Well-Known Member
    Seems legit, hopefully someone will post a review comparing it to the Hypertech unit
  3. Nov 6, 2018 at 12:34 AM
    sportracer829
    sportracer829 Taco Tuesdays... PShhh Taco Everyday!
    Andrew
    Colorado
    2018 Black TRD PRO DCSB
    Subd I wanna know too.
  4. Nov 6, 2018 at 2:43 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Changes shift points based on tire diameter. Very promising. Unfortunately can’t be sold or used in California . Arggggg!
  5. Nov 6, 2018 at 3:27 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    Very interesting that this says it changes the shift points....
    I just sent them an email to verify that it changes what the ECM sees.
    Guys on the ovtune thread said the hypertech unit does not change what the ECM sees.
    I’ll probably end up buying it, doing some logging with tech stream, then return it if it actually doesn’t change what the ECM gets.
    alwaysHI[OP] and bulalo like this.
  6. Nov 6, 2018 at 3:39 AM
    DarkFire989
    DarkFire989 Well-Known Member
    Ian
    Worcester, MA
    2017 TRDOR DCLB
    Hitting up my buddy who is a RC dealer. Might give this one a shot.
    alwaysHI[OP] and Tac0Tic0 like this.
  7. Nov 6, 2018 at 3:42 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    Group buy!
    alwaysHI[OP], bulalo and Yann like this.
  8. Nov 6, 2018 at 3:46 AM
    DarkFire989
    Ian
    Worcester, MA
    2017 TRDOR DCLB
    I could ask....
    Tac0Tic0[QUOTED] and Yann like this.
  9. Nov 6, 2018 at 5:58 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    I don't see how this does anything besides updating the cluster display. The ECU still sees the speed from the wheel sensors first.
    Tac0Tic0 likes this.
  10. Nov 6, 2018 at 6:02 AM
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    Appears to install in the same manner as the HyperTech module, so I'm unclear as to how this can update the ECM.
  11. Nov 6, 2018 at 6:03 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I agree. It T’s into the same spot as the hypertech. Similar small little black box module too
  12. Nov 6, 2018 at 11:26 AM
    alwaysHI
    2017 MGM DCSB
    Just take it out prior to inspection lol
    I don’t understand that part either. But a cheaper alternative to hypertech, yet achieve the same goal is nice for me haha. My mpg data per trip is affected since everything is off. My SR5 came stock with 245’s and I’m on 285’s now with 4.88’s
    baltimorebirds2 and Tac0Tic0 like this.
  13. Nov 6, 2018 at 11:29 AM
    commbubba19
    '23 TRD PRO
    gears don't effect the speedometer display in the cluster, only tire height.
    MCDavis likes this.
  14. Nov 6, 2018 at 11:42 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Are you sure about that??
    bulalo[QUOTED] likes this.
  15. Nov 6, 2018 at 11:43 AM
    alwaysHI
    2017 MGM DCSB
    Ahh, thanks lol
  16. Nov 6, 2018 at 11:43 AM
    MESO
    State of Jefferson
    Stick it to da man!
  17. Nov 6, 2018 at 11:52 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    I got a feeling this thing doesn’t touch the ECU..
  18. Nov 6, 2018 at 11:52 AM
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Definitely interesting
  19. Nov 6, 2018 at 12:01 PM
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    The install instructions are the exact same as the hypertech, they even use a hypertech module in the first pic #730123. That being said, the pic at the top of the page looks nothing like the hypertech other than the module. Something seems a little fishy.
  20. Nov 6, 2018 at 12:02 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Edit: The only tacomas that pull speed from the transfer case are 2005-2011 manual Tacoma, so gears will affect the speedo. The rest all gets read from the ABS sensors so it won't have any affect.
    Assuming third gens are the same as second gens, gear ratio does affect the speedometer on manual transmissions. Autos read speed based off ABS sensors and manuals based off driveshaft revolutions.
    I just did a search to see if I could find an answer one way or another but didn't come up with anything 3rd gen specific.
    6MTPro and xxTacocaTxx like this.
