Rotora BBK (Big Brake Kit) 380 x 35mm 2 piece w/ 6 Piston Forged Aluminum Awesomeness
Discussion in 'Technical Chat' started by skygear, Mar 17, 2015.
  1. Mar 19, 2015 at 5:01 AM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    I finally got my truck yesterday so next local meet up I'm in.
  2. Mar 19, 2015 at 5:06 AM
    skygear
    skygear [OP]                    
    DAYUM! Just for that, we should have a meet sooner than the first week of next month! Theres a bunch of other meets I'm going to in the mean time.
  3. Mar 19, 2015 at 9:50 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Here is a great link. http://carbotechperformance.com/brake-fluid.asp
    I use to use ATE Super blue. Made it easy for fluid changes. However, it doesn't have as good a boiling point, wet/dry as these others in the link. Primarily now, I use the Motul RBF 660. I have not tried the Brembo, Castrol, or AP Racing.
    When you get your BBK, I highly recommend not getting their racing pad. Whichever is their lowest pad, most streetable, go with that. Mine came with the lowest tier racing pads. It didn't take any time for those to cut through the rotors. It is the compound used in them. Becomes extremely abrasive as the compound changes due to heat. Their street pad has lasted a good time now, over two years, and has been on a few track days, still has plenty of pad left, doesn't dust like the race pads, doesn't eat the rotors, and still stops like a sum'bitch!
    I haven't had to upgrade my master cylinder. You won't need to either, unless you just want to.
    If you get rear disks, then you will likely need an adjustable proportioning valve.
    Since there is a rear kit for the 4Runner, and then there is a 4Runner swap kit for the 6 lug Tacoma, then those would fit. I like Proofs.
  4. Mar 19, 2015 at 10:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Here is that pad p/n which i was referring to.
  5. Mar 19, 2015 at 12:40 PM
    JBecker
    Virginia
    I agree completely. Those race compound pads chew up rotors very quick. My friend had a VW GTI with a Porsche 911 Brembo big brake kit and Hawk race pads. The rotors were toast in under 12k miles. But man that thing would stop.
    Replacement discs were about $400 a piece I believe.
  6. Mar 19, 2015 at 12:47 PM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    P/N: RP.06.1.175
    Just in case the photobucket pic up and disappears in a year or so.
  7. Mar 19, 2015 at 2:43 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The 355's are about that price as well. Curious how much the 380's will be. :eek:
    :thumbsup: Let's keep in mind, that those pads will likely be the same. Unless something has changed with their 6 piston calipers.
    I also have the link to AP Racing's cross-referenced pads, which can then also be found on CarboTech's website. Available in various compounds. They don't use the compound which eats rotors, even in their race pads.
  8. Mar 19, 2015 at 2:50 PM
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    No, I meant LOLs :pccoffee:
  9. Mar 19, 2015 at 3:01 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  10. Mar 19, 2015 at 3:41 PM
    skygear
    skygear [OP]                    
  11. Mar 19, 2015 at 3:44 PM
    skygear
    skygear [OP]                    
    Which one from here? I believe I am getting the Street. H2 maybe?
    http://www.rotora.com/new-page-2/
  12. Mar 19, 2015 at 5:35 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    H2 are the ones I recommend. Mine originally came with the H6.
  13. Mar 19, 2015 at 6:29 PM
    skygear
    skygear [OP]                    
    Nice. I believe the H2 are the ones I am being shipped.
  14. Mar 27, 2015 at 1:29 AM
    skygear
    skygear [OP]                    
    Ground from Cali to East coast. Getting excited.
  15. Mar 27, 2015 at 8:59 AM
    #35
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    What all did you end up ordering?
  16. Mar 27, 2015 at 1:06 PM
    #36
    skygear
    skygear [OP]                    
    380 x 35mm Slotted 2 piece rotors
    6 Pistor Forged Aluminum Calipers Red/ White writing
    SS line kit
    H2 Pads
    Mounting Bracket aluminum forged bracket
    Hardware kit
    Thats what I believe the long and short of it is. For the off road endeavors, I didn't like the idea of mud and things potentially getting stuck in the holes of a drilled rotor. The possibility of having a rock or something getting stuck in a hole then causing all sorts of damage to the pads was not appealing to me. \
    I can only imagine the sand and gravel from the beaches, streams, backroads, and other places I travel. Makes me shake my head at it.
    http://www.rotora.com/street-challenge/
    http://www.rotora.com/new-page-3/
    http://www.rotora.com/service-parts/
  17. Mar 27, 2015 at 1:34 PM
    #37
    skygear
    skygear [OP]                    
  18. Mar 27, 2015 at 1:36 PM
    #38
    skygear
    skygear [OP]                    
    Check this out. Exclusive pic! Saw it here first.
    Rotora, you guys got it going on!
  19. Mar 27, 2015 at 1:47 PM
    #39
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    You certainly have my attention.
  20. Mar 27, 2015 at 1:49 PM
    #40
    BadBrains
    AL
    That pic makes me wanna barf but in a good way. Like when Stan sees Wendy.
