Rotor warping yet again
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skynet Surfer, Feb 20, 2020.
  1. Feb 21, 2020 at 9:01 AM
    DG92071
    DG92071 Well-Known Member
    Adjusting the rear brakes is done by the truck itself in reverse and stepping on the brake. Anything tighter is an incorrect adjustment.
    People out there laying on their backs spinning the brake star wheel makes me lmao! And the people that claim I'm incorrect makes me lmfao!
    Most rear brakes on passenger vehicles are responsible for approximately 30% of the stopping power but it varies by vehicle/brake design.
    cosmicfires and whatstcp like this.
  2. Feb 21, 2020 at 9:03 AM
    DG92071
    I must have missed someone calling you a liar. Sounds like the beginning of a great Friday thread though...
    Then you're calipers are sticking, it's not like it's a complicated system.
  3. Feb 21, 2020 at 9:06 AM
    DG92071
    1st you posted they don't warp then you posted a link saying they do warp. I'm confused by these posts.
    Brake rotors definitely warp and anyone who has resurfaced rotors or seen it done will attest that they do in fact warp.
  4. Feb 21, 2020 at 9:06 AM
    DG92071
    Drive it like you stole it. I do too.
  5. Feb 21, 2020 at 9:27 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Negative. Read the article. It confirms pad transfer or heavy footed braking as the culprit.
    Rotors don’t “warp” in the way that people think they do. It’s a myth.
    Having your rotors wear unevenly and create an uneven surface is absolutely possible. So yes, if you go to resurface rotors and measure them with a set of calipers they absolutely can be uneven.
    I stand behind my first post. :thumbsup:
    I enjoy learning, if I’m wrong please provide some information to show that. I’d hate to continue providing wrong information. In this case, I don’t believe I am wrong.
    MolonLabeTaco and sdsurfer like this.
  6. Feb 21, 2020 at 9:55 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I believe the front rotors warp because of inaccurate rear brake adjustment. Rear brake being too loose could cause the front brakes to work more as there is not a proportionate braking bias. I burnt out a few rotors in a meter of a few months until I adjusted the rear. Either through the ebrake method (which never worked for me due to gummed up star adjusters) or manual adjustment.
  7. Feb 21, 2020 at 10:06 AM
    Skynet Surfer
    Skynet Surfer [OP] Well-Known Member
    Dis
    15 DC v6 SR
    Hood struts Weathertech floor mats Roll n lock bed cover With custom Yakima rack over the bed Poploc tail gate Bed mat Retrofit source led fog lights Hitch and or 4 pin wiring Or just random small crap!
    So your saying you already know how I drive without ever seeing me drive my truck. Wow how observant of you. I don't race my truck. I bought it to haul my car when needed. I drive 30 miles a day in LA traffic. So you can stop judging my truck driving just because I also own a modified wrx.
    Now with that said can you be useful about my problem with a fair split of city and hwy driving?
  8. Feb 21, 2020 at 10:07 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    what.
    DG92071 likes this.
  9. Feb 21, 2020 at 10:08 AM
    Skynet Surfer
    Dis
    15 DC v6 SR
    What article I have yet read anything but people pointing the finger at my driving style, which has been inaccurate.
  10. Feb 21, 2020 at 10:09 AM
    coopcooper
    alberta canada
    Start and stop traffic can take a toll on brakes, they get hot the pad material burns onto the rotor yadda yadda next thing you know your new rotors shake.
  11. Feb 21, 2020 at 10:20 AM
    Tah-koh-mah
    Tah-koh-mah Well-Known Member
    2012 Tacoma TRD-Off Road
    What brake pads are you using?
  12. Feb 21, 2020 at 10:41 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    whatstcp likes this.
  13. Feb 21, 2020 at 11:01 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    If rotors indeed warp someone needs to notify the tech school I went to:notsure:
    whatstcp and eccracer104[QUOTED] like this.
  14. Feb 21, 2020 at 11:03 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    ADVICS is one of the OEM brake pad suppliers to Toyota, along with AKEBONO and SUMITOMO, when you eventually pull out the front pads on your truck and the name ADVICS will stamped on the backing plate or AKEBONO depending on what they are sourcing at the time, the 04465-04070 are made by SUMITOMO and are semi metallic, the Toyota 04465-AZ100 pads are ADVICS they are Ceramic, the ADVICS rotors are a Made in USA part that are standard for factory Tacomas, Toyota 04465-az001-TM (discontinued) are AKEBONO ceramic made in USA pads.
    b_r_o, eccracer104 and Greenedmc like this.
  15. Feb 21, 2020 at 11:05 AM
    #35
    Greenedmc
    Daniel
    Elizabethton TN
    Wish I had known This a few months ago lol I’ll have to try those next time instead of going to the dealer
    BillsSR5[QUOTED] and eccracer104 like this.
  16. Feb 21, 2020 at 11:05 AM
    #36
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    ^ This guy gets it :cheers:
  17. Feb 21, 2020 at 11:10 AM
    #37
    BillsSR5
    bill
    2014 SR5
    You can find ADVICS model AD0976 pads are the Toyota model 04465-az100 ceramic pads you can get them from ROCKAUTO or others online at a better price along with ADVICS A6F057 rotors your OEM at less cost.https://www.rockauto.com/en/moreinfo.php?pk=1874706&cc=3015099&jsn=523
    KTM753 and whatstcp like this.
  18. Feb 21, 2020 at 11:13 AM
    #38
    BillsSR5
    bill
    2014 SR5
    yo research research research Toyota buys their OEM parts from numerous suppliers if you can find out who the original manufactorers are u save save a lot of Money$$
  19. Feb 21, 2020 at 11:22 AM
    #39
    jasonct
    jasonct Well-Known Member
    CT
    2021 F150, C7 Grand Sport
    I changed my front pads and rotors over to the Powerstop K137 kit at around 75,000 miles. Coming up on 97,000 miles now and a couple of hard braking events and I haven't experienced any pulsation like I did with the OEM brakes. Great price point too!
    MolonLabeTaco likes this.
  20. Feb 21, 2020 at 11:32 AM
    #40
    DG92071
    If the rotor isn't perfectly true it warped. If the rotor has high spots it warped. If the metal changed shape in any form it warped. Ya all have a ball...
    I think I'm leaning towards getting the f___ out of this thread hahahaha!
    b_r_o likes this.
