Rotational Driveline Noise: Transfer case?
Discussion in '1st Gen. Tacomas (1995-2004)' started by seehodgey, Nov 22, 2020.
  1. Nov 22, 2020 at 3:18 PM
    seehodgey
    seehodgey [OP] Member
    chris
    Southern California
    02 tacoma 3.4
    2002. Tacoma 4x4. 5vzfe. 5 speed (R150f ?). ADD Transfer Case. 208xxx miles. 3inch lift. 285 tires
    I am struggling to diagnose a rotational driveline noise that I now suspect is coming from the transfer case. Looking for advice/ help since i have zero experience with transfer cases.
    Videos of noise:
    https://youtu.be/vJNH0LxkkWY
    https://youtu.be/hGPEWp9PJIo
    Issue: Loud, rotational (bad)whirl noise with occasional metal chirp noise.
    - Occurs at low and high driving speeds, 1st through 5th gear/ 10-70mph.
    - Speed increases frequency of noise but has no effect on pitch or loudness.
    - Occurs in 2hi, 2 low, 4hi, and 4low.
    - No change found by turning, breaking, coasting, or gunning it.
    Action:
    - Removed rear propeller/ drive shaft assuming it was U joints and/or carrier bearing.
    Result:
    - Engaged 4hi and took on a fwd test drive...Noise persists, canceling out rear drive shaft components as issue.
    Recently Replaced: (Last 20k no issues)
    - all 4 wheel bearings
    - both cv axles (napa)
    - ECGS front differential needle bearing replacement
    - Transfer case, front diff and rear diff fluid
    Thoughts:
    - decent amount of throw out bearing noise but doubtful this is THE problem, consistent transmission operation .
    - Jacked up the rear end off the ground with no drive shaft connected... rear wheels spin freely with no noise. Rear diff pinion gear/ shaft has zero play.
    - Zero play in transfer case output shaft flange
    - Sound comes from back to middle.
    - Decent weep in between trans and transfer cases
    Transfer Case Thought/ Sound: - With rear driveshaft removed and engine running.
    - I hear a rumble like bearing noise that is completely different from the problem noise, only while the truck is under simulated load///transfer case output spinning but no driveshaft.
    - 2High/ 5th gear = Noise
    - 2Low /5th gear = Noise
    Second guessing myself/ will double check but...
    - 2high/low, Transmission in neutral = NO NOISE
    - Transmission in neutral and transfer case in neutral = NO Noise
    So my thinking is a transfer case input shaft bearing, output shaft bearing, or maybe transfer case chain but the sound is more bearing than chain to me. When power is sent through the transmission to the transfer case there is a bad transfer case idle noise that may explain the loud noise while driving.
    The kicker is the inconsistency, first day without rear driveshaft = noise, next day/week... drove for 4 days/ 40 miles without the rear driveshaft = NO noise at all, today, with no change in anything, drove 5 miles = Noise.
    I appreciate yall taking the time to read this.
    Black97v6MT likes this.
  2. Nov 22, 2020 at 8:47 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Bearing would be my guess, but you'll have to take it apart to figure out which one. You miiiiight be able to get close with a stethoscope though.
  3. Nov 23, 2020 at 12:17 AM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
  4. Jul 18, 2024 at 3:55 PM
    Herschel
    Herschel Well-Known Member
    Ben
    Utah
    2004 Gold Tacoma, 3.4L V6, Double Cab
    Relentless Fab Front Bumper Relentless Fab Rear Bumper/Swing Out Tire Carrier RCI Engine + Transmission Skid Plates RCI LCA Skids SCS Ray-10 Gunmetal 16" Wheels BFGoodrich Ko2 (285-75-R16) Prinsu Cab + Topper Rack Snugtop Topper MBRP High Clearance Exhaust CVT Hardshell RTT Bilstein 5100 OME 881 Coilover Springs OME Dakar Rear Leaf Springs Engine Replaced at 230,000 Miles (New engine had 91,000 at time of replacement) Rebuilt Transmission
    I'm responding to this thread because @SkunkMan17 thread is a bit messy and doesn't seem to have the same issue or resolution. I have nearly an identical sound as the second video in the original post in this thread. I also have my video here that may help: https://youtu.be/sdWEP3TDfWU
    I talk about the driveshaft because think it's somewhat unbalanced because my carrier bearing is going out. I have rebuilt my driveshaft twice in two years. It's certainly not normal for the DS to go out that often so I'm assuming the T-Case might have something to do with it. The whining sound under acceleration is another problem that has come up. I got my transmission rebuilt 2 years ago and don't know how it would have gone bad again unless the T-Case was somehow "hurting" it. I understand there is a lot of movement under acceleration, I replaced the transmission mount two month ago :notsure:
    Here is another video that might help (I am moving the front driveshaft and not sure if the sound is normal, the wet spots around the plugs are from recently changing fluid): https://youtube.com/shorts/sI4mMpPeFc0?feature=share
    My symptoms are nearly identical to @seehodgey although when I put transmission and T-Case in neutral it still makes noise.
    Until I found this thread, I was under the assumption it was a wheel bearing or axle, although now I'm certainly second-guessing myself. Before I go out and buy an entire T-Case I want to make sure that's the problem. Does anyone have some insight?
    I also just changed the T-Case fluid and it was pretty dirty: IMG_6249.jpg
  5. Jul 18, 2024 at 4:38 PM
    Black97v6MT
    Black97v6MT 364k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    27+ years of livin' Gen1 TacoLife...
    Where is that metal chirp noise seem to come from?
    When does it happen?
    I had an undiagnosable chirp for the longest time that was finally found :(
    But NOW there is a whirring noise.
    Might be like yours IDK yet
  6. Jul 18, 2024 at 4:48 PM
    Herschel
    Ben
    Utah
    I genuinely have NO idea. It has been squeaking for months. For the longest time I thought it was the driver side wheel bearing but nothing I see leads me to understand it’s a wheel bearing sound. The chirp got a little quieter when the grinding started but it’s still there…
    Black97v6MT[QUOTED] likes this.
  7. Jul 18, 2024 at 6:21 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Is this an automatic transmission?
    The chirping in my truck was eventually found in the pilot bearing
    The whirring noise it has now goes away when I push the clutch pedal all the way in
    Rebuilt r150f from another truck
  8. Jul 18, 2024 at 6:31 PM
    Herschel
    Ben
    Utah
    Okay, so this is interesting. I stuck my head out while driving and to my surprise, the sound was actually coming from the rear. I hooked up my $300 directional microphone to a GoPro and found some interesting things. I'm attaching the video here: https://youtu.be/h9quxMjyGGE
    I pointed the mic at the left rear wheel first to see if it's a break bad or possibly a bearing like I originally thought. Then (with fingers crossed) I pointed it towards my rear diff to see if the sound was coming from there. In the video, it seems pretty obvious that it's coming from somewhere on the wheel. My left parking brake seems to be seized but it's been seized for years and I haven't noticed anything until about three months ago when the chirps started. I did have my rear drum brakes replaced about two months ago but that didn't do anything to the sound. I think this might be the rear wheel bearing. But from everything I've seen online, wheel bearings are more of a constant grind rather than rhythmic sounds.
    Any thoughts?
  9. Jul 18, 2024 at 6:33 PM
    Herschel
    Ben
    Utah
    I have an automatic transmission with J shift T-Case. Any way I can test or isolate the noise my configuration? Even though I found a lot of sound coming from my rear wheels I still have suspision about the T-Case.
  10. Jul 18, 2024 at 6:47 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Rear wheel bearings seemingly can fail and present with many different symptoms on these trucks, according to many reports on this website. For example mine never grinded either, but rather clunked whenever I turned the truck. Based upon that noise your driver side wheel is making, I think it is going to be your rear wheel bearing.
    By the way, that directional microphone gadget is really awesome.
  11. Jul 18, 2024 at 8:20 PM
    Herschel
    Ben
    Utah
    Thanks so much for the info! I’ll have to get it checked out formally by someone because I don’t have the skill set myself to self diagnose further than my own experiments.
    Thanks! I’m a professional videographer so I just had it laying around :) came in handy for this exact purpose :cheers:
  12. Jan 1, 2025 at 8:15 PM
    Zork
    Zork Well-Known Member
    CA / KY
    04 PreRunner V6 D-Cab
    Alpine CDA-9885
    Did you get this figured out?
  13. Jan 6, 2025 at 4:23 AM
    TRoss1
    TRoss1 Member
    Maybe I missed it but does you rig have a rear drive shaft center bearing? If so, check that.
