Rooftop Tent Setup (Bed Rack and Cab Rack)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pasha, Aug 22, 2023.
  1. Aug 22, 2023 at 11:59 AM
    pasha
    pasha [OP] Active Member
    Pasha
    2023 Tacoma TRD Off-Road
    Hey guys
    Looking to get a full size ikamper 3.0 in the future, which is 83” long. I have a long bed with an xtrusion bed rack that sits level with my prinsu cab rack.
    If i wanted to mount the RTT from the furthest cross bar on the bed rack, it would hang over 2 cross bars on my prinsu rack.
    That being said, could i mount it onto both the prinsu cab rack and bed rack? My worry is bed flex off road… So: if i wanted to give the bed some room to flex, how much higher above the cab rack should it sit? 1 inch, 2 inches? Or would that not be a problem, therefore allowing me to mount on both racks…
    Thanks
  2. Aug 22, 2023 at 1:43 PM
    BlarBlarjosh
    BlarBlarjosh Well-Known Member
    Josh
    Southern California
    Bed and cab aren't supposed to be attached so things can flex and twist, don't attach it to both. My GFC overhangs my roof rack by a couple inches so I'd guess that 2" gap would be "safeish".
    If you play settlers when out camping let me know where to meet you.
  3. Aug 22, 2023 at 2:26 PM
    Tucker2020!
    Tucker2020! Well-Known Member
    Do not mount to both, let it hang at least 2" above the cab.
  4. Aug 23, 2023 at 5:55 PM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    Don't mount it to both. You can either cut your rack, buy the half rack for an alu-cab that Prinsu sells, or remove the rack since you won't be left with much usable space in front of the tent anyway. Or what you could do is buy the tent feet Prinsu sells to raise the tent 1" above the rack it is sitting on. That should probably give you enough space for flex.
    https://prinsu.com/product/1-tent-mounting-feet/
