Roof Rack Questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LtTaco, Oct 22, 2015.
  1. Oct 27, 2015 at 9:00 PM
    mojavejohn
    mojavejohn Well-Known Member
    Mojave Desert, Ca
    2018 Dbl. Cab Off Road MT
    ditto, on the pics of the Front Runner. That's what I think that I'm gonna get too.
  2. Nov 6, 2015 at 12:27 PM
    ragincajun35
    ragincajun35 Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    the factory roof rack is pretty much for looks and light duty applications.... if you want a solid utility roof rack i would recommend Prinsu, Baja racks, or front runner. I have the front runner and love it.
    Corneeeeelius and mojavejohn like this.
  3. Feb 19, 2016 at 10:55 AM
    ryank817
    ryank817 Member
    2016 MGM TRD OR DCSB
    Can anyone confirm the ACTUAL weight limit for the factory rack? I see 75 lb on some sites, 100 on others, obviously a significant difference if you're getting it to transport two 45 lb kayaks. I'd really prefer the Baja Rack, but I gotta take the cheap route on this one, plus i like that these bars fold back to help cut down on wind noise.
  4. Feb 19, 2016 at 3:58 PM
    Archtaan
    Archtaan Well-Known Member
    2016 MGM Tacoma DCOR
    I can confirm the max weight on the factory roof rack system is 100 pounds evenly distributed. It is marked right on the bars of mine.
    One thing to be aware of is the factory shark fin for the nav/sat sits right at the end of the roof and behind the cross bar so you will need to angle your kayaks more to avoid it (or make sure you stay offcenter)
    ryank817[QUOTED] likes this.
  5. Feb 19, 2016 at 4:10 PM
    nwAdamR
    nwAdamR Well-Known Member
    Adam
    SW PDX
    2016 Tacoma TRD OR LB AT MGM
    How do you like your Front Runners? And did you purchase directly from their website? I'm about to pull the trigger on these. And any more info on how you installed your antenna on there? I had the same idea.
    ragincajun35[QUOTED] likes this.
  6. Feb 19, 2016 at 10:12 PM
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    I love the front runner racks. They are super modular and extremely strong. The antenna actually ended up getting moved down because I didn't like how high it was. Constantly hitting it on stuff. Also had trouble getting the rack to act as a ground plane for some reason. Good luck with the rack. You won't be disappointed.
    sbmon likes this.
  7. Feb 22, 2016 at 6:20 AM
    rmcabee
    rmcabee Well-Known Member
    Fernandina Beach, FL
    16 Tacoma TRD 4x4 Off Road :: Silver Sky Metallic
    I had the factory rack installed before I took delivery. Looks good, and like stated earlier is very quiet in the "closed" position. Within the first few weeks I took a road trip with a 10' longboard (surf). Within the first 10 miles at highway speed (70mph) and wind shear from a few semis, the front crossbar started to come out of the locked position. Luckily, I had used a third strap over the middle of the board which held it in place. I had to pull over and relo the board into the bed and use the bed extender. I see some people say they will use the factory rack for kayaks, which I guess at lower speeds on non-highway roads might be OK. However, I will only use the factory rack for very light use and short distances. Looking at upgrading to a Prinsu.
  8. Feb 22, 2016 at 6:47 AM
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Roof racks regardless of which one you get are awesome to have. I find the longer i have mine the more i use it. Cheers
  9. Feb 22, 2016 at 10:48 AM
    sbmon
    sbmon Well-Known Member
    I am confused the frontrunner website says the rack is compatible with the rear antenna. Are you saying you had to move (relocate) the antenna to mount the rack system on the cab? I am asking in relation to a Gen3 if that matters?
    Thank you
  10. Feb 22, 2016 at 12:36 PM
    nwAdamR
    Adam
    SW PDX
    He's referring to the CB antenna he originally mounted onto his Front Runner.
    sbmon[QUOTED] likes this.
  11. Mar 5, 2016 at 6:29 AM
    1st-Tacoma_2016
    1st-Tacoma_2016 Active Member
    Mark
    Dallas Ft. Worth area
    2017 SR5 Double Cab, 4x4
    A.R.E. Bed cap
    Great set up!!!!
  12. Mar 5, 2016 at 6:39 AM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Hey, Ragincajun, how big is your awning and what type is it? Thanks.
  13. Mar 5, 2016 at 6:41 AM
    oldtoyotaguy
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Also, I was wondering about noise from the Front Runner racks?
  14. Mar 5, 2016 at 6:53 AM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    Double cab only
    idahbro[QUOTED] likes this.
  15. Mar 5, 2016 at 7:02 AM
    #35
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    It is a CVT and it think it is 78" long
  16. Mar 5, 2016 at 10:14 AM
    #36
    cowboy808
    cowboy808 Well-Known Member
    will the smallest ARB awning fit on the factory rack? hope so ....went with it for looks and hoped to use it for that
  17. Mar 5, 2016 at 1:04 PM
    #37
    oldtoyotaguy
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    I'm trying to decide between the 55" and the 79". Decisions, decisions. ARB, Front Runner and CVT make basically the same one. I guess function will win over aesthetics. What good is the small one? It needs to big enough for a couple of people to fit under!
  18. Mar 5, 2016 at 1:11 PM
    #38
    Sbpark
    Sbpark Well-Known Member
    2017 Subaru Outback 2.5i Limited
    I have it and like it for carrying my SUP. I installed it myself after I bought the truck.
    Kila, Jessrin, mattbookpro and 4 others like this.
  19. Mar 5, 2016 at 3:20 PM
    #39
    oldtoyotaguy
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Looks great! I think I'm going with OEM as well. I like the look when it's not in use, and I only need to carry a canoe and an awning.
  20. Mar 5, 2016 at 4:14 PM
    #40
    Faheygf87
    Faheygf87 Well-Known Member
    2016 Blue TRD Off Road MT
    So i'm in the process of finding my perfect taco(4 door, 4wd, V6, TRD O-R, Manual, any color other then red or quicksand, with no options). As it turns out, its not a very common configuration.
    Anyhow, I finally found one that is close enough(has a roof rack and a bed step). Neither my wife nor I like the roof rack, does anybody know how hard it is to remove and put back the, i'm assuming) rubber strips?
