Roof Rack (OEM) with Off Road Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yarro, Dec 30, 2013.
  1. Dec 30, 2013 at 11:24 PM
    yarro
    yarro [OP] Well-Known Member
    Tacoma, WA
    11' TRD Off Road DCSB
    TREX Eyelids. RIGID Fogs Toyota Skid Plate. AVID Light Bar. Rigid SR 20"Combo LED bar OEM Toyota Running Boards, LEER Canopy RIGID Roof Rack - COMPLETE. FJ cruiser Switch panel install in center isle. (4 new slots for OEM switches) Glove box & Center counsel Lighting with amber switch.
    Hey guys, im thinking about putting on some off-road lights, or LEDS on the top of my roof rack, but I want to use it in conjunction with my current OEM Roof Rack I have on now. I know I've seen a picture on TW here somewhere with that setup. I cant remember who had it and how they did it. anyone come across that and or can throw in some info to help me.
    and is this even possible without getting a Baja rack or something ?
    Thanks
  2. Dec 31, 2013 at 4:08 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    What you can do is get a single Yakima bar that clip on the factory rack and modify some lights to mount on there. That way it's removable in case you need the factory rack for hauling.
  3. Dec 31, 2013 at 5:26 AM
    JpAdct
    JpAdct Well-Known Member
    PB County, FL
    2003 Tacoma ExtCab
    I have seen these with a light bar run through the middle. Looks pretty good. Check into something like Rigid Industries or a similar LED light bar mount.
  4. Dec 31, 2013 at 5:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Check out Sierra Expeditions. They have been messing with a roof mount for a large LED light bar. I'm not sure if it can be used with the factory roof rack but it uses the same mounts so with the ingenuity, I'm sure you could get it done.
  5. Dec 31, 2013 at 7:09 AM
    madscientistmike
    madscientistmike Active Member
    Vancouver WA
    2010 TRD sport tacoma
    horrible iphone picture because of the sun glare but you'll get the point. 40" bar mounted between the factory rack. Built two brackets that bolted to the factory rack in the front so the rack is still usable.
    383A07EA-5EC0-486D-84C8-7BE37698C316_zps_d6bffa480d491c7cb7955ae1a85a1ecc8d2c06da.jpg
  6. Jan 1, 2014 at 4:41 PM
    yarro
    Tacoma, WA
    Thank You all for your info, I can now start looking at those options. YOU GUYS ARE GREAT?? THANKS
    If anyone else comes up with more info please add to this forum
  7. Mar 16, 2015 at 9:46 AM
    nbhooker
    nbhooker Member
    Nat
    Memphis
    2014 4x4 crew
    Road armor stealth winch bumper and pro comp explorer LEDs
    i can't figure out how to make or get mounts. I have wanted to put my 40 inch on my oem rack so any help is greatly appreciated!
  8. Mar 16, 2015 at 5:16 PM
    Tovar28
    Tovar28 Well-Known Member
    David
    Chino,California
    05 prerunner TRD sport
    bilstien 5100s in front @ 1.75 bilstien 5160 in rear,general HD 4 leaf pack, 20% tint in front 5% rear, 40 inch led bar ,Kc daylighters , Aries bully bar , aries side steps ,black housing headlights ,factory roof racks ,snugtop camper shell, plastidip rims, bfg ko2 tires
