Roof rack mounted jerry cans forward or rearward?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dansnare, Feb 6, 2017.
  1. Feb 6, 2017 at 2:28 PM
    Dansnare
    Dansnare [OP] Well-Known Member
    2013 T/X Baja
    So if you were mounting jerry cans of gasoline on a roof rack, does anyone think it makes a difference whether they are mounted up at the front of the rack vs. toward the rear of the rack? I've seen it both ways.
    Thanks.
    Dan
  2. Feb 6, 2017 at 2:31 PM
    ROCdermody
    ROCdermody Well-Known Member
    '16 Quicksand DCSB TRD OR
    I've always been a fan of moving everything as far forward as possible to minimize potential movement under hard braking. Accidents are a whole different animal, I'm not sure you can plan for that.
    I have no idea how sound my thought is, though, it just seems right.
  3. Feb 6, 2017 at 4:34 PM
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    I'd put them wherever it's easiest to lift them up and take them down, probably over a door opening so you could stand on the door sill. A full 20L NATO can isn't exactly light or easy to maneuver. Smaller cans can still be heavy/awkward if you're balancing trying to get them off the roof. I'd personally skip the Larry of Arabia look and put 'em in the bed if it were me, but I'm not a big fan of roof racks.
  4. Feb 6, 2017 at 4:37 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Back so you can stand in the bed to mount / remove them
    ItalynStylion likes this.
  5. Feb 6, 2017 at 4:40 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Doesn't sound practical to put cans of gasoline on top of your cab. For 1 they are exposed more to direct sunlight and 2 rolling over would be bad as well.
    Naveronski and joeyv141 like this.
  6. Feb 6, 2017 at 4:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    I think I'd pick something lighter and less volatile to carry on the roof rack, and secure the boom juice somewhere in the bed that has least risk of movement or impact in any type of accident.
  7. Feb 6, 2017 at 4:48 PM
    OZ-T
    Peter North
    British Columbia
  8. Feb 6, 2017 at 7:05 PM
    Dansnare
    2013 T/X Baja
    I guess I forgot to mention that I have a cap on the bed, so mounting cans in the bed and standing in the bed don't work.
  9. Feb 6, 2017 at 7:07 PM
    Dansnare
    2013 T/X Baja
  10. Feb 6, 2017 at 7:09 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I have a cap, jerry cans still go in the bed.
    Trying to get them up/down from my roof rack would just be silly.
    I can carry up to 15 gal fuel and 10 gal water. That much weight on top of the truck would also be silly.
    TashcomerTexas likes this.
  11. Feb 6, 2017 at 7:44 PM
    OZ-T
    Peter North
    British Columbia
    I have a cap and put a couple hundred pounds of lumber up top , not silly
  12. Feb 6, 2017 at 7:46 PM
    Naveronski
    Fort Worth
    And you wheel with several hundred pounds of lumber up top? That's silly too.
  13. Feb 6, 2017 at 7:51 PM
    OZ-T
    Peter North
    British Columbia
    The weight isn't a big deal , especially if you are talking 60lbs for a couple jerry cans , the issue is the mounting dismounting them
