Roof Rack Leak?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AM_Taco, Mar 14, 2022.
  1. Mar 14, 2022 at 3:31 PM
    AM_Taco
    AM_Taco [OP] Well-Known Member
    2020 Tacoma TRD Off-Road
    Hi all. So about a year and a half ago I installed a roof rack on my 2020 tacoma. I siliconed the bolts and around the bolts when I installed it too. Recently I noticed some water on the floor of my passenger side on the floor mats after the the dealership washed it for me. Its not the first time ive seen water on the floor mats, happens every now and then after rain. Im guessing it has to do with water making it in through the roof rack mounting points. However, when I feel around headliner nothings wet. I cant seem to find where its infiltrating from. When I noticed it on my passenger side the other day i also saw some wet spots by the door hinge inside where the door normally covers. Im starting to wonder if the water makes it through the bolt holes on top and runs down the frame above the door and infiltrates from there? Whats your guys' opinion, you think it from the roof rack or potentially somewhere else?
  2. Mar 14, 2022 at 3:50 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Could roof rack, silicone is not good for that, application. Butyl is better. Also could be plugged drains under wiper cowl.
  3. Mar 14, 2022 at 4:05 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Do you have a sunroof?
  4. Mar 15, 2022 at 9:30 AM
    AM_Taco
    No Sunroof
  5. Mar 15, 2022 at 9:47 AM
    bonifacio_629
    bonifacio_629 Well-Known Member
    Walther
    Virginia
    2018 Tacoma TRD Sport, 6MT 4x4 DCSB, Inferno
    Predator steps, TRD cat-back, lots of orange stickers.
    Yep, I went through this two weeks ago.
    I installed a Toyota OEM rack on my truck back in 2019. Got it for the low price of free. The guy stripped the hell out of the hardware and the bolts are made out of unobtainium, you can't find replacements anywhere. Got it as tight as I could. My waterproofing efforts apparently didn't cut it. I first noticed the dome light wasn't coming on when I opened the back driver's side door. I had the little button on the door jamb replaced under warranty, took the driver's side off, resealed, reinstalled, send it. Now the hardware is effed, it's never coming off after a third install. A couple times I noticed moisture on the top left corner of the headliner, but it only happened when I parked with the nose uphill, so it couldn't be the roof rack again, right? Anyway my temporary solution was to back into the driveway, no issues since.
    Week before last I brought it in for the 3rd brake light recall. They performed a leak test and determined a. the brake light's fine, b. the roof rack on the passenger side was leaking like hell and the bolts had worked their way out. Crap. They pulled up the carpet and padding and found a bad case of mold under the passenger footwell. Craaaaaap. They handed me a $7,000 estimate to replace the entire carpet, padding and sound deadening kit, and oh-by-the-way, it's all backordered.
    I had them show me the damage before they out all the trim pieces back. Ordered and had them install a new factory roof rack. Had to break the old one off. The new one is tight.
    The good news is that it's contained to one spot. The good news is that it's cleanable. It's all underneath everything; I never saw or smelled any signs of mold, no windows fogging up indicating moisture, nothing. When the weather gets warm and once The Pollening is over, I'll be hiring my mobile detailer friend, removing the seats and the entire carpet, and deleting all traces of mold. While I'm in there I'll be installing some Noico sound deadening mat.
    Moral of the story, buy once cry once.
  6. Mar 15, 2022 at 1:23 PM
    AM_Taco
    Looks like I need to take the rack off and check the bolt holes again i guess. Ill either silicone the shit out of it or try butyl maybe. I have an aftermarket roof rack not an OEM. Still havent seen any water or moisture or anything like in the headliner. It seems to be all coming in from around the footwell area, as if it following the frame above the door and leaks in from there. I did once find water in the back seat on the floor mat really randomly, no rain no car wash no spilled water botttles or anything. One day it wasnt there the next it was just randomly there and a lot of it. Headliner didnt feel wet or any other area. Still a mystery to me. I just wanna get ahead of this before I end up with mold or a bad headliner or something.
  7. Mar 20, 2022 at 5:14 PM
    TacoVErmont30
    TacoVErmont30 Well-Known Member
    2021 DCLB OR
    I just siliconed mine and had no issues. I really went to town with it however
  8. Mar 20, 2022 at 5:19 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
  9. Mar 20, 2022 at 5:38 PM
    GOROAM
    GOROAM Where can I get Raptor lights?
    19 TRDOR
    Crawling Malls
    RTV silicone works just fine and has worked just fine without issues for thousands of people…
  10. Mar 20, 2022 at 8:39 PM
    Lenny Dykstradamus
    Lenny Dykstradamus Well-Known Member
    Lenny
    New York City
    Tacoma Warthog
    OP you are correct
  11. Mar 23, 2022 at 11:17 AM
    AM_Taco
    Thanks guys. Something im seeing now is when I park on a driveway water ends up on my backrow floor mats. Starting to think theres water just hanging out in the frame which explains the random water when it hasnt rained. Im going to look at that thread and probably take off the rack and silicone the hell out of everything this weekend.
  12. Mar 23, 2022 at 4:32 PM
    craig007
    craig007 New Member
    2018 Toyota tacoma Trd sport
    hey just been reading some of these replies and I believe I may have a leaking oem roof rack on 2018 trd sport probably been happening for awhile cause truck had a bit of a musty smell since bought, but the other night after after a rain got in my truck to go to the store, put seat belt on and it was soaked, so I took the scuff plate off on the drivers side rear door and the sound deadening material under the carpet is drenched so I guess I will have to take truck all apart now to remove carpet and sound deadening material to see how much mold is there and also take roof racks off and reseal and check the bolts for tightness, and also the sunroof drains thanks in advance for the info
