Roof rack awning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dallas05taco, Apr 27, 2020.
  1. Apr 12, 2023 at 6:44 PM
    #81
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  2. Apr 12, 2023 at 6:45 PM
    #82
    OnHartung'sRoad
    You don’t have to worry about the bolt heads, it will just tighten up against them.
  3. Apr 12, 2023 at 7:57 PM
    #83
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Your fastening location should be solid not a void. That does nothing but open up the possibility for flex to occur making it much easier for the bolt to lossen up or even worse making another spot for a rattle to pop up.
  4. Apr 12, 2023 at 8:30 PM
    #84
    OnHartung'sRoad
    Naw, not true- it just has 6-points to rest against, those t-bar bolts aren’t going anywhere. Mine has been mounted for three years now, many miles on washboard roads and it stays snug as the day I mounted it. Use nuts with nylon lock threads. If you are concerned, get a spacers. Rubber sheeting with double stick tape may help, but it’a not really needed. One thing about rubber spacers is they will help protect the powder coat on the rack, direct mounting like I did may mess it up but I keep the awning permanently mounted anyways.
  5. Apr 13, 2023 at 7:30 AM
    #85
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    OVS 270 Awning here. Custom mounts on my bed rack.
  6. Apr 13, 2023 at 9:03 AM
    #86
    BlarBlarjosh
    BlarBlarjosh Well-Known Member
    Josh
    Southern California
    Are there any cheaper solutions for a free standing awning similar to the Kammok? At their price point I'd be inclined to go with a 270 but I like the idea of a standard 6ish foot awning to keep things a bit more light weight.
  7. Apr 13, 2023 at 9:15 AM
    #87
    Tronfunkblow
    Tronfunkblow Well-Known Member
    California
    2017 DCLB TRD OFF-ROAD 4x4
    MT64s, Icon RXT Leaf Springs, Topo Topper
    This things a beauty.
    shaggy135[QUOTED] likes this.
  8. Apr 13, 2023 at 4:10 PM
    #88
    Stephen1988
    Stephen1988 Well-Known Member
    Stephen
    Snoqualmie Valley, WA
    2016 TRD Off Road
    TRD Pro Grille Cali Raised Ditch Lights BFG KO2 E-load Bed Molle Board ARB single compressor KB Voodoo 10" Rack Smittybilt Overlander Gen2 Tent SSO Slimline Bumper Warn VR Evo 10-S
    New OVS Nomatic 270 LTE awning, also custom homemade brackets similar to @shaggy135. Much lighter and more affordable than most with the tradeoff of slightly less coverage but still adequate.
    -Rorschach- and shaggy135 like this.
  9. Apr 13, 2023 at 5:25 PM
    #89
    shaggy135
    What did you come up with for a mount? Looks like you have the same rack too, haha.
  10. Apr 13, 2023 at 6:11 PM
    #90
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    6C7314EB-7F3D-4518-B421-71C99F4B3B84.jpg Lovin’ mine. Not shown is my windy day hack. I put the legs into 5gal buckets filled with sand and bungee the bucket handles to the awning arms, rock solid.
  11. Apr 18, 2023 at 10:22 AM
    #91
    Stephen1988
    Stephen
    2016 TRD Off Road
    I purchased the standard awning bracket from KB Voodoo because it has the right angle and that one was cheap, then I just bought a 3” strip of steel from Home Depot and drilled some holes and slots and painted it to match. Basically used it as an extension to gain some height.
  12. Apr 18, 2023 at 11:07 AM
    #92
    shaggy135
    Thats pretty slick. I also used KB's awning brackets but I felt like I needed something a little heavier duty due to the weight, so I used some 14" countertop support backets and drilled some extra holes. Probably overkill but my awning does weigh 80 lbs, ha.
    Stephen1988[QUOTED] likes this.
  13. Apr 18, 2023 at 11:34 AM
    #93
    Veet-88
    Got mine mounted off the side of the prinsu this weekend. Built 3 spacers to keep it off the bolt heads drilled some lower mounting holes thing is solid. Really close to the roof I'll have to monitor for signs of rubbing from the cover. Might be worth tossing some 3m on it sooner than later.
    Pro to going this way over using mounts it sits tight and at a good height. And I didn't have to adjust my roof boxes at all.
    Stephen1988 likes this.
  14. Apr 18, 2023 at 11:46 AM
    #94
    Stephen1988
    Stephen
    2016 TRD Off Road
    Yeah I like your thinking, the dynamic weight wont be as much of a concern with that. We were pretty intentional about weight so when we saw this 270 awning under 50lbs we decided that was the one we wanted, haha.
  15. Apr 18, 2023 at 11:47 AM
    #95
    Tronfunkblow
    California
    Planning on getting a prinsu soon. I currently have the slim shady, do you still use the clamp inserts? I needed additional inserts to mount to my Yakima bars
  16. Apr 18, 2023 at 12:59 PM
    #96
    NWTacoTime
    NWTacoTime Well-Known Member
    Nate
    WA - Seattle/Kent
    Cement SB 2019 TRD offroad -
    Car Seats
    I sold the awning, but i just used the standard clamps on the awning and clamped them to the crossbars on the prinsu - fit perfectly
    Tronfunkblow[QUOTED] likes this.
  17. May 23, 2023 at 11:09 AM
    #97
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I have the kammok crossing awning .. it's pretty sweet20230521_114346.jpg 20230516_195423.jpg 20230516_195434.jpg
  18. May 23, 2023 at 11:11 AM
    #98
    BlarBlarjosh
    Josh
    Southern California
    Looks awesome, I really want one but for the price I feel like I should get a 270.
  19. May 23, 2023 at 2:10 PM
    #99
    Jeffvt0508
    Jeff
    Anderson, SC
    I thought about it but I can't use a 270 with my ikamper 3.0 mini. It would hinder me fron getting into the tent
  20. May 23, 2023 at 2:11 PM
    #100
    BlarBlarjosh
    Josh
    Southern California
    This seems like a great choice. Might just get it instead of a 270 anyway.
    Jeffvt0508[QUOTED] likes this.
