Roof Damage: Need Advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PaulK, Jun 16, 2015.
  1. Jun 16, 2015 at 5:45 AM
    PaulK
    PaulK [OP] Life is hard. It's harder if you're stupid.
    Paul
    Dublin, OH (but still a Pittsburgh guy)
    2013 Black Baja Access Cab
    Some dickhead walked on the roof of my Taco while it was in a parking lot, and I'm not sure what to do about it. I pulled the big dents out with a suction cup, but the roof is still obviously damaged. Insurance will cover everything so this is not a money issue, but the body shops don't think that they can get the existing metal straight. Two estimates went right to cutting out the factory roof and welding in a new one. The insurance adjuster has advised against this, and I agree. They are working with me to try to encourage a shop to try to repair the factory roof before just cutting it away. Another option would be to not fix anything - a bummer on a 2 year old truck - and instead bolt on a roof rack to hide the damage. This is an access cab 2013, so a roof rack would require drilling - also something that makes me uncomfortable - and would need to be a basket style rack to hide everything (not just cut-down factory rails).
    I need some opinions and perhaps some ideas regarding a rack vendor.
    Thanks.
  2. Jun 16, 2015 at 6:06 AM
    wesplains
    wesplains Well-Known Member
    West
    Middle of USA
    Tacoma TRD Sport
    SnugTop, Aries Stealth Bull Bar, OEM Bed Mat, Wet Okole Seat Covers, Husky Floor Mats, OEM Cab Rack, Amp Bed Extender, VooDoo Bad Brackets with Cargo Basket. Yakima racks on cover. MagnaFlow Muffler, KC Running Lights, Console Vault, Dash Cam, Side Moldings, UltraGauge
    Wow sorry that happen. If it was me I would be leaning towards the roof basket fix. Take the pay off from insurance company and put the rest aside if the roof rack fix does not work for you. I based this on the quality or rather the lack of it from shops these days.
  3. Jun 16, 2015 at 6:19 AM
    Pigpen
    Dan
    Northwest Montana
    I'd do a Baja Flat Rack.
    People from Ohio are assholes... I'm one of them :D
  4. Jun 16, 2015 at 6:28 AM
    PaulK
    Paul
    I like the looks of the Baja Racks, but my truck is an access cab without factory threaded inserts. I need something sized for an ACLB, and I'll have to drill my own holes.
    I moved here for my job 20 years ago. Too flat.
  5. Jun 16, 2015 at 6:52 AM
    4.0 TEQ
    4.0 TEQ Well-Known Member
    3 WORDS>>> New Body Shop
  6. Jun 16, 2015 at 6:57 AM
    Pigpen
    Dan
    Northwest Montana
    No matter what you do, you're going to have to drill with a quality rack as an access cab owner. I went Yakima and my roof is fucked (abuse on my part). I wish I had done it right.
    Yakima or Thule with a basket cost as much as Prinsu and Baja...
  7. Jun 16, 2015 at 10:30 AM
    CroResident
    CroResident Well-Known Member
    Nick B
    Opelousas, Louisiana
    2015 4X4 DCSB
    6" Zone lift 35x12.50 Super Swampers
    ^^yes
  8. Jun 16, 2015 at 10:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    Find a competent body shop. Those two sound a bit weak in the metal massage skills. Granted, it is thin metal and in an odd working position, but it's not impossible to deal with either.
    Be glad you have a cooperative insurance adjuster.
    Those are my opinions, as you requested.
    If there is a shop in your area that does restorations or hot rod builds (high end metal, not plastic stuff) you might find a good metal man there.
    If you have any local gatherings of street rods, hot rods, muscle cars, etc., that's a good place to go, look, compliment, and ask for references.
  9. Jun 16, 2015 at 11:43 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    new roof means new windshield and a lot of bondo when they weld and grind
    the new roof on....pass on that
    it must be fixable
  10. Jun 16, 2015 at 11:48 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    This is lame. Who the f*** walks on somebodys vehicles roof? If i saw somebody on my truck, things would get real ugly fast.
  11. Jun 16, 2015 at 11:57 AM
    dcaplan
    dcaplan Well-Known Member
    Drew
    Fergus, ON
    2020 4Runner Venture
    Maybe it would be a good time to install a sunroof?
  12. Jun 16, 2015 at 12:24 PM
    PaulK
    Paul
    What do you mean your roof is fucked? What happened, and what would you have done different?
    Has anyone had experience with the Prinsu Accessrac: http://www.prinsudesignstudio.com/#!2nd-gen-tt-accessrac/c1lq1
    Any other builders that make racks for access cabs out there?
  13. Jun 16, 2015 at 12:28 PM
    munkiemec
    munkiemec Well-Known Member
    That.
    I've seen good body shops take out a whole-car-length sideswipe sans-bondo.
  14. Jun 16, 2015 at 12:39 PM
    taco206
    taco206 Well-Known Member
    Post some pics. I have experience in roof/body repair and I can get some others to check it out and see if you need to get to another shop. Sounds like you do. Good luck.
  15. Jun 16, 2015 at 12:44 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    As far as I know we are the only ones who make a roof rack specifically designed for your access cab. I think front runner did a cut down version for All-Pro's "Brownie" build but thats about it. There are a handful of people who have installed the accessrac on their truck. I can't speak for everyone but if I were to ask anyone specifically about their experience it would be NYCO. He installed his and it has been in constant use on some pretty awesome trails since spring.
  16. Jun 16, 2015 at 3:51 PM
    Pigpen
    Dan
    Northwest Montana
    I had my 90+ pound 17' canoe up there, and didn't have it supported past the cab. I may have tied it too tight to the rear of the truck and proceeded to drive at high speed down a really bad dirt road.
  17. Jun 16, 2015 at 3:59 PM
    Andre D
    Andre D Member
    Andre
    Ontario, Canada
    TRD Sport Blue Ribbon metallic
    Paintless dent repair, especially if the paint isn't cracked.
    Sorry about your truck. There are people that don't have respect for anyone or anything.
    DouginNC likes this.
  18. Jun 16, 2015 at 4:06 PM
    theboy12
    theboy12 The Answer is 42, But What is the Question?
    Jon
    Redding, CA
    2005 Tacoma TRD Sport DCLB
    King 2.5 Remote Resi'sand rear 2.0s, Dakar Pack, TRD 1st Gen air intake, Stealth 6's wraped in DynaPro ATms 285/70R17s, SnugTop, ALL Pro Front bumper, Brute Fab HC Rear Bumper, Hella Black Magic Lights, Bedslide 1000
    Love my Prinsu rack. I have a double cab. Wouldn't think twice about buying it again. That said I work with emotionally disturbed student's and I had a student jump up on my truck and try to cave the roof in. We hauled him down and the roof sustained a few small dents. and a foot dent I popped out. I put the rack on a week a later and have not looked back.
    Now ask me about the 4k in damage to a coworker's Honda with a sunroof...
    My two cents,
    -Jon
  19. Jun 16, 2015 at 4:50 PM
    PaulK
    Paul
    I'm going to have the Dent Doctor come over for a free estimate. We'll see. I'm going to try a couple more shops too. Regardless, no new roof. Either they try to fix it without removing the factory roof or I go with the roof rack option.
  20. Jun 16, 2015 at 7:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't know why everyone is so afraid of cutting and installing a new roof. Sometimes that is the answer. A good body shop can do it with a minimum of bondo on the weld seams and you would never know it without removing the head liner or grinding off the paint. I have seen cars cut cut in half and you couldn't tell.
