Roller Fairlead or Hawse?
Discussion in 'Recovery' started by Comatose, Jan 8, 2018.
  1. Jan 8, 2018 at 1:06 PM
    Comatose
    Comatose [OP] You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    I have steel wire and have read mixed reviews. Will a hawse cause damage to the cable or will the cable just cause damage to the hawse? Should I just stick with the roller fairlead?
  2. Jan 8, 2018 at 8:35 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    Steel cable stick with the roller.
    Naveronski and RogueTRD like this.
  3. Jan 8, 2018 at 9:26 PM
    Ridgeline001
    Ridgeline001 Well-Known Member
    Oregon
    2014 DCLB Sport 4wd
    Roller only with steel as been stated.
    Marbleyard and RogueTRD like this.
  4. Jan 9, 2018 at 7:39 AM
    ted44
    ted44 Member
    A roller fairlead is, in general, a better choice regardless of steel or synthetic. Make sure your rollers can actually roll freely. Less friction and a larger radius to bend around in the event of an off-center pull.
  5. Feb 17, 2018 at 12:39 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Roller best choicewith steel cable.
    Do NOT use roller with synthetic. Will eventually pinch where vert roller meets horizontal. Instant death to cable.
  6. Feb 18, 2018 at 8:05 AM
    ted44
    ted44 Member
    Roller fairlead is superior for synthetic. Larger radius and less friction. After participating in 100s (seriously) of winching operations, I have NEVER seen the line pinch between rollers. This is a myth. Bill Burke of BB4WA also recommends rollers over hawse.
  7. Feb 18, 2018 at 8:54 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    NOT a myth.....it's a FACT. I've spooled new winch cables for a number of friends that destroyed synthetic lines. Warn (the winch people) caution people NOT to make that FOOLISH mistake.
    I've owned winches for over 45 years, used them myself thousands of times and personally witnessed synthetic lines jamb in roller fairleads. Bad advice to use them with synthetic lines.
  8. Feb 18, 2018 at 8:58 AM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
