Roll-starting with a bad Alternator? (manual trans)
Discussion in 'Technical Chat' started by x2468, Oct 7, 2013.
  1. Oct 7, 2013 at 9:21 AM
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Will an engine start up and run if it is roll started (manual trans) with a bad alternator? I was always under the impression it would.
  2. Oct 7, 2013 at 9:26 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I thought that was just if the starter was bad. You talking about popping the clutch right?
  3. Oct 7, 2013 at 9:53 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    With a bad alternator you won't get too far before the engine dies, if you have a fully charged battery.
    wilcam47 likes this.
  4. Oct 7, 2013 at 10:47 AM
    x2468
    For some weird reason, I assumed there was a flywheel run stator or something in the engine powering the essential stuff like plugs, ecu, injectors etc. And the alt was just for charging the battery and running accessories. Sucks if that's not the case.
    How long would a vehicle run with a fully charged battery?
  5. Oct 7, 2013 at 10:48 AM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    depends, are you driving at night or during the day?
    id say during the day your driving time will be limited to 2 hours on a fully charged battery.
    night time-30 minutes
  6. Oct 7, 2013 at 11:00 AM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Its called bump starting... You will only be able to drive until your battery dies.. get a new alternator.
    Bump starting only works for long distance driving if you have bad starter or dead battery..
  7. Oct 7, 2013 at 2:26 PM
    x2468
    Actually, it's called bump, roll, or push starting, depending on where you are and what motorsports crowd you're in. They're synonymous. :jerkoff:
  8. Oct 7, 2013 at 2:31 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If the alternator is toes up and you have to roll start it because the battery is now dead you'll be lucky to make it around the block. Other wise just twist the key.
  9. Oct 7, 2013 at 2:33 PM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    Let's just say I got maybe 2 miles on a bad alternator driving at night in my 03 tacoma 6 years ago. Not fun driving, I was on the highway and everything died and luckly I was able to get off the road. No hazards and it was pitch black out, not safe at all.
  10. Jan 12, 2019 at 9:36 AM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    Big ups to jason and david on the rescue!!!!!
  11. Jan 12, 2019 at 9:38 AM
    grubburg
    2019 TRD OR MT
  12. Jan 12, 2019 at 9:39 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    nope, most everything runs off the alternator/battery. If the alternator isnt overproducing/aka charging DC charge it runs off the battery until depleted.
  13. Jan 12, 2019 at 9:42 AM
    grubburg
    2019 TRD OR MT
  14. Jan 12, 2019 at 10:33 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Maybe some people should think about boats perhaps Air Boats
    Once the Voltage in the Battery drops low enough the ECM goes into Hibernation mode to save itself
  15. Jan 14, 2019 at 6:49 AM
    96carboard
    96carboard Well-Known Member
    Here is the thing; if you can't start it due to bad alternator, it means that your battery is already low enough that it won't crank the engine. It may run for a while, but not for too terribly long, and nobody can tell you how long it will run for, since it would be based on a guess about just how dead your battery already is.
    Cars these days have a much larger electricity draw than in the old days. Old cars needed pretty much just SPARK to run. Now you need computers and electric fuel pumps and electric fuel injectors and electric throttle gates and a million electric sensors.
