Rodents chewed up engine harness!
Discussion in 'General Tacoma Talk' started by Max5150, Feb 16, 2024.
  1. Feb 16, 2024 at 7:56 AM
    Max5150
    Max5150 [OP] Well-Known Member
    Mark
    Corpus Christi, Texas
    09 SR5 DC 4x4
    Eibach Springs, Billies set at .85, 2" AAL Audio System: Pioneer AVH-X4600BT, Polk DB 6501, Polk DB 651s, Rockford Fosgate R2SD4-10, Alpine MRP-F320 Amp, Dynamat Sound Dampening
    Damn mice ate through wire loom along passenger side of the engine. They attacked my wife's 4runner's engine harness for the second time in 3 months and its disabled . They built nests and created a cozy bed room. She's pissed and said she's done with Toyota. Doesn't every manufacturer make there electrical wiring out of soy?
  2. Feb 16, 2024 at 8:08 AM
    Robert@KCHiLites
    Robert@KCHiLites Robert Byrd @ KC HiLiTES Vendor
    Robert Byrd
    Flagstaff AZ
    2022 Tacoma
    KCHiLites
    Not sure if it helps but we had this problem in AZ as well. I open my hood every night to prevent them from having a warm place to set up. I also installed an Amazon rodent underhood kit ($15 i think) that's wired to the battery. I was told from my shop that having the engine steamed / detailed is a way to get rid of the scent they leave when set up shop...hope that helps.
  3. Feb 16, 2024 at 8:31 AM
    Max5150
    Mark
    09 SR5 DC 4x4
    Thanks, I'll definitely steam clean the engine. I'm soldering her engine harness wires since insurance took two months to fix it last time. I was also spraying peppermint oil in the engine bay and front wheel wells. Pic of her damage to the engine harness which cost about 2K not including labor.
  4. Feb 16, 2024 at 8:44 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    So, we had it real bad in Mrs Arc's subaru - they got in and stayed pretty bad two years ago. As in living in the headliner, spare area, etc. We'd actually hear them running around, and it massively stained the headliner. She took it out and spent days enzyme treating to get rid of the ugliness.
    With that said, we both park outside next to each other. Had gen1 up to 2013, gen2 2013 to 2023, and now gen 3. I've never had an issue except an errant chipmunk I can see running in and out once in a great while, but no mice. The only difference I can see is that I massively treat the Tacos with fluid film often. I think I did her car once early on (also around 2013) but not since. So I assume most of the ff is gone fro the suby.
    I think I saw someone else also suggesting that maybe ff helps. It may be worth a try to spray around on the suspension, frame, and engine areas a good bit for this problem, as well as just generic rust prevention. We tried the pepermint and dryer sheets with hers, and even have huge bags of mothballs under her car to try to ward off. They have had minimal effect. Something about the ff they don't like? It does have a "unique" odor.....
  5. Feb 16, 2024 at 8:48 AM
    HuskerPaul
    HuskerPaul Well-Known Member
    Kansas
    2022 Lunar Rock Off-Road Access Cab
    I have mouse traps in my garage in hopes to prevent this. A friend of mine who doesn’t have a garage had extensive squirrel damage to his Tundra so he added a motion triggered deterrent device. I’ve seen some on Amazon.
  6. Feb 16, 2024 at 8:49 AM
    4Stents
    4Stents Roost or be Roosted
    Appleton Wisconsin
    2013 White Tacoma SR5 , w/peeling paint.
    Frame recall done
    Maybe Orkin Terminex could help , I know a power sports dealer that almost died from the dropping, not something you want to mess with.
    Good Luck
  7. Feb 16, 2024 at 8:51 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Had it as well over at my parents house. Dads 4Runner wiring harness, moms Outback hardness and a bunch of other stuff, plus they nested on top of her gas tank, then when I left my truck there they got some coolant hoses. Only difference is these were rats.
    Once we found where the little shits were living, out back under a chair cover they put on the patio furniture for winter, they seem to have split. Knock on wood. I probably trapped a dozen of them before that as well.
    During the debacle I found these on Amazon and they actually had an effect. You just have to remember them every night and morning.
    https://www.amazon.com/gp/product/B08L6B87Z5?ie=UTF8
    I wish you luck. It isn't fun.
  8. Feb 16, 2024 at 8:56 AM
    01x4
    Like you, my truck is Fluid Filmed simply because of where I live, and at least for rats, they didn't care. We tried the mothballs under the car as well with no results, same with putting them in a mesh bag under the hood. They're super frustrating little things.
    @Max5150 I'd also suggest a couple traps. I put one at each tire, figuring that's how they were getting up and in. The tunnel style ones worked well for me.
  9. Feb 16, 2024 at 9:17 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    HondaGM and Tacoma Mike like this.
  10. Feb 16, 2024 at 12:37 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    The f'ing squirrels were regularly -- almost daily -- crawling around the engine compartment of my frequently-parked Gen 2. These are the same little bastards that ate the wiring on my 1988 XJ 20+ years ago and my Lexus RX 12+ years ago.
    So I was not happy. I tried an ultrasonic repeller with flashing bright white LEDs from Amazon, and amazingly, after a year there have only been footprints on the engine cover one time. I had one of my Arlo cameras set up in front of the truck early on and one could see the f'ing squirrels run under the truck, look up at the engine, and keep on going.
    I'm kinda surprised, and I don't have a lot of data (although I did get one of those ultrasonic repellers for my Gen 1 too, and so far-so good), but I'm leaning toward the conclusion that these things work.
    The ones I got were indoor use only, but I figured underhood is thisclose to indoor anyway. I have them on the 120V same extension cord as my CTEK battery maintainers, although I see there are similar 12V repellers available.
    Here's mine. These come and go on Amazon, but there are almost certainly many similar versions. I place mine on the power steering reservoir when the truck's parked for several weeks or a month.
    And, BTW, although it's a very popular thing to blame the couple-% by weight of epoxidized soybean oil in some PVC insulation for attracting rodents, my experience and the technical literature discount this. Gravid squirrels and other rodents have been chewing things like wiring for DECADES.
    https://pubs.acs.org/doi/10.1021/acssuschemeng.0c05868
    GilbertOz likes this.
  11. Feb 16, 2024 at 1:08 PM
    Tacoma Mike
    Southern Maine
    tacofish[QUOTED] likes this.
  12. Feb 16, 2024 at 1:11 PM
    01x4
    Do you know if it has a shelf life as far as potency? (I didn't know about this when we had our issues.)
  13. Feb 16, 2024 at 1:17 PM
    4xdog
    Santa Fe, NM
    The capsaicin is encapsulated in the top layer of the tape, so it should be quite durable. I don’t recall a best-by date on the rolls I have or in the technical literature. I’ll check and update this post if there’s new and useful info.
    01x4[QUOTED] likes this.
  14. Feb 16, 2024 at 1:18 PM
    01x4
    Nice, thank you. I'll have to snag some to keep handy.
  15. Feb 16, 2024 at 1:21 PM
    4xdog
    Santa Fe, NM
    It’s pricey stuff! Not the kind of thing to buy just for fun.
    Check online/eBay, etc. vs the dealer — I found some (that I’m pretty sure isn’t counterfeit…) online that was half the price or less compared to the parts counter at my local Honda dealership.
  16. Feb 16, 2024 at 1:21 PM
    Odlcjro01
    Odlcjro01 Well-Known Member
    Lee
    Rhode Island
    2021 Tacoma MGM DBC SR5
    LT265/75R16 tire, side steps
    Had this issue wife's iM. We found 4 condos in the car. Ended up trading car in and installed these on her car and my Gen3 . They are battery operated. But has motion sensors that turn it off while car is moving.
    Loraffe Under Hood Rodent... https://www.amazon.com/dp/B07N6JZ2J4?ref=ppx_pop_mob_ap_share
  17. Feb 16, 2024 at 1:22 PM
    01x4
    Just saw $45 a roll, not cheap, but if it works its worth it. Way cheaper than replacing wiring and hoses.
  18. Feb 16, 2024 at 1:23 PM
    4xdog
    Santa Fe, NM
    A friend in Santa Fe was having a real problem with mice nesting in his RAV4’s engine compartment. He shrouded most of the underhood wiring with braided oversleeving. It looked OEM and solved his problems.
  19. Feb 16, 2024 at 1:28 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Max5150[OP] likes this.
  20. Feb 16, 2024 at 1:57 PM
    Max5150
    Mark
    09 SR5 DC 4x4
    Thanks for all the suggestions. May try wrapping existing wiring loom with the Honda tape. I also purchased some flexible non metallic conduit which is way thicker than OEM loom.I will wrap them with black electrical tape or Honda tape so they look better. I do have four traps around both vehicles and have not caught anything.
