Rocktrix wheels?!?
Discussion in 'Wheels & Tires' started by BoiMeatWonder, Dec 27, 2023.
  1. Dec 27, 2023 at 7:30 PM
    BoiMeatWonder
    BoiMeatWonder [OP] Some idiot with a truck
    Central Florida
    2008 Indigo Ink Tacoma Pre Runner
    -Rocktrix wheels on 33” Arturo mt’s -2.5 level in front, 1.5 rear -Prinsu roof rack with cali raised 40”light bar -MBRP dual exit exhaust -Alpha Rex headlights -Aftermarket grill (forgot what brand) -Sound system
    Just recently found this wheel brand called RockTrix, that make some pretty cheap and good looking rims, there was a few different styles and sizes of each and they fit great on my second gen
    and if your wondering I’m running some Atturo trail blade mud terrain 33/12.5/17
  2. Dec 27, 2023 at 7:41 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Great rim, no problem with them and never had the tire leave the bead when aired down.
  3. Dec 27, 2023 at 8:04 PM
    BoiMeatWonder
    Central Florida
    I was actually considering those wheels too, glad to see those ones also look good
    Mully[QUOTED] likes this.
  4. Feb 6, 2024 at 1:16 PM
    Shane2ndgen
    Shane2ndgen New Member
    Cement Grey 2006 Tacoma
    What is your suspension setup? I have just a 2” front level right now and wanting to get this exact setup, Does it rub at all?
  5. Feb 6, 2024 at 1:27 PM
    BoiMeatWonder
    Central Florida
    It’s got a 2.5 inch puck lift in the front and a 1.25 block in the back and it rubs pretty good. I’ve done a good bit of plastic trimming on it but the worst is on the body mount. 3/4 to full turn on relatively level ground and it rubs. It hasn’t been destroying my tires though, just loud
  6. Feb 6, 2024 at 1:35 PM
    Shane2ndgen
    I have 265’s on there right now and they only rub a little fully turned in reverse. i was wanting to go with a bigger tire but rubbing is kind of annoying, might just run these till they need replaced then go bigger, Love the setup tho it looks perfect
  7. Feb 6, 2024 at 1:49 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I like some of their wheel designs, but I don't like super heavy wheels. That turned me off right away. IIRC a 17x9 from them is something like 29lbs vs my TE's that are 17lbs. I'll take 40+ lbs less rotating weight all day.
    Should be able to get aligned at a proper shop and have them push the caster higher up front to fix this. Unless your offset is like -35 or more you should not rub with a 265. Else a CMC will fix you.
  8. Feb 7, 2024 at 8:56 PM
    EscargotArmy
    EscargotArmy New Member
    2019 Tacoma SR AC
    I just pulled the trigger on some RT111s. Just wondering if anyone had an answer for the TPMS sensors?… Rocktrix says the oem ones aren’t compatible but couldn’t give me any recs for ones that would be.
    They're on the way and hoping to get them on next week so any input is appreciated!
    Having a leveling kit installed as well and putting the wheels on some BFG 265/70s… Hoping the rub won’t be an issue. I’ve seen some people post who’ve said it’s not a problem and then some who’ve had serious rub
  9. Feb 7, 2024 at 9:09 PM
    BoiMeatWonder
    Central Florida
    I believe they should work. The TPMS sensor I am running aren’t the originals but they are OEM Toyota sensors, so in theory they would work
    EscargotArmy[QUOTED] likes this.
  10. Feb 21, 2024 at 4:40 PM
    gnarthirty2
    gnarthirty2 Well-Known Member
    Brandon
    2017 Toyota Tacoma TRD Pro
    Unless your OEM wheels were the peasant spec steelies, your OEM sensors will work just fine. If you have steel OEM wheels, you'll need different sensors.
    Hope that helps!
    Mully likes this.
  11. Feb 24, 2024 at 2:44 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Those look great with the blue!
    RxYoda likes this.
  12. Feb 29, 2024 at 6:58 PM
    BoiMeatWonder
    Central Florida
    Thanks man, I don’t see blue with bronze often so I thought it would look good and unique
  13. May 19, 2024 at 2:58 AM
    RxYoda
    RxYoda Well-Known Member
    Mark
    Florence, SC
    2023 Sport Premium 4x4 DCSB
    Can you give any feedback on these wheels?
    clearance/rubbing?
    Suspension mods required?
    Durability of finish?
    Any problems/regrets?
  14. May 19, 2024 at 4:56 PM
    EscargotArmy
    2019 Tacoma SR AC
    I had mine installed back in Feb. Was going to put in the spacer lifts to help with rubbing but in the end I couldn’t be bothered given the price and knowing I’ll likely just upgrade the suspension when I can anyway…
    No ragrets so far, quality wheels and finish hasn’t changed since I bought them, poke is perfect (I have an 2019 AC SR so no fender flares either) - Get lots of compliments on them. Only slight rubbing on the rear of the fender liner with some K02 265/70s at ~3/4 turn usually in reverse but sometimes forward when at speed. Even then it’s only slightly rubbing and hasn’t caused any issues.
    I ended up using Toyota TPMS sensors and it works just fine!
    Hope that helps!
    6B1D2C43-C081-49A7-9638-97366892CCBC.jpg 1BD68E42-405C-4B96-82B8-30A6E83DF18B.jpg DB8E3847-DC09-49BB-B51C-3FD6FD0DB711.jpg F2F13093-2549-4B60-A31C-D1EC24644D13.jpg
    RockTrixWheels, Mully and RxYoda like this.
  15. May 20, 2024 at 1:47 PM
    gnarthirty2
    Brandon
    Mine have all been great. No mods really required unless you plan on upsizing the tires. I've been through a few sets of them--not because of any issues--but because I have a connection to the company.
    A little birdie told me they're coming out with a machined finish for the Toyota PCD. I can't wait to get my hands on a set.
    RxYoda likes this.
  16. Jun 1, 2024 at 4:35 PM
    BoiMeatWonder
    Central Florida
    It has been about half a year now since I’ve installed them, they have been great
    I don’t do a whole lot of “extreme” off-roading with it being a 2wd, but with a 2.5 puck lift, it has done fairly well
    it rubs on the body mount at full turn but does no damage to the tires, only rubs the finish on the body mount down. So if you actually need the travel, maybe stay away from 33s until you lift it or just in general
    and the finish on the wheels have held up great, when they are clean, they look as good as new
    RxYoda[QUOTED] and Mully like this.
  17. Jun 1, 2024 at 5:31 PM
    RxYoda
    Mark
    Florence, SC
    The bronze looks great with the blue on your truck!
  18. Jun 1, 2024 at 5:47 PM
    BoiMeatWonder
    Central Florida
    Thank you, I took a long time to figure out what colors would look the best with it and the bronze stuck out to me
  19. Jun 1, 2024 at 6:51 PM
    RxYoda
    Mark
    Florence, SC
    I’m looking for unique on celestial silver.
  20. Jun 4, 2024 at 5:47 PM
    bf2junky
    bf2junky Well-Known Member
    West GA
    2021 Super White Tacoma TRD Sport 4x2
    Eibach stage 1 with 275/70 ridge grapplers
