rockstar rims size need help to pick offset
Discussion in 'Wheels & Tires' started by KaliTaco, Jan 18, 2011.
  1. Jan 19, 2011 at 2:24 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    It says 0 offset on the back of the wheel. I do believe i will go with what the wheel has stamped into the back of it.
  2. Jan 19, 2011 at 2:30 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Then if the offset is 0 and the rims are 9" wide, you actually have 5" backspaced wheels, not 4.5 as you said in your earlier post.
    See the chart on this page, 1/3rd of the way down. :thumbsup:
    https://www.rsracing.com/tech-wheel.html
  3. Jan 19, 2011 at 3:13 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I am confused by this a bit too.
    From the Sticky:
    4. Offset. The distance from the centerline of the wheel to the face of the mounting surface of the wheel that contacts the hub.
    4.1 Zero Offset. Indicates the mounting surface is at the wheel center.
    Seems to me that on a 9" wide wheel with 0 offset, the backspacing on that wheel would be 4.5" because 0 offset indicates the face of the mounting surface is at the centerline of the wheel which is half of 9".
  4. Jan 19, 2011 at 3:18 PM
    KaliTaco
    KaliTaco [OP] Well-Known Member
    What problems will I run into? Rubbing against the body mount because I can cut that no problem. And cut the plastic but not into the fender itself. I'm running 17x9 eight now with a 0 offset and 265/70/17 nitto terra without any problems at full lock. I want my rims to stick out a bit. So is it possible or should I get wheel spacers and go with 20x8.5?
  5. Jan 19, 2011 at 3:53 PM
    francis1291
    francis1291 Well-Known Member
    10 4x4 SR5 super white
    3" procomp lift wit 20" rockstars on 33 toyo mt's
    Yes get 20x8.5 when .25 wheel spacer. It will be the best in long run.
  6. Jan 19, 2011 at 4:43 PM
    TexasTacoma37
    The measurements are taken from different places.
    Rim width is measured between the bead seats, not the actual entire width of the rim. Go measure your rims right now. They will be about an inch wider than the true "rim width" that they are spec'd at.
    Backspacing is measured from the outside of the rim, not the bead.
    Therefore, while a 0 offset, 9" wide rim has 4.5" between the rim seat and the bead, it actually has about 5" to the outer edge of the rim.
  7. Jan 19, 2011 at 4:46 PM
    tacoma1923
    tacoma1923 Well-Known Member
    houma, la
    6" procomp,35" toyo mud terrain tires,20" rockstars,halo projecter headlights,floor board lights front and back seats, 3 10" kickers with jbl amp, jensen flip out touch screen
    i have 20x10 with a -24 on 35x12.5s. ive had -12 and had problems with the inside of my tire being eaten out by the tie rod when i would turn all the way
  8. Jan 19, 2011 at 4:48 PM
    tacoma1923
    houma, la
    and dont get spacers. it shortens up your bolts and increases the risk of lugs coming off
  9. Jan 19, 2011 at 5:33 PM
    francis1291
    you can get spacers from wheeladaptor.com that are hub cemetric and longer lugs that are made for toyota...that is what i did and i have not had any probs
  10. Jan 19, 2011 at 5:36 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Wish they made them in 16". I'd have a set. People say they're played out but I have never, ever seen a set here in the center of the midwest.
  11. Jan 19, 2011 at 5:55 PM
    KaliTaco
    Tacoma1923 I pmed you. I don't really want to use spacer either. Thinking of going with 20x10 now depending on what tacoma1923 says about fitting them. Thanks everyone.
  12. Jan 19, 2011 at 8:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, Thank You! That actually made sense to me.
  13. Jan 19, 2011 at 8:30 PM
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2020 Cement Tundra Limited
    None
    18x9 FTW!
    We do have a 5"bs
  14. Jul 6, 2011 at 10:17 AM
    MicahsTaco
    MicahsTaco Member
    Micah
    Edwards, Colorado
    06 TRD Sport Red
    3" Lift,TRD Cold Air Intake, 20"x10" XD Rockstars, Nitto Terra Grappler Tires
    Here is a photo of my truck with the 20" x 10". Does rub if I crank the wheel but hasn't been a major issue.
