Rocker switch question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Walther shooter, Feb 25, 2018.
  1. Feb 25, 2018 at 2:00 PM
    Walther shooter
    Walther shooter [OP] Member
    Jeb
    2017 quicksand Tacoma TRD Off Road
  2. Feb 25, 2018 at 2:02 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    If wired correctly they will only light up when the truck is on or the item the switch controls is being used. I prefer the Toyota push style switches to blend in with the factory look.
  3. Feb 25, 2018 at 2:04 PM
    Walther shooter
    Jeb
    They are designed to be lit up constantly. I did however, figure how to wire them, to only illuminate, when I flip them on. Just wondering about draw.
  4. Feb 25, 2018 at 2:09 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  5. Feb 25, 2018 at 2:11 PM
    Walther shooter
    Jeb
  6. Feb 25, 2018 at 2:20 PM
    SuperBad
    Dallas, TX
    Truck stuff
    All switches are designed to be lit up constantly when provided power. Most people wire the back light wire for the switch to a power wire that only gets power when the ignition is on. If you wire it directly to the battery or to a wire that always has power it will put a constant drain on the battery, its only a small amount of drain. I would never want my switches lit up when my truck is off. I dont want anything causing a constant drain regardless of how much drain and I dont need or want my switches lit up when my truck is off.
    Falconsfan likes this.
  7. Feb 25, 2018 at 2:21 PM
    Falconsfan
    Falconsfan Well-Known Member
    2017 sr dcsb v6 4x4 black
    Regardless of how they are designed, as long as you power the illumination wire with a switched 12v source instead of a constant 12v they will go off with the truck. Most wire them to only illuminate when lights are on tapping into an existing illumination wire on another switch, most pull it off of cargo light switch.
  8. Feb 25, 2018 at 2:28 PM
    Walther shooter
    Jeb
    These are directly wired to the battery, through the relay in the light harness, so they light all the time. I don't like the idea of constantly lit either but I don't like tapping into factory wires. With my luck, I'd kill the truck, somehow.
  9. Feb 25, 2018 at 2:34 PM
    Falconsfan
    Ok you can use an add a fuse and tap into the tail fuse and they will only come on with the lights,that is how i have mine wired up, and it works, only illuminates if my lights are on or it's my led light bar is switched on.
  10. Feb 25, 2018 at 4:17 PM
    Walther shooter
    Jeb
    These ones are. The item description, on Amazing, shows them lit up all the time.
  11. Feb 25, 2018 at 4:35 PM
    Falconsfan
    Only if you wire them that way. Right on the listing it says "Built-in LED light emits perfect beam to light up the pattern when the switch is powered up, which also allows you to clearly catch sight of it in a dark environment, no more fumbles!"
    It wouldn't say when the switch is powered up if it was lit all the time. But believe what you want.
