Rockauto Refuses Return
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ten Eight Rider, Nov 22, 2017.
  1. Nov 22, 2017 at 3:20 PM
    Ten Eight Rider
    Ten Eight Rider [OP] Well-Known Member
    Central California
    2006 White Tacoma SR5 DCLB 4x4 V6
    Fox 2.5" Coilovers, Fox 2.0 Rear Remote Reservoir DSC, SPC Light Racing UCA, Wheelers Progressive 1.5" AAL, Wheelers Bump Stops, Wheelers Braided Brake Lines, Fuel Revolver 16x8, Toyo AT 265/75/16, ECGS Bushing, Energy Suspension Steering rack bushings/sway bar bushings, All-Pro Sway Bar Links, At the Helm Fabrication bumpers (front and rear), Cali-Raised LED lights, Leer Cap
    I purchased a heater blend door actuator from Rockauto using a part number (SI F04007) I got off one of the forums. The part number was wrong. I contacted Rockauto and they would not accept a return even whit the part being unused. Make sure you have the correct part number. I will not be doing business with Rockauto anymore.
    TomTwo likes this.
  2. Nov 22, 2017 at 3:30 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    This is an electrical device correct? Most places will NOT take returns on electrical items. You have an issue and it fries their brand new part and they take it back and can’t test it and they get burnt. It is a pretty standard policy no matter where you go.
    KB Voodoo, TacoFMS and User Name01 like this.
  3. Nov 22, 2017 at 3:30 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  4. Nov 22, 2017 at 3:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    And they are just an internet reseller. They don't have anything 'in stock'.
    So return policies, on any part, are based on the actual vendor the part came from.
    I've used them. But not much. Been lucky.
  5. Nov 22, 2017 at 3:44 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Well, if you ordered the part using your part number and didn't verify it with their look up then it really isn't a @RockAuto issue. No returns on electronic/electrical parts is pretty standard at auto parts stores.
    Blockhead likes this.
  6. Nov 22, 2017 at 4:26 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Rock Auto also usually has a link somewhere in the part description that tells you what years and models this part is compatible with.
  7. Nov 22, 2017 at 4:32 PM
    Fuelman
    Fuelman Well-Known Member
    Winchester VA
    2014 Taco DCLB Sr5 4x4
    Ultraguage
    Since that part fits 302 General motors models you should be able to unload it on fee bay to cut your losses. Ive used Rock for over Ten years never an Issue. Always check and double check on electrical parts no parts house I know of accepts returns.
    cliffyk likes this.
  8. Nov 22, 2017 at 4:35 PM
    Powerstroke995
    Powerstroke995 Member
    2013 DCSB
    The feature that allows you to input vehicle information and it tells you what parts are compatiable is inaccurate as well sometimes. My boss ordered front brake calipers, pads and rotors for his 2wd F-150 based on it saying it was compatiable. The rotors were for a 4wd. rock auto refused the return. They are still sitting in the corner of our shop.
  9. Nov 22, 2017 at 4:38 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    I would just send them back in this case with a note explaining it, might shame them into issuing a refund.
  10. Nov 22, 2017 at 4:54 PM
    Powerstroke995
    2013 DCSB
    He ended up calling and explained what happened. They responded that the compatibitly was not 100% accurate all the time and it is the customers responsibility to read the entire description before purchasing. He doesn’t shop there anymore.
    Clearwater Bill likes this.
  11. Nov 22, 2017 at 7:15 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I don't think anybody accepts returns on electrical parts. With electronic parts, pull the old one out and get the exact part number before ordering. You have no idea how often they do split year parts. Example, every truck built between January and June of 2017 will have this part and every truck between July and December will have this part. In all honesty just keep the part. Never know, may need it.
  12. Nov 22, 2017 at 9:18 PM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    You may want to point this out to whomever responded to you that they will not take it back.
    Although many companies do not take returns on electrical parts, I see no clause here that reflects this.
    From Rock Auto.
    https://www.rockauto.com/help/?page=4#Returns
    Boyk1182 and scottalot like this.
  13. Nov 22, 2017 at 11:30 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Its up too the buyer too make sure its the right part,seller has nothing too do with that.
  14. Nov 22, 2017 at 11:39 PM
    DANGERMONEY
    DANGERMONEY Well-Known Member
    This has not been my experience and your logic makes no sense.
  15. Nov 23, 2017 at 3:33 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Dangermoney, HappyThanksgiving........Electrical parts are usually nonreturnable because if the customer damages it and it not obvious, When its resold the buyer may have a defective part. It also keeps people from trouble shooting buy getting every part that might be defective and returning the rest..........
    Exracer2 likes this.
  16. Nov 23, 2017 at 5:17 AM
    rybern
    rybern Well-Known Member
    N Alabama
    2023 TRD OR & 2000 SR5
    5100's & 3AAL, 265/70r17 Toyo AT3
    I've received a wrong part from Rockauto and they made it right. I don't use Rockauto exclusively, but I've had good experiences when I do. Sorry to hear your stuck with a wrong part.
  17. Nov 23, 2017 at 5:54 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Just curious, why did you use Rock Auto instead of an OEM part, price or convenience or both? Not trying to be a wise guy, just wanting to know. I tend to lean towards OEM myself.
  18. Nov 23, 2017 at 5:56 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I bought a set of headlights from them. They got condensation in them and I contacted them. "Buy replacements, send the bad ones back and we'll credit you," was the response I got. They're boxed back up and will be in the mail tomorrow or Saturday....
