Rock sliders for first gens?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Natenite, Feb 2, 2020.
  1. Feb 2, 2020 at 7:08 PM
    Natenite
    Natenite [OP] Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    I asked this in the armor section but I’m not getting anywhere. I need sliders, ideally bolt on and from someone that will ship them. Would really like the ones with plates since I have kids that climb in and out of the back seats. Anyone know any manufacturers I can check out? Thanks!
  2. Feb 2, 2020 at 7:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  3. Feb 2, 2020 at 7:17 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I like my trail gears, pretty cheaply priced. Only downside is they aren't a true bolt on. But I'm sure they have them in stock and ready to ship.
    I also agree they are awkward to use as a step, my wife does, but they are almost level with the floor.
    Natenite[OP] and Kwikvette like this.
  4. Feb 2, 2020 at 7:34 PM
    jmferg
    jmferg Well-Known Member
    Shrockworks
    True bolt-on and you can specify flat or angled up with body when ordering. Flat would work better as a step.
    I had the standard 2 tube support, hrew sliders and they survived a triple rollover at highway speeds
  5. Feb 2, 2020 at 7:45 PM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    I got my Trail Gear sliders from 4wheelparts.com. They're in stock and will ship, or pick up locally if you have one nearby. They do bolt on, but they don't give you any hardware, and you'll have to drill the holes in your frame.
  6. Feb 2, 2020 at 7:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Sucks you don't have anyone that can fab some up for you near you.
    Mine are home brew by a member here.
  7. Feb 2, 2020 at 8:00 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I think you want to look at weld-on instead of bolt-on. @Blue92 may have something to add on this...
  8. Feb 2, 2020 at 8:02 PM
    slander
    Hickory, NC
    I have weld ons and wish they were bolt on to be honest with you. Makes for a PITA if you have to paint them or repair them. Strength may be a toss up, I ripped my welded ones off the frame, who would have thought a slider wouldn't be able to handle a massive downward force on it.
    Area51Runner[QUOTED] likes this.
  9. Feb 2, 2020 at 8:06 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    You likely wont find a company that makes a 100% bolt on slider for 1st gens. I think even CBI still wants you to drill a few holes. Even still, they will be far more expensive then the weld on ones as they are much more time consuming to make.
    I made a set that was truly bolt on. Ended up selling them cause it was my first set and they just didnt meet my expectations. The passenger side was breeze, the drivers side took a lot of trial and error to get the mounts to fit with all the fuel/brake/electrical lines in the way. And the gas tank in the back made things tight too.
  10. Feb 2, 2020 at 8:26 PM
    970btu
    970btu Well-Known Member
    Ty
    Las Vegas
    99 Tacoma 3.4 5spd ext limited TRD 55K and counting
    OME, SPC UCA, ARB w/warn 10K winch, TG Rock Defense Rear, Marlin Clutch, Custom hi clearance under bed spare mount. 285/75/16. A ton of repairs done and a list up to come modifications.
  11. Feb 2, 2020 at 8:32 PM
    Area51Runner
    I'd have to search and honestly I won't right now but I remember something about bolt on tended to produce more noise vs sliders that were welded. Again, just something that stands out. If I come across it, I'll post it.
    Taco2021LB likes this.
  12. Feb 2, 2020 at 9:04 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Love my 4xinnovation ones. Had them on for a couple of years now and they are pretty awesome and the price is right too.
    jbrandt likes this.
  13. Feb 3, 2020 at 6:53 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    I have the "TRUE" bolt-on sliders from CBI, and I absolutely love them; they'e perfect! And, they come with ALL hardware, and don't require drilling the frame. As for using them to get in and out of the truck, they DO stick out far enough to use just fine, and although mine don't have plates, I put that "sticky sandpaper" stuff so your feet don't slip off; works great. Photos show sliders right after I put them on (before the sticky sandpaper steps we applied. They weren't cheap, but were EXACTLY what I wanted, and installed in about 1/2 hour. Careful on the driver's side
    though so brake & fuel lines don't get pinched.
  14. Feb 3, 2020 at 3:37 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Bolt-ons are generally much more expensive than the weld on versions. Main advantage is ease of install for a DIYer, but you pay for it.
    I paid $250 for my DOM sliders (4xInnovations), $80 to ship iirc. There are folks paying $800 (+ shipping) for their bolt-ons. My sliders, plus the cost of my 1st welder is still cheaper, lol. I've since gotten a bigger one, but I did my sliders with my little $400 125 welder.
  15. Feb 3, 2020 at 4:44 PM
    N.NV
    N.NV Well-Known Member
    2000 TACO 3.4L
    Sliders from Amazon, 1 3/4" DOM tube, says bolt on but as gussets require alot of holes best to weld, make sure that you leave at least a 1/4" min. under the pinch weld under cab, price is $365,
    Trail Gear Rock Slider Kit: Tacoma 78" (1995-2003 X-Cab & Double Cab) 120011-1-KIT
    Natenite[OP] likes this.
  16. Feb 3, 2020 at 10:14 PM
    jdmstuff
    Derrick
    That is a kit and you have to weld it together, and then bolt it on. .
  17. Feb 4, 2020 at 8:35 AM
    N.NV
    2000 TACO 3.4L
    These are the ones that link says $500+, this is today
    by Trail Gear
    Price: $364.71 & FREE Shipping
    2002Tacoma4x4 and Kwikvette like this.
  18. Feb 4, 2020 at 12:05 PM
    N.NV
    2000 TACO 3.4L
    Be sure to order ones from Trail Gear, those are $365, the ones sold through Advanced Cycle Parts are the $508, and both are same kit #120011, so look closely!!!!
    Actually both are described by Trail Gear but once ordered the cheaper ones come from Advanced Cycle Parts and are $365, same kit, same ###, so be sure to look around Amazon trying to be sneaky.
    QMEDJoe likes this.
  19. Feb 4, 2020 at 3:44 PM
    jbrandt
    Justin
    Only reason to go for something like the 4xInnovations ones vs. the TG ones linked above is if you want to be able to customize the width, height, and angle of the sliders.
    When I did mine, I took an inch off each side (total width is 2" smaller than as supplied) and set the bars to something like 10 degrees from horizontal. I also tucked them up as high as they could go, even had to hammer in the pinch weld a little. You don't have quite so much freedom when you start with the standoff tubes and frame mounts already assembled.
    CenCalWheeler likes this.
  20. Feb 4, 2020 at 6:02 PM
    N.NV
    2000 TACO 3.4L
    Good point, nice truck I esp like the hi lift mount, with the gussets ur still able to angle up or down, just need a little heat and tweak here and there, but I get what your saying mine will be here this week then I got some fab work I want to do to customize them, and then black bedliner. Dab and then roll works best right? I see you did your bed, looks nice.
