Rock auto Mevotech/spc. Upper control arms.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jeeptchr, Mar 1, 2022.
  1. Mar 1, 2022 at 6:33 PM
    Jeeptchr
    Jeeptchr [OP] Member
    04 DC SB Gold Tacoma Trd
  2. Mar 1, 2022 at 6:35 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Yup, thats the new, improved design.
  3. Mar 1, 2022 at 6:41 PM
    Jeeptchr
    Just wanted to check before I got everything tore apart after my return period was up :). I’m actually glad they aren’t the original welded design I like this design a bit better.
    Speedytech7 likes this.
  4. Mar 1, 2022 at 11:41 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Do you have a link to these?
  5. Mar 2, 2022 at 4:46 AM
    ZColorado
    13 DCSB OR 6MT
    boston23 and Nessal[QUOTED] like this.
  6. Mar 2, 2022 at 6:06 AM
    Jeeptchr
    Mine was for an 04 but that's the same part numbers and link
  7. Mar 2, 2022 at 11:09 AM
    Afuen400
    Afuen400 Member
    Angel
    2004 tacoma
    let us know how this turned out, might do the same
  8. Mar 2, 2022 at 11:43 AM
    Jeeptchr
    will do, once I get my coil overs ordered I'll start in on it, probably a month or so out... frame repair, full rear suspension, and full front suspension overhauls are in the works... I figure while it's down I might as well do it all at once :)
  9. Mar 3, 2022 at 8:36 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    The adjustable UCAs you got are better in many ways, but unneccessary if you have a 0"-3" lift. They're really there for bent frames or such extreme lifts that you need to move the UBJ outward and possibly forward/backward. Like with mid to long travel suspension setups. You can still use them on simple to no lifts, but IMO it's a waste of money since they're there to adjust camber/caster beyond what the LCAs can do. The uniball UCAs are probably a better choice for you if you don't need anything like I mentioned.
  10. Mar 3, 2022 at 8:42 PM
    ZColorado
    13 DCSB OR 6MT
    SPCs are fantastic for moving the wheel forward in the wheel well, thats kind of the point.
    I was able to max out the front cams in, and the rear cams out, this maximized the tire/body mount spacing and then all the alignment is now done on the UCA.
  11. Mar 4, 2022 at 6:33 AM
    Jeeptchr
    @CodeSeven I live in the midwest above Kansas City. Where I live winter road treatment on the roads I primarily drive is not conducive to uni-balls or else I would thought about them. I wanted a traditional style ball joint sealing (I'll end up treating and covering the coilovers with something so they don't corrode). I really wanted to put jba's on but I read about tire rubbing issues with different wheel offsets. part of the reason for going with SPC/Mevotech was the price point, I was in these for sub 450 shipped.
    adjustability is nice for the reasons @ZColorado said above, I'll be honest I'm a little worried about there being too much adjustability with both lowers and uppers now have adjustments when I go to my local alignment shop. so I'm still trying to figure out exactly where to set these to start with.
    Lift wise I'll probably be right in the 2-2.5 range when finished is my guess, I really would like to run 255's long term if they will fit. (first rig with IFS)
    CodeSeven likes this.
  12. Mar 4, 2022 at 7:14 PM
    CodeSeven
    Serge.
    Coachella Valley
    10-4. I didn't think about where you live and the road conditions. I live in SoCal so uniball UCAs would probably be much better here than where you are.
  13. Mar 4, 2022 at 7:19 PM
    Jeeptchr
    Yeah on my tj I ran straight heims for rear UVA’s they were almost a consumable in bad winters and they were kinda protected. Out where you are at I could see uniballs as a fair choice. The other day I was driving over so much road salt it looked like chatt gravel covering the road.
