Roadside assistance jacked my truck up by this instead of frame. What is this part?
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, Oct 12, 2018.
  1. Oct 12, 2018 at 12:39 PM
    prerunnerSD
    prerunnerSD [OP] Well-Known Member
    USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    Can someone please help me identify the proper part name on my 01 Tacoma V6 4X4.
    You will see it in the red circle, also with some markings from his jack.
    I had a flat tire and the the roadside assistance guy lifted up my truck by this part and not sure what else because he didn't have a jack that could fit my frame. This caused both skid plates to fall off and be bent after he left and I drove over a bump.
    What other damage may he have caused? I will ask my mechanic to take a look.
    regards
    Jonathan
    http://www.divesummit.com
  2. Oct 12, 2018 at 12:40 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Lower Control Arm
    wilcam47 likes this.
  3. Oct 12, 2018 at 12:42 PM
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
    that's the lower apple sauce maker
  4. Oct 12, 2018 at 12:43 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Lower control arm. Jacking from it wouldn't have damaged your skid plates, though, unless the jack slipped off while he was doing it and the truck somehow jumped sideways and upwards in the process of having it slip off (which you would have noticed, since it defies gravity). Honestly, jacking from the control arm wouldn't even have damaged the control arm itself, since it's designed to hold up the weight of your truck while you're driving down the road anyway.
  5. Oct 12, 2018 at 12:47 PM
    Mojave4x
    Mojave4x Active Member
    98 SR5 4x4 extended cab 3.4 5speed & 08 limited 4Runner 4x4 4.0
    Detroit TrueTrac both diffs, re-gear 4:30, Wheeler's 8 leaf, OME 881, JBA UCAs, Bilstein 5100 all 4 corners, All new u-joints & ball joints, new LCA bushings
    Its the Lower control arm. I've used a jack under the LCA to jack up my front tires many times. No issues. On my 1st gen, the skid plates don't attach to the LCA. The LCA pivots up & down as part of the suspension.
  6. Oct 12, 2018 at 12:47 PM
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    Hmmm I’ve been use the lower control arm to Jack my truck up all this time..
    Where are u supposed to jack it up :burp:
    Edit: and by truck I mean just the wheel
  7. Oct 12, 2018 at 12:49 PM
    EF
    EF Well-Known Member
    Upstate NY
    2015 TRD Off Road Blue Ribbon
    Primewell tire’s fault.
    User Name01 and Dirtridercrf250 like this.
  8. Oct 12, 2018 at 12:51 PM
    Mojave4x
    My owner's manual says to place the jack under the frame just reward of the wheel well, about inline the hinges on the front door. Check your owners manual or there are links to the various manuals somewhere in TC World.
  9. Oct 12, 2018 at 12:52 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You are 100% fine. There is no reason to worry about some little scratches on that part - the lower control arm.
    That's a common place to jack from.
    As for the skid plates, that is most likely completely unrelated, and merely a coincidence. Neither part is connected to the other.
    Those plates are held on with like 9 bolts so there's really no way I can see your skids falling off *because* of anything the roadside guy did.
  10. Oct 12, 2018 at 12:53 PM
    Boatbldr
    Boatbldr Well-Known Member
    Florida
    2002 prerunner
    None
    Owners manual shows u should be jacking it up from cross member under tranny. Rear axle for back
    black coffee likes this.
  11. Oct 12, 2018 at 12:53 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    It’s totally fine to jack up the truck under the lower control arm, and may be preferable so that the suspension doesn’t droop, causing you to have to lift the truck higher.
    That by itself did not damage or dislodge your skid plates. They were either already loose or something else happened to them during the roadside service.
    Rocan likes this.
  12. Oct 12, 2018 at 12:55 PM
    jbrandt
    Justin
    There is no way the supplied OEM bottle jack will safely reach the frame.
    If the lower control arms aren't strong enough to handle jacking from, they shouldn't be used to support the weight of the vehicle in the first place (which is kinda what they do 100% of the time).
  13. Oct 12, 2018 at 12:59 PM
    Boatbldr
    Florida
    2002 prerunner
    None
  14. Oct 12, 2018 at 1:07 PM
    PeeDeeTaco
    PeeDeeTaco Custom Title
    Effingham, SC
    2017 TRD Off Road 4x4 DCSB Blazing Blue Pearl
    5100 + OME 888 + Headstrong AAL SOS Offroad Concepts Streamline Winch Bumper Smittybilt XRC 9500 winch Method Race Wheels MR308 Roost Falken Wildpeak AT3W Image Dynamics speakers/sub Tacotunes Amp and sub enclosure
    Jacking the LCA is mechanic 101 for checking ball joints and wheel bearings.
    Rocan, wilcam47, Train and 1 other person like this.
  15. Oct 12, 2018 at 1:09 PM
    jbrandt
    Justin
    Those are instructions on how to use that jack. It's not detailing the only acceptable places to jack the truck up.
    That said, I would still rather jack from the LCA anyway, even using the bottle jack.
    Rocan, wilcam47, Gunshot-6A and 2 others like this.
  16. Oct 12, 2018 at 1:13 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Have fun doing that with the stock bottle jack.
    The guy used the right location. Not sure what's up with the skid plate tho
    Willbeck likes this.
  17. Oct 12, 2018 at 1:19 PM
    chrispchicken9
    Are you positive he lifted it up by that part?
    Jacking it up by the front cross member would require to remove the skid plate I'm pretty sure.. At least that's how it looks on my truck.
    Is it possible he jacked it up by the front cross member while leaving the skid plates on? Or maybe during his first couple attempts he tried in this area and f'd up your skid plate. That's why he went to the a-arm
  18. Oct 12, 2018 at 1:21 PM
    jbrandt
    Justin
    That's certainly possible, but I don't think even that (by itself) would cause the skid plates to fall off. Bend them? Yeah. Fall off? Nah.
  19. Oct 12, 2018 at 1:28 PM
    chrispchicken9
    Well the skid plates connect to one another pretty snug, if one of them was bent it could have some type of potential energy like a decompressed spring..
    This combined with the terrible job of corporate oil-change techs and missing/stripped bolts in the skid plates having an affect (assuming you don't change your own oil) it is certainly possible!
    I mean hell, skid plate fell off from a small bump somethin was definitely up! :p
  20. Oct 12, 2018 at 1:29 PM
    Boatbldr
    Florida
    2002 prerunner
    None
    Here comes the "Buttercups" I better stick to the Chinese censorship o
