Road Force Balancing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma guy, Jul 17, 2015.
  1. Jul 17, 2015 at 4:13 PM
    tacoma guy
    tacoma guy [OP] Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Hey guys looking for any one with personal experience with having the road force balance done? A little bit about what I am dealing with. A year ago I got some new after market wheels with new tires. Here's what I got . 265/70r16 Hankook Dynapro ATm. with American outlaw wheels 16x8 . Both brand new. The wheels are hub and lug centric. I made sure of it. From day one I has a very slightly vibration at 53 and at 68-70. Just recently it started to get slightly worse so I decided to get them balanced and rotated. Well it was way worse so I went back that same day and they rebalanced them and it is a little better but at 63 to 70 the steering wheel shimmy's and you can feel it in the rest of the truck. After the second time I took the guy how did the balance with me and he felt it to. He told me to have them Road Force Balanced. But they didn't have that machine at that location. I never had this problem until I did the wheel switch. It is on my 2011 with only 237xx miles. I have red up on this type of balancing but dos it really work? Any and all personal experience would be highly appreciated. Thanks in advance !!
  2. Jul 17, 2015 at 4:17 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Had Road Force balance done to my Revo 2's worked very well. My tires were brand new and had a vibration from the get go, after Road Force was done no problem at all.
  3. Jul 17, 2015 at 4:54 PM
    tacoma guy
    Joe
    Phoenix Az.
    Thank you 03coma. That is good to hear and gives me some hope.
  4. Jul 17, 2015 at 5:27 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Just make sure a competent shop does it. I had a moron do mine. Gouged my wheel using an impact on my lug locks and the next day a strip of weights fell off one of my wheels. He was also too lazy to remove/rotate any of the tires.
  5. Jul 17, 2015 at 6:50 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Also challenge the shop to make sure their balancing macine is using the hub centric adapter
  6. Jul 17, 2015 at 6:55 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    Road force is good, it can also measure just the wheel to see if they are out of balance.
  7. Jul 17, 2015 at 7:10 PM
    tacoma guy
    Joe
    Phoenix Az.
    Oh ok . That is good info . I will definitely make sure thank you !
  8. Jul 17, 2015 at 7:12 PM
    tacoma guy
    Joe
    Phoenix Az.
    That is what I am finding out . I just hope that my wheels are not the problem .
  9. Jul 17, 2015 at 7:16 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I had the same tires for 7 months, and had 4 rebalances and 2 road force balances, 2 replacement tires plus the original set of 4 and they never got fixed. I had constant vibes with them.
    Swapped for Cooper ATP and instantly went away.
    I'll never own them again. Good luck! It is rare for a wheel to be out of balance, and with your symptoms I wouldn't think they are either. I bet it's your tires!
    Every local shop here (besides the shop I bought them from) suggested immediately it was a tire fault and that Hankook truck tires are low grade, turned out to be true.
  10. Jul 17, 2015 at 7:16 PM
    TacoDan723
    TacoDan723 Well-Known Member
    Dan
    Pacific Northwest
    2015 MGM Tacoma Limited
    The shop I had road force balance my previous tires said they could only test them up to 60 mph. Make sure they let you know what speed they are testing it to cause it may not show up at lower speeds!
  11. Jul 17, 2015 at 7:18 PM
    00yotasr5
    lee
    merced, ca
    Stealership should have the hunter 9000 road force machine, well the one I work at does. Anyways hope it's not the wheels that are out of balance. I bought 4 of the rock crawl from wheelers and 3 of 4 was out of balance like 52 lbs off.
  12. Jul 17, 2015 at 7:26 PM
    akamrkent
    akamrkent Well-Known Member
    Kent
    San Jose
    2004 Black Tacoma TRD
    Homemade Bumper and Skid plate, OME lift, Powertrax auto locker(front dif) and a Leer Shell
    Also keep an eye out for heavy weights, if they are stacking one side to counter balance something big. Ask them if they tried to rotate the wheel in relation to the rim. I once had one 3rd of my rim stacked with weights, they told me it was normal... So I googled it and learned about that technique. Took it back and insisted they try that, they used half as many weights once rotated and it felt smoother on the road.
  13. Jul 17, 2015 at 7:46 PM
    wesplains
    wesplains Well-Known Member
    West
    Middle of USA
    Tacoma TRD Sport
    SnugTop, Aries Stealth Bull Bar, OEM Bed Mat, Wet Okole Seat Covers, Husky Floor Mats, OEM Cab Rack, Amp Bed Extender, VooDoo Bad Brackets with Cargo Basket. Yakima racks on cover. MagnaFlow Muffler, KC Running Lights, Console Vault, Dash Cam, Side Moldings, UltraGauge
    I had 2,500 miles on my 2014 when I went to 265/70/17 Goodyear Wranglers Adventures on the stock wheels. 3,000 miles later had them rotated at Dealership during an oil change.Vibration at the speed OP mention. Took it back twice to the shop that put them on. Second time talked to the co-owner (lady of owner) she had them rebalance the front ones. So far so good.
    Had a really bad experience with the Goodyear Silent Armors tires on my Jeep. Great, super quiet until I rotated them. After rotation never could get them feeling as smooth. Starting to wonder about tires with Kevlar in them.
  14. Jul 17, 2015 at 8:12 PM
    tacoma guy
    Joe
    Phoenix Az.
    Yeah I hope they can get it fixed . It is really annoying especially since I didn't have it with my stock trd off road wheels. I even had Michelin put on and smooth as glass even at 90 mph. I am wishing I would of left it stock.:confused: Thanks guys for all your replys. All great info. Very much appreciated! I will keep you posted. I am in the process of finding a big o tire near me with that balance machine. Thay are the ones that I got the tires through so the balance is covered under warranty.
  15. Jul 17, 2015 at 9:13 PM
    Fatnlow
    Fatnlow New Member
    Doug
    Minot ND
    08 trd dcsb 4x4
    Spacer, blocks, kn drop in, ap muffler amd dumped
    This is my first post, I'm a factory trained coat equipment tech, I fix tire machines and balancer that the shops brake. Roadforce is a good balance, but the biggest this is to get a good mount on whatever machine is being used. Toyota 6 lug has a huge center hole making it hard to get a good mount. See if you can find a shop that has the cone kit for toyota. If you see a huge stack of weight ask is they will match mount your tire and wheel assy. Also find out when the last time their balancer was calibrated.
    akamrkent likes this.
  16. Jul 18, 2015 at 6:13 AM
    tacoma guy
    Joe
    Phoenix Az.
    Sounds good . I will add that to my list of things to look for . Thanks for your reply !
  17. Jul 18, 2015 at 6:36 AM
    wesplains
    West
    Middle of USA
    Tacoma TRD Sport
    Fatnlow, that is some good info. Thanks.
  18. Jul 18, 2015 at 9:57 AM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Hankooks are pretty popular around here and I never heard anyone having problems with them.
  19. Jul 18, 2015 at 12:31 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    You need a tire shop that has a Haweka adapter. Without it, the balance job is a crapshoot.
  20. Jul 18, 2015 at 5:00 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Would he still need the Haweka adapter even though he is now using aftermarket rims?
