RisingWithoutWings - 2016 TRD Off Road-Build
Discussion in '3rd Gen. Builds (2016-2023)' started by RisingWithoutWings, Aug 9, 2016.
  1. Aug 9, 2016 at 4:09 PM
    RisingWithoutWings
    RisingWithoutWings [OP] Well-Known Member
    SoCal
    2016 Tacoma TRD Off-Road
    Hi TacomaWorld!
    This thread will document my build for my 2016 Tacoma TRD Off-Road 4x4.
    Follow me on Instagram @RisingWithoutWings
    Truck Video:
    Modifications completed to date:
    - 5% Llumar ceramic tint to all windows
    - 40% Llumar ceramic tint to front windshield
    - Full LED interior upgrade
    - RSI Platinum LED Bulb Kit for low and high beams
    - Rigid Dually Fog Lights
    - JDM ASTAR 800 lumens Reverse Lights
    - Viper LCD 2-Way Security + Remote Start System
    - Pop & Lock Power Tailgate Lock
    - Side Marker Light Overlay from Import Equipment
    - Escort Max 360 Radar Detector with BlendMount / MirrorTap
    - WeatherTech FloorLiner
    - TRD Pro Grille
    - Safari Snorkel
    - Hood wrapped in Matte Black
    - Rigid Industries Toyota Tacoma Grille
    - Rigid Industries E-Series 20" Midnight Edition
    - ICON Vehicle Dynamics Suspension System - Stage 5 w/ 700lb springs
    - OME Dakar HD Leaf Pack
    - Icon Rear Hydraulic Air Bumpstop System
    - Wheeler's Front SuperBump Bumpstop
    - Toytec 1" body lift
    - RCI Off Road Rock Sliders
    - Tacoma 8.75", 4.88 Ratio, Nitro Front & Rear Gear Package Kit
    - Hypertech In-line Speedometer Module
    - Yaesu FTM-400DR (HAM Radio) w/ Diamond NR73BNMO Dualband Mobile Antenna
    - Midland 75-822 CB Radio w/ FireStik MK-204R Door Jamb Antenna Mount
    - sPOD HD Switch Panel for 8 Circuit SE
    - sPOD 8 Circuit SE System w\Touchscreen (in the cargo area)
    - ARB On-board High Performance 12 Volt Twin Air Compressor with 1 gallon tank(Slee Off Road bracket)
    - National Luna Dual Battery Split System DIY Kit
    - BlueSea Systems Fuse Box
    - 2 Optima Yellowtop D34/78
    - Waterproof LED HOOD & BED light kits
    - CBI Winch Mount 3rd gen Tacoma
    - Pelfreybilt Aluminum Plate Bumper
    - WARN VR10000-s
    - Factory55 Hawse Fairlead 1.0
    - Factory55 FlatLink
    - TRD Pro Skid Plate
    - Pelfreybult Aluminum Mid, Rear and gas tank skids
    - A.R.E. V Series Topper with Windoors and LED light strips
    - FrontRunner SlimLine II Tray Roof Rack
    - Rigid Industries E2-Series 40" Combo LED Light Bar
    - Rigid Industries SR-Q2 Series Diffusion LED Light
    - 285/75/R16 BFGoodrich All-Terrain T/A KO2s
    - Method Race Wheels NV 16x8 with 6 on 5.5
    - 315/70/R17 BFGoodrich All-Terrain T/A KO2s
    - Method Race Wheels NV 17x8.5 with 6 on 5.5
    - ARB drawers
    - ARB Element Fridge
    Future Modifications:
    - Rear bumper
    etc
    How she sits currently:
  2. Aug 17, 2016 at 10:10 PM
    ProjectPat
    ProjectPat Member
    South Carolina
    2016 Tacoma TRD OR 4x4
    Nice set up. Curious about your 1in lift. Was it easy to install? Do you think its a good mod?
  3. Oct 7, 2016 at 7:58 AM
    RisingWithoutWings
    SoCal
    New Photo after tire and wheel install. Tires do rub slightly but waiting on ICON suspension
  4. Oct 7, 2016 at 12:38 PM
    Rein
    Rein Well-Known Member
    Cole
    San Diego
    2017 TRD Offroad DCLB
    Suspension, racks, tune, bed, lights. See build thread.
    How is the wind noise with the Slimline roof rack?
  5. Oct 7, 2016 at 2:25 PM
    RisingWithoutWings
    SoCal
    It's not that bad. You can really only hear it when you're traveling at highway speeds. I normally have some music playing so it's hardly noticeable.
  6. Oct 25, 2016 at 5:26 PM
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
    hi was the 1 inch toytec bodylift tough to do does this void warranty thanx for your time
  7. Nov 12, 2016 at 2:40 PM
    Kerri's Toy
    Kerri's Toy Member
    2016 Tacoma TRD
    great Mods. thanks for sharing. Where did you mount your ARB air compressor??? I don't see any room under the hood.
    I have the ARB 12 volt as well
  8. Nov 14, 2016 at 5:39 AM
    RisingWithoutWings
    SoCal
  9. Nov 14, 2016 at 5:43 AM
    RisingWithoutWings
    SoCal
    I mounted it on top of the fuse box with a custom bracket. Slee Offroad also makes a custom mount, but I couldn't buy it because it would have gone where I installed my second battery
    http://www.sleeoffroad.com/products/products_air.htm
  10. Nov 14, 2016 at 5:45 AM
    RisingWithoutWings
    SoCal
    It was pretty easy to install, about half a day. I did it with the help of one other person. Anything you do to your vehicle should not void your warranty. If you run into any issues with your truck, Toyota would need to prove that the 1 inch lift caused the problem. I am no expert so please do your research and install at your own risk.
  11. Nov 14, 2016 at 7:10 AM
    Cold_Toad
    Cold_Toad Well-Known Member
    I'm curious about the CBI winch mount, first truck I've seen one on. Do you like it? How was the install, have to remove/cut anything? Could you post a few extra pictures of it as the picture on there website is pretty terrible.
  12. Nov 14, 2016 at 8:04 AM
    RisingWithoutWings
    SoCal
    The install was very easy and straight forward. They actually didn't send instructions so I called them and let me know I shouldn't need instructions (which I thought was odd). Once I took off the bumper I realized that it was indeed an easy install. You just remove the OEM bumper dampener and install the hidden winch mount onto the OEM bolts. They send additional support brackets that require you to temporarily remove the sway bar but I opted to not install the brackets. I called and they said that it was highly recommended I install the brackets if I am doing heavy winching (which I am not at the moment).
    I really like how it came out and I think it's very low-key but very functional. I am using a (now "old") WARN VR 10000-S so I didn't need to remove and relocate the winch solenoid. Some of the new series of WARN winches have the solenoid located in the center of the winch so you'll need to remove it and relocate it because it will hit a bracket in the engine bay. I also got the wireless controller which is great but you can still access the winch with the hood open to release the spool manually if you needed to.
    Lunabird likes this.
  13. Nov 15, 2016 at 6:54 PM
    TRLEATR
    TRLEATR Member
    Scott
    2017 Tacoma TRD Off Road
    Just off the lot. Need some help here :)
    Can you show pics of the work you did inside?
  14. Nov 15, 2016 at 7:03 PM
    Kerri's Toy
    Kerri's Toy Member
    2016 Tacoma TRD
    thank you for taking the time to reply....gonna give it a shot!!
  15. Nov 16, 2016 at 3:39 AM
    RisingWithoutWings
    SoCal
    I'll try and post a few photos later today of the engine bay
    goodluck!
  16. Nov 17, 2016 at 3:51 AM
    Chiefandy
    Chiefandy Well-Known Member
    andy
    2017 tacoma
    i like your grille
  17. Nov 21, 2016 at 11:21 AM
    RisingWithoutWings
    SoCal
  18. Nov 21, 2016 at 2:26 PM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    is this with the Toytec 1" BL AND the Icon suspension on? or just the BL?
  19. Nov 21, 2016 at 3:08 PM
    RisingWithoutWings
    SoCal
    Only 1" body lift with 285/75R16 (rubs a little) . Suspension will come early next year.
  20. Nov 21, 2016 at 3:43 PM
    WHOISTYLER
    WHOISTYLER Well-Known Member
    Tyler
    Denver, CO
    2016 MGM TRD OR DCSB
