Rinsed motor, now it's squealing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sicki, May 5, 2020.
  1. May 5, 2020 at 10:34 AM
    sicki
    sicki [OP] Well-Known Member
    Few weeks ago @mynameismudflap challenged me to a large mud puddle in Big Bear hahaha. (its all his fault haha jk)
    I rinsed the motor and used some simple green on it. I did not pressure wash.
    Was the Simple Green a bad idea because after this rinse, my belt is squealing.
    I bought some belt conditioner spray and that will quiet it..then after it sits for a while and dries, it will squeal again on next start up? 3 days of liberal spray on lube at every startup so far.
    Looking closely at everything I also feel as though im seeing an Idler Pulley that appear to spinning with a very slight wobble. Maybe thats normal?
    Im wondering if the Simple Green permanenty fucked up my belt?
    Any advice, input, or better engine bay washing procedures are greatly appreciated.
  2. May 5, 2020 at 10:41 AM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Tighten that pulley. It shouldn’t wobble. You talking about up and down motion? Might be the tensioner pulley (or whatever it’s called). That one will move up and down a little
  3. May 5, 2020 at 10:43 AM
    mdwall
    mdwall Well-Known Member
    2020 TRD Offroad
    It's possible the simple green soaked into the belt somehow and is causing the squealing. They are rubber and I have heard of it soaking into rubber which would make it hard to remove. That may be why the conditioner you spray on quiets it until it wears off and then it goes back to squealing. Can you try getting a replacement belt and see if that resolves the issue?
    Modesto Tacoma likes this.
  4. May 5, 2020 at 10:43 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Water was too Cold. Has to be the problem.
    b_r_o and Gunshot-6A like this.
  5. May 5, 2020 at 10:43 AM
    rkao1832
    rkao1832 Member
    Ron
    2019 TRD OR, Cement
  6. May 5, 2020 at 10:47 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    How old is your belt? Is it at the proper tension?
    If anything mud getting caked up in the belt probably messed it up more than cleaning it off would have.
    I've never had a problem with simple green. Love that stuff.
    Gunshot-6A likes this.
  7. May 5, 2020 at 10:52 AM
    sicki
    It was fine till i cleaned.
    30K miles on 2019 , original belt
    yeah might be the tensioner pulley that i mentioned.
    Cold water? I assume your kidding right?
  8. May 5, 2020 at 10:53 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Everytime i washed my engine bay, i had something go wrong everytime. They were all minor things but still. I would never wash my engine again unless i really really have to. Just my 0.02, good luck.
    GHOST TACO, WarrenG, Tommyb08 and 6 others like this.
  9. May 5, 2020 at 11:03 AM
    suaveflooder
    Same. I usually just wipe down the stuff I can see with a microfiber and water
  10. May 5, 2020 at 11:24 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    steam clean or with a spray bottle and hand towel only. i washed the engine bay in my first vehicle and regretted it.
    wilcam47 and Junkhead like this.
  11. May 5, 2020 at 11:29 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I always wipe everything down with a rag and degreaser by hand. Water messes with everything and causes issues that I don’t want to cause.
    71tattooguy and Junkhead like this.
  12. May 5, 2020 at 11:30 AM
    Tnc
    Tnc Well-Known Member
    Tim
    NE Oklahoma
    2017 DCLB TRD OR
    I’ve always rinsed my motor with it running. Never had any issues. Not sure if that’s why or I just got lucky.
  13. May 5, 2020 at 11:40 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Yeah unfortunately simple green didn’t fuck up the belt...you did
  14. May 5, 2020 at 11:42 AM
    sicki
    what would you have done differently?
  15. May 5, 2020 at 11:43 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yep, i regretted it every time haha. Not touching the engine on my taco, fuck that.
    GHOST TACO and auskip07[QUOTED] like this.
  16. May 5, 2020 at 11:45 AM
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    I always use simple green under the hood. No squeaks. If you use the lemon simple green, run you a/c with the engine to dry and the a/c will smell like lemons for a few days.
    PzTank and Gunshot-6A like this.
  17. May 5, 2020 at 11:48 AM
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
    :anonymous:
    I take full responsibility.
    davidstacoma likes this.
  18. May 5, 2020 at 11:53 AM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    Take ownership for my own actions rather than blaming the tools.
    71tattooguy likes this.
  19. May 5, 2020 at 11:54 AM
    sicki
    well you sound like a Tool..so ill blame you then
    Minimag95, VB25, ericvega and 25 others like this.
  20. May 5, 2020 at 11:56 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I used to love racing through the mud on my mountain bike. Having to do a complete teardown and overhaul once a week it quickly changed my mind on how fun it was. One of these days, Im going to learn not to do that with my truck either.
    Stopmithering and Junkhead like this.
