Rinse undercarraige in winter or no?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitro52, Jan 24, 2022.
  1. Jan 24, 2022 at 11:45 AM
    Nitro52
    Nitro52 [OP] Well-Known Member
    ct
    2022 SR/SX
    Someone on youtube suggested that if you have already rustproofed the frame and under-body with surface shield, fluid film, etc - road salt picked up later on does not come in contact with the metal. So rinsing it with pressure, say, after a snow storm, doesn't really help, it just works to weaken your rustproofing.
    What do you think?
  2. Jan 24, 2022 at 11:55 AM
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    Here in Colorado I’m not going to bother with fluid film etc. I use the undercarriage sprayer for my pressure washer after each mag chloride-worthy storm. YMMV, I suppose mine will too!
    Frito, Jason in KC, kgilly and 2 others like this.
  3. Jan 24, 2022 at 12:06 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I don't overthink this type of thing. I FF or Woolwax mine before each winter and wash like normal (1 a week through a wash with brushes!). It will keep everything rust free enough that way for the 10 or so years I'll have it.
    Sxottie and vicali like this.
  4. Jan 24, 2022 at 12:13 PM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I fluid film in the fall and don't wash it until spring. Fluid film can be washed off with a pressure washer. My underside still looks great. Might do Cosmoline next fall though for a more permanent/longer lasting coating.
  5. Jan 24, 2022 at 12:54 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    I have been using a house gutter spray wand attached to my garden hose to easily reach under the frame and dilute the salt off of everything. Works great and fast even in the cold weather. I've seen too many vehicles parked somewhat long term with salted undercarriages and the damage occurs quicker then you might think. It is not high pressure - so it won't blow your protectant away - kinda like driving in the rain.
    Blockhead likes this.
  6. Jan 24, 2022 at 1:04 PM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Love the replies from folks that aren't contributing to the OP's question.
    I woolwaxed mine this year but have avoided hitting those parts with a pressure washer.
  7. Jan 24, 2022 at 1:20 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I wash every time my truck gets salty, Im not concerned about it rinsing away the fluid film because I put the film on to protect areas that dont get rinsed very easy. There are spots on my truck that are covered in fluid film, and spots that are bare. The spots that are still covered I know dont get rinsed very well by the car wash, so the fluid film protects there.
  8. Jan 24, 2022 at 1:31 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I rinse my undercarriage pretty much every time i drive on salty roads.
    Never had issues with rust on my pick ups.
    Vmax540 and Montana_Actual like this.
  9. Jan 24, 2022 at 1:36 PM
    TacoDipVT
    TacoDipVT Member
    Vermont
    2019 DCLB TRD Sport Super White
    Air Dam Delete Rek-Gen Mud Flaps Bilstein 6112/5100 OME Dakar Leafs Med. SPC Upper Control Arms Falken Wildpeaks AT3W 255/80/R17 ARE MX Topper
    Vermont here, I FF late fall and try not to wash the underside until spring. I will wash the outside, which needs to happen the next warmish day.
    Slashaar, gsubioguy and Nitro52[OP] like this.
  10. Jan 24, 2022 at 1:47 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I use Woolwax which is a bit thicker than Fluid Film. It's pretty difficult to wash off but it can be done. A couple of undercarriage washes won't hurt but I'd reserve it for the heaviest of salt though.
    So far my truck is 5 years old and has less (if any) rust than I see on a lot of newer GM vehicles in my area. Yay for the rust belt!
  11. Jan 24, 2022 at 1:54 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I use CRC Marine (cosmoline) which is very resistant to washout. I take mine through an automatic touchless car wash with underbody spray when the temps go above freezing a few times each winter.
    Greg-tacoma likes this.
  12. Jan 24, 2022 at 1:54 PM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    I think general atmospheric moisture is important not just how much road salt there is. Do you live near the ocean? If so I think you need to rinse a lot. Desert- much less so even if there is snow.
    Sonofliberty92 likes this.
  13. Jan 24, 2022 at 1:58 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    In the winter, I do auto carwash with the power under-spray.
    In the summer, I get the wife to do it.
  14. Jan 24, 2022 at 2:07 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Your wife washes the undercarriage of your truck?
  15. Jan 24, 2022 at 2:10 PM
    Spinner
    Spinner Well-Known Member
    NW CT
    17' DCSB TRD Sport
    I use NH Oil, I have had it applied twice. I was instructed not to rinse underneath which seems to have worked well, zero rust issues. The salt here is terrible, it destroys undercarriages.
    Toolndie7 likes this.
  16. Jan 24, 2022 at 2:14 PM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    If it isn't rust proofed rinse it often as you can, especially in New England.
    gsubioguy likes this.
  17. Jan 24, 2022 at 2:14 PM
    AwesomeLaw68
    Lawson
    Brand new.
    Is she out wearing a bikini while she does it...
    Slashaar, Junkhead and Seventh like this.
  18. Jan 24, 2022 at 2:20 PM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    COMMANDO740, AwesomeLaw68 and Tocamo like this.
  19. Jan 24, 2022 at 3:18 PM
    Tacoma091919
    Tim
    2019 OR DCLB
    I have that in my Amazon cart. I think I might have enough fluid film for one more season but cosmoline is good stuff. Nasty, but good stuff.
  20. Jan 24, 2022 at 3:37 PM
    Nitro52
    ct
    2022 SR/SX
    I'm looking at surface shield. It says it can last up to 2 years, and the reviews seem pretty good.
