Ring to convert lug centric spacers to hub centric?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tomrad, Nov 27, 2022.
  1. Nov 27, 2022 at 7:50 PM
    tomrad
    tomrad [OP] Well-Known Member
    2008 Tacoma Access cab, automatic 4x4
    A previous owner put lug centric spacers on my 2nd gen 6 lug Tacoma. Bottom line, it's a crapshoot to get the front wheels in the exact centered spot every time the wheel is removed and reinstalled (vibration above 50, depending on where wheel ends up).
    I'm certain the problem is the wheel isn't perfectly centered sometimes. Is there a centering ring made that I can use with my existing spacers, or do I need to swap them to hub centric? Thanks!
  2. Nov 27, 2022 at 8:41 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Swapping to a hub centric spacer is going to be way easier and probably the same cost as having a spacer ring made up to fit the gap.
    The only hard part is if it’s a slip on spacer rather than a spacer with lugs.
    TnShooter and tomrad[OP] like this.
  3. Nov 28, 2022 at 2:33 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
  4. Nov 28, 2022 at 3:05 AM
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    Go with hub centric spacers. They cost more but offer more advantages and peace of mind. I bought some cheapies at AutoZone and did a test fit but was concerned for safety reasons. I had a wheel come off years ago and didn't want to risk reliving that.
    Bora's have been on my 17 Tacoma since new and I have had no problems. Just make sure you have them torqued properly and recheck them when rotating your tires. I went with 0.75 spacers.
    b_r_o likes this.
  5. Nov 28, 2022 at 5:41 AM
    tomrad
    Thanks! Did you buy yours from Bora directly? Do they come with the lug nuts? The ones to hold the spacer, I mean. One of mine the hex is a bit chewed up from whoever put it on.
  6. Nov 28, 2022 at 12:00 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    Man, I ran lugcentric spacers for years without issue, but that's just my experience, not advice.
  7. Nov 28, 2022 at 12:04 PM
    d0ugh0ck
    d0ugh0ck Well-Known Member
    NJ
    Did you have to trim the studs with the 0.75?
  8. Nov 29, 2022 at 7:13 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    I bought centering rings off of Amazon for my gen 1 years ago. I’d bet they are still available
  9. Nov 29, 2022 at 7:27 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The lugcentric spacers have a smooth face? i.e. they lack the hub lip for the wheel to register on? Not many elegant solutions besides replacing the spacers with hubcentric spacers.
    What is the center bore on the spacers? 106mm or 108mm? What is the center bore on the wheel?
  10. Nov 30, 2022 at 2:33 AM
    tomrad
    The wheel is 106.1 mm opening, the hub opening is, if I’m reading the markings on the spacer correctly, is 108mm.
  11. Nov 30, 2022 at 6:46 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I had the same .75 boras and did not have to trim the studs. Most wheels have a little pocket of space in the casting between each lug hole. I know all the oem alloys do
    d0ugh0ck[QUOTED] likes this.
  12. Nov 30, 2022 at 7:49 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I have some Boras for sale in the wheel/tire forum.
