Ring and pinion replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mikesedge, May 9, 2016.
  1. May 9, 2016 at 11:44 AM
    mikesedge
    mikesedge [OP] Well-Known Member
    2003 Silver Tacoma TRD Off-Road
    AEM intake, Magnaflow exhaust, bluetooth radio, LineX bed liner
    So on the way to work this morning all of a sudden there's a loud clanking/clunking sound. My immediate thought was that I blew a piston or something in the engine because it only happened when I hit the gas. I pulled over and investigated the truck and read some internets and realized it wasn't the engine and most likely it was something in the rear diff. Very gently drove to the transmission place nearby and they say I need to replace the ring and pinion gears in the diff, probably bearings and bushings from taking it apart, and labor is going to be nuts. Ballparked it somewhere around $1500 most likely. Potentially $700 if I'm really lucky but huge possibility to double that, so probably at least $1400.
    So my concern is, can I do this myself? I don't have a ton of tools and I'm not a mechanic but I've done a bunch of repairs on a bunch of vehicles (including this one) and I'm good at taking things apart and putting them back together. If I did this myself what parts do I need for ring and pinion. It looks like on the internet there are a few different types. My truck is a 2003 Tacoma, extra cab, V6, manual, TRD Off Road 4WD, electronic locking rear diff. Is there a particular model number I can search for? I really just want to make it driveable again. I don't plan on putting many more miles on it, planning to get a brand new one soon.
    Sooo... any and all help would be greatly appreciated.
    Thanks
  2. May 9, 2016 at 12:12 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    Unfortunately its a very hard job if you don't know what your doing and you will need certain tools.
  3. May 9, 2016 at 1:03 PM
    mikesedge
    well that was helpful...
    Seabass likes this.
  4. May 9, 2016 at 1:08 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    eccracer104 and mikesedge[OP] like this.
  5. May 9, 2016 at 1:14 PM
    mikesedge
  6. May 9, 2016 at 1:26 PM
    mikesedge
    So... I think I could probably do this over a weekend... but my real problem is finding out which parts to order. I don't know specifically which actual parts are broken but it is a very good assumption that it is either the ring or pinion gears or both. SO assuming I replace those, which set does my truck take? it seems there are a few different types of differentials for Tacomas. Is it the 7.5"? 8"? V6? something else?
  7. May 9, 2016 at 8:02 PM
    04rktaco
    04rktaco Well-Known Member
    Lee
    California City, Ca.
    '04 4x4 xtra cab 4x4 TRD. 2014 Tundra crewmax TRD 4x4
    All Pro UCAs King coil-overs All Pro rear springs Modified All Pro Bumpers. Home made skids and sliders. Lefty 4.7 transfer case. Stock e locker rear stock 4:10's Tundra Brakes 285/75/16 Falcon Wildpeak AT3W stock wheels with 1.25 spacers BAMF lca skids. 2014 Tundra crewmax TRD 4x4 5.7 v-8 with leather interior. RCI Metalworks full set aluminum skidplates All Pro rock sliders
    You have the 8" elocker axle front is 7.5 reverse clamshell. Just order a complete differential from ECGS. Easy to replace. Disconnect driveshaft pull axles pull diff replace with new one then send old one back to get core charge back. Make sure to clean out the housing real good and axle tubes before installing new diff. Might want to replace axle bearings if the is any play in the old ones or they are, not smooth. I would at least replace the axle shaft seals. If you really take your time should only take a couple hours to do.
    hresendiz25 likes this.
  8. May 9, 2016 at 8:36 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    You won't know the extent of the damage until you get in there and take a look around. Then go from there. The most important part is to make sure the gears mesh properly. There is a ton information on the interwebs on how to do it. People have a fear of rearend work for some reason. Same for Automatic trannies. It's a transmission, not a rocket engine.
    mikesedge[OP] likes this.
  9. May 9, 2016 at 9:00 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Replacing the gears is the easy part. Reseting the backlash and preloads requires a few special tools and patients. Not saying its the hardest thing in the world but it can be intimidating for alot of people.
    Really if the r&p are broken and chewed up then bits of that metal has been thrown around possibly damaging the bearings so, to be safe those would need to be replaced.
  10. May 10, 2016 at 6:09 AM
    mikesedge
    Thanks for the replies everybody. I'm not too scared of doing the work, just never did it before. It'll be a learning curve for me but I have plenty of patience and a knack for mechanical stuff. Plus I have a cousin who rebuilds jeeps for rock crawling. He's done quite a few so I know he'll help me if I need it.
    Found some really helpful information as far as determining which ring and pinion to get. There is a code on the sticker in the door jamb that relates to the axle as well as the transmission. My code is B03A. If you look at this website (http://www.risingsun4x4club.org/forum2/attachment.php?attachmentid=41449&d=1429223988) you'll see that my ring and pinion is an 8" with a 4.10 ratio. That was some of the toughest information for me to figure out. Now that I have that info I can follow along on a lot of the write ups and videos. The write up from kodiakisland above was great. And I found a video on YouTube that I think was from some university on how to preload the bearings and setting the backlash. Thanks again everybody
    Ugly Betty likes this.
  11. May 10, 2016 at 7:33 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Here's a great site for gear R&R's. Not a how-to, but loaded with pictures of numerous 3rd member gear installations
    http://www.gearinstalls.com/
    If you're capable of doing brake work, etc. - then removing and reinstalling 3rd members is well within your skillset.
  12. May 10, 2016 at 7:35 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    DO NOT under any circumstance tear into this project.....
  13. May 12, 2016 at 10:20 AM
    mikesedge
    Well that's confusing...
  14. May 12, 2016 at 10:37 AM
    devinzz1
    devin
    2023 aclb trd or mt
    Think he was just talking about swapping the 3rd for another not regearing existing one.
  15. May 12, 2016 at 10:44 AM
    mikesedge
    It's just that one guy says it's a do-able project and the other guy says don't even attempt it. I was just being a little facetious. It just amazes me that some people are so short-sighted and would rather throw around their baseless opinions than to possibly try and help or offer information to support their opinion.
  16. May 12, 2016 at 11:10 AM
    mikesedge
    Hopefully I'll get started this weekend. Maybe even sooner. My plan is to at least get the third member out and see what's actually broken. At that point I might take just the 3rd member to the transmission shop to have them work on it or I might try and attempt it myself. I have learned that I need to set the preload and the backlash. I also have learned that preload is the pressure on the bearings via shims that translates into an amount of rotational resistance measured in inch-lbs at the pinion nut, which is also measured before and after the ring gear is in place. And I learned that backlash is the amount of play between the pinion and ring gears which is measured in thousandths of an inch. Luckily for me my brother and my uncle are both machinists so I know they have the right tools to measure these tolerances. Like CD20H said above, this isn't a rocket engine. No reason to fear
    I'm eventually going to try to put together a list of all the helpful information that I find along the way but for now here's some installation instructions:
    http://www.rockauto.com/info/USAStandardGear/USAStandardInstallInstructions.pdf
  17. May 12, 2016 at 11:46 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Not really, from your first post you site having lots of tools & stuff ,being mechanically inclined but not doing this before, it's not as cut & dried as you've been told, hit me back when you start trying to R&R the inner bearings or setting the gear lash & pinion preload, the Elocker is a bit tricky..
    It IS doable, if you have the knowledge & tools to do it, providing your gears are in good shape you can get a bearing kit for $200 & change...
    It'd be a piece of cake if you just changed out the 3rd...
  18. May 12, 2016 at 11:54 AM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    So, do you have an ELocker??
    Nevermind...I see that you do.
    I'd look around for a used 4.10 elocker 3rd and replace it myself. Changing out a 3rd is a piece of cake for anyone with ANY mechanical sense.
  19. May 12, 2016 at 11:56 AM
    devinzz1
    devin
    2023 aclb trd or mt
    he said he did in 1st post..
  20. May 12, 2016 at 11:57 AM
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    I edited...
