rims getting stuck to rotors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bassbasset, Nov 6, 2015.
  1. Nov 6, 2015 at 2:58 PM
    bassbasset
    bassbasset [OP] Member
    DJ
    Santa Rosa, Ca
    2010 TRD Sport
    Just paid her off, about to start the mods
    Alright,
    This seems like a dumb question, but why are my tires not coming off? I went to pull my front tires to inspect my rotors and breaks due to a bunch of shimmy and shake when coming back from fishing the other day. Put the truck on stands pulled the lugs and rims just stuck to the rotor on both sides. WTF? they are stock 2010 17" sport rims. I beat on the tires with a sledge to see if I could get them to pop and no go.
    Suggestions?
  2. Nov 6, 2015 at 3:08 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Jack the truck up in front - keep the lug nuts on but loose - drop the truck with the jack - tire breaks free - jack it up again and take it off. I take no responsibility if you F up but I've done it many times. When you are finished put some never seez on the area that was "welded"
  3. Nov 6, 2015 at 4:11 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    I have this problem and just get under the front of the truck and kick the tire from behind. One or two kicks and it always loosen.
  4. Nov 6, 2015 at 4:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Boy you are crazy!
    JimBeam and Got2ryde like this.
  5. Nov 6, 2015 at 5:05 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    it happens because of galvanic corrosion. easiest and safest way is a piece of 2x4 about 4 feet long and the jack that comes with the truck. one end of the 2x4 butts up to the inside of one rim, base of the jack against the other end and the head of the jack against the inside of the rim you are trying to get off
  6. Nov 6, 2015 at 7:18 PM
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
    Why is that?
    I'm under the front bumper not the truck. Gheesh.
  7. Nov 6, 2015 at 7:20 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I like to kick from the outside, opposite sides until it breaks loose.
    Got2ryde likes this.
  8. Nov 6, 2015 at 7:28 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Wipe a thin layer of grease on the wheel hub's inner surface where it contacts the rotor hat and wipe some in the hub-bore. Problem solved.
    Arcticelf likes this.
  9. Nov 6, 2015 at 7:33 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    On a jack stand I hope, even then the bumper can also squish you.
    To each its own...
    ecoterragaia and Arcticelf like this.
  10. Nov 6, 2015 at 7:34 PM
    Plain Jane Taco
    USA
    Just loosen the lugs some and then drive it around the block with some hard turns. Then grease as suggested above.
  11. Nov 6, 2015 at 7:44 PM
    kev6216
    kev6216 Well-Known Member
    Kevin
    Pittsburgh
    2013 Baja
    Beat it off from the inside hitting the inside of the rim with a dead blow hammer. Once you have it off, put a dab of anit-sieze on the inside of the rim where it hits the wheel when you put it back on(like 5 separate places). This will not let it get stuck together for the future. I also put a small dab on the lugs because I had the same problem with them getting welded on and broke a lug trying to get my wheel off on the side of the highway in the middle of the night with a flat tire. Some people say don't do this but get a flat on 79 in Pittsburgh in February in the middle of the night and it will change your mind....
    Justified likes this.
  12. Nov 6, 2015 at 8:00 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    It's not face of the rotor or the drum that the wheel bonds to from galvanic corrosion, it is the pilot on the front hub / rear axle within the wheel pilot hole. That is the area to apply anti-seize or grease once the wheel is removed and the surfaces cleaned. DO NOT apply anti-seize or grease to the face of the rotor hat or drum, or the flat mating surface on the wheel - doing so can contribute to broken studs and a wheel-off situation. Rotating your tires on a regular basis also helps prevent badly seized wheels.
    Jimmyh likes this.
  13. Nov 6, 2015 at 8:22 PM
    Plain Jane Taco
    USA
    The hub-bore is the area that's usually the culprit. But placing a very thin layer of grease on the inner hub surface will help as well...and won't cause any problems. Been doing it for years. A thin layer of grease with the proper lug torque won't cause any issues.
  14. Nov 6, 2015 at 9:11 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I always use Antisieze on my wheels to prevent dissimilar metal corrosion.
    gearcruncher likes this.
  15. Nov 7, 2015 at 9:10 AM
    Arcticelf
    Gladiator
    I just painted my hubs/drums with rustolium bed liner. The rotor hats were already painted.
    I also use spacers, which helps too.
  16. Nov 7, 2015 at 10:06 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Swinging the spare against the stuck tire has worked for me on SWMBO's Honda.
  17. Nov 7, 2015 at 10:30 AM
    gearcruncher
    Canadain bumper technician
    I use anti-seize as well . Although they say not to use it on lug nutt threads , I continue to use it as I always have . I figure if a tire is about to fall off , I am going to feel it in the steering wheel before it happens . I also put anti seize all around the hub . Never had to hammer a rim off since and been doing it for 30 years
  18. Nov 7, 2015 at 10:33 AM
    Arcticelf
    Gladiator
    I painted it a year ago, no issues so for.
  19. Nov 7, 2015 at 11:46 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I rotate my tires every 5,000 miles and put anti-seize on my lugs/threads and haven't had any problems with the wheels sticking. I used to always use anti-seize on the jeep between the rotors/wheels to prevent corrosion. The Jeep was more susceptible to corrosion & rust because it was exposed to more mud/water and less mileage as it sat for longer periods. But....haven't had issues with the tacoma at all.
    Use Anti-seize on wheel/rotor (metal on metal surfaces) and on the rear axle shaft/drum too!
  20. Nov 7, 2015 at 7:37 PM
    shakerhood
    Southern Ohio
    Same here, I also use just a touch on the threads and also on the taper of the lugnuts.
