Rigid Truck Bed Molding
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prl99, Mar 20, 2020.
  1. Mar 20, 2020 at 9:24 AM
    prl99
    prl99 [OP] Member
    Peter
    pacific northwest
    2013 Tacoma double-cab TRD
    I have a 2013 Tacoma double cab with the flimsy plastic bed molding. I spent a lot on a Diamondback HD cover and continue to have problems getting it to seal against moisture in the Pacific Northwest. The OEM plastic molding is not rigid so tightening the center section deforms enough to not allow a good seal. Silicone caulk doesn't work on the plastic. I'd rather replace the plastic molding with either rigid stainless steel or aluminum molding, giving me a flat surface for the gaskets to seal against. I'm not finding anything on-line.
    I have the short bed, TRD off-road configuration.
    Any ideas? Thanks
  2. Mar 20, 2020 at 9:28 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Mar 20, 2020 at 11:54 AM
    prl99
    prl99 [OP] Member
    Peter
    pacific northwest
    Thanks. These look real nice. Do you have them? If so, how is the junction between the side rail caps and the front of the bed? I added a piece of mahogany to even it out with the OEM side rails. Should this still be needed? Voodoo doesn't have anything for the front but does have a tailgate cap, which I might not need because my Diamondback cover came with a spacer for the tailgate. If you don't have this setup, I'll contact Voodoo directly and ask them about the fit.
    Thanks again for the suggestion.
  4. Mar 20, 2020 at 12:28 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I have had then for about 4 years. I currently have a Softopper and a Bed Rack on top of them and never had an issue.
    jeff b likes this.
  5. Mar 20, 2020 at 12:32 PM
    connerclan97
    connerclan97 Southern Xpeditions
    Steven
    South MS/Northeast TN
    2018 Black Tacoma TRD Off-Road 4x4 DCLB
    List of mods in build thread
    Can you tell me what the length of your rack is, from outside-outside of the tubes?
