Rigid lights switch to OEM style switch
Discussion in 'Lighting' started by Parker93, Jan 5, 2020.
  1. Jan 5, 2020 at 2:23 PM
    Parker93
    Parker93 [OP] Member
    Parker
    Utah
    I just put some ditch lights on my truck from rigid lights. They have the three wire connector to a rocker switch that illuminates when the lights are on. I’m kind of a novice when it comes to wiring and fuses and anything like that. But I just ordered a CH 4x4 switch that will go in one of the blank OEM slots. Does anyone know a simple easy way to wire the new switch? Thanks in advance for the help
  2. Jan 5, 2020 at 2:40 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Did the lights come with a relay if so should be the same as the stock switch. If not then you can install a relay with the new switch. If you don’t want to install a relay then you need to be sure the ditch lights do not exceed the rating of the new switch.
  3. Jan 5, 2020 at 8:21 PM
    Parker93
    Parker
    Utah
    Gotcha. Like I mentioned before I don’t really know much about this stuff. I’m not 100% sure what a relay is and what it does and how to add it ha ha. So any specifics on how to make it work would be much appreciated.
  4. Jan 5, 2020 at 8:26 PM
    Shellshock
    Iowa
    You connect the 3 wires from the harness to the 3 wires on your switch leads (wire 3 Red 2 is unused)
  5. Jan 5, 2020 at 8:35 PM
    Shellshock
    Iowa
    This is from the rigid instructions for my duallys.
  6. Jan 5, 2020 at 10:01 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I would wire the two red wires on the ch4x4 switch together. One is technically for your dash illumination, but if you're not comfortable with wiring, you can just wire the two red ones together and have both switch LEDs come on when the button is pressed.
    Edit:
    Yours should go
    Switch - lights
    Black - black x2
    Red X2 - red/black
    Green - red
  7. Jan 5, 2020 at 10:11 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    The CH4x4 switch is a solid-state switch that is only designed to pass a maximum of 3A. If the harness from Rigid is just for ditch lights it probably did not come with a relay. It would be easier to get a different harness than re-wire the one from Rigid (here's one example).
  8. Jan 5, 2020 at 10:15 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I would highly recommend a relay be installed along with the lights. The aftermarket switches aren’t designed to take that much current running through them.
    This.
  9. Jan 5, 2020 at 10:34 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Rewire it. If relay is put under the dash, plain relay will be fine. If relay is put in engine compartment, use a weatherproof relay.
    Relay wiring diagram. If 5 wire relay, cap 87a wire with marine heat shrink, or remove wire entirely. If 4 wire relay, this step is not needed.
  10. Jan 5, 2020 at 10:39 PM
    Shellshock
    Iowa
    All my rigid lights have come with relays :notsure:
    but yes, if there isn’t one, get one.
  11. Jan 5, 2020 at 10:44 PM
    tedusmc1345
    tedusmc1345 Well-Known Member
    ted
    2018 Tacoma Sport 4x4
    You should install a relay or inline fuse. Always you can get wiring harness from Amazon for 12.99 with remote control
