Riding dirty!!! Is there an easy fix for P0420 code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oaklandtaco, Sep 2, 2016.
  1. Sep 2, 2016 at 1:31 PM
    Oaklandtaco
    Oaklandtaco [OP] Member
    Dan
    2006 v6 4.0 prerunner
    I'm terrible at getting my tags paid on time. Paid late fees every year for the past 10 years. Late fees are the least of my problems. This year the truck wouldn't pass smog. CALIFORNIA gotta love it! P0420 pshhhhh!!!!!
    I tried crc guaranteed to pass: no luck
    I tried a gallon of laquer thinner: no luck
    Seafoam: no luck
    Fuel injection and gas cleaner: no luck
    1 bottle of cataclean: no luck
    Now P0420 and the P0430 code are thrown
    I have been driving with expired tags for 4 months and haven't been yanked yet. Knocking on wood til' my knuckles bleed!!!!
    I cannot afford to change the 4 cats on this damn truck. Dealer wants $4k. No aftermarket cats allowed in CA at least for this guy 195,000 miles and the truck runs great. Any suggestions?
  2. Sep 2, 2016 at 1:38 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    You only have 2 cats on the 4.0L. Cats are attached to the manifolds, and resonators are attached to the y pipe. I had a 430 code a few weeks ago. Changed o2 sensors, spark plugs, cleaned maf and TB, seafoam in gas, sea foam in intake all with no luck. May have helped though and eventually got me where I'm at now. Then heard about cataclean at AutoZone. $25 dollar bottle of I hope this works. It did for me. Though, it may not give the same results in every instance. Read the instructions and follow them. Pour whole bottle in 1/4 tank of gas or less, drive 15 miles, fill up tank. I did that, in high rev, two fill ups since, and all seems good. Hope that it might work for you as well if you try it.
    Oaklandtaco[OP] likes this.
  3. Sep 2, 2016 at 1:47 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Try the 02 sensors first.
  4. Sep 3, 2016 at 12:21 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do you have soot around the header to y-pipe flanges? If so, the gaskets are bad and replacing them might fix your issue if the cats aren't bad.
    With that age on the rear O2 sensors, you might need to replace them. You can test them, or just replaced them. Up to you. Could even replace one sensor at a time, and see if it clears the associated bank's code. Amazon has them at a good price. Be gentle as they can break easily internally if banged.
    When you were smog checked last time, were emissions in range, but the CEL's still on? I don't even know if they would go that far, with the light on?
    If so, an O2 simulator, or J-bung adapters, could get you by for a little bit.
  5. Sep 3, 2016 at 2:01 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Got my o2 sensors on rock auto, slightly cheaper than Amazon.
  6. Sep 4, 2016 at 10:48 AM
    Oaklandtaco
    Dan
    Tried cataclean today. Maybe should have bought 2 but I'm up to $100 on fuel addatives and I feel like I'm playing a carney game you'll never win at the state fair. Ordering the O2 spacer from eBay now.
  7. Oct 6, 2016 at 12:50 AM
    Oaklandtaco
    Dan
    Oxygen sensor spacers!!! They really work. One on each rear (downstream) sensor. Can't wait to get the truck smogged. $10 and a little wrench time. O2 sensors are a pain in the ass to remove.
  8. Oct 7, 2016 at 12:07 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Make sure to use copper antiseize on the sensors. Silicone based antiseize will damage the sensors.
  9. Nov 25, 2016 at 3:29 PM
    NitromanZZ
    NitromanZZ Member
    None
    Did you get this figured out? I have the same code problem, haven't started working on it yet, got a code reader and about to order some O2 sensors
  10. Nov 25, 2016 at 4:16 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Most auto parts stores sell them under a weird name, but they work. I've got a stack of different styles in my garage. Ended up needing some 90° adapters on my Lexus after an exhaust upgrade.
    EDIT: Spark plug non-fouler
  11. Nov 25, 2016 at 4:43 PM
    Brother Lu
    Brother Lu Member
    Lu
    Vancouver,Canada
    2009 BSP X-RUNNER
    AFE CAI,Satellite Radio,Door Speakers,18x9 American Racing Torq Thrust M Gunmetal Wheels,275-40 ZR18 Pilot Sport A/S Tires,Tundra Racing Drop,Recessed Grill,Coupe Shift Ball
  12. Aug 11, 2019 at 8:24 PM
    browncow
    browncow New Member
    2005 Toyota Tacoma TRD 4.0
    stock
    My 2005 Tacoma failed with P0420 and P0430 codes during smog check.
    I replaced my 2 down stream o2 sensors, reset the codes, drove around and Check engine light came on.
    I pour cataclean, seafoam into the gas tank, reset the codes, drove around and check engine light came on.
    I changed spark plugs, replaced air filter, reset the codes, drove around and check engine light came on.
    I removed upstream o2 sensor, sprayed seafoam in, ran the truck while smoke came out my exhaust for a while, reset the codes, drove around more and the check engine light came on.
    Finally, I added non-foulers on the down stream o2 sensors, reset the codes, drove around, no check engine light.
    Took the truck to get smogged and it passed...
    $5 non-foulers from Amazon on each of the two down stream o2 sensors.
    Link here: https://www.amazon.com/gp/product/B0002JMS6I/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
    Refer to this youtube video: https://www.youtube.com/watch?v=J1pOJ1Hn-wQ
    I've read that you must use OEM o2 sensors with this hack.
    Link to o2 sensors:
    https://www.amazon.com/gp/product/B00199FBQY/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B0016NBBQW/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
    Please note, I believe they can still fail you if they notice the hack on the visual inspection. I guess I was lucky and they must not have done a visual on my re-test.
    Good luck.
    TXpro4X4 likes this.
  13. Aug 11, 2019 at 8:34 PM
    kyledamon
    kyledamon Well-Known Member
    Colchester, VT
    2016 AC TRD OR
    Mine had 0420 and 0430 as well. Exhaust was leaking out of all of the flanges in the y-pipe. Replaced the gaskets at a shop for like $150 and no more codes.
  14. Aug 11, 2019 at 9:25 PM
    ImBillT
    ImBillT Well-Known Member
    2010 4x4 base
    Recently had it on a 2010 4-cyl. The first cat was GONE! I’d unbolt the Y-pipes and see if the cats appear intact. You also see which side the code is being thrown on. IF you have to replace a cat you could at least just replace ONE on the faulty side. I haven’t priced an OEM cat, but $4k has to include some high labor costs.
  15. Aug 12, 2019 at 6:34 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Cats are ridiculously expensive because they contain exotic metals like palladium, platinum, rhodium. In general, the OE cats have more content (more $) because they need to last 8 yrs or 80k miles.
    The spacers work as far as turning off the light, but they only fool the sensor - you will still probably fail a tailpipe sniffer if one or more cat is not functioning properly.
    b_r_o likes this.
  16. Aug 19, 2019 at 8:28 AM
    dlarpre
    dlarpre New Member
    Danny
    Reno, NV
    2012 Double Cab Tacoma Offroad
    I pulled a P0420 code (my first check engine light in 134,000 miles) about 3 weeks ago and put it off as a dirty O2 sensor as I had no negative driving impacts. About a week ago I had a very noticeable rattle that sounded like it was coming from the dash area that was more obvious with harder acceleration. I took it in and they confirmed that it was my catalytic converter that tripped the code (<30% efficiency) and that the vibration and rattle that i was experiencing was the disintegrated honeycomb of the converter being whipped around in the exhaust. I then had just about the most unnerving 100 mile drive of my life to my hometown mechanic (in CA) with highly reduced power and what sounded like a major exhaust leak. Total with labor came out to a little under $1900 and of course smog is due this month...
    b_r_o likes this.
  17. Aug 19, 2019 at 8:36 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    What did your mechanic say ended up being the issue?? Sounds like someone took you for a ride. Even if you had to replace your cats, that should be way less than 1900 bucks.
    Are you still having the p0420? Check out these o2 simulators. Gets rid of the CEL if its a bad cat causing the issue
    b_r_o likes this.
  18. Aug 19, 2019 at 8:43 AM
    dlarpre
    dlarpre New Member
    Danny
    Reno, NV
    My downstream O2 sensor was completely out of service and I had been pushing my truck pretty hard the past couple of months. I commute ~70 mi a day and have had a few 500-600 mile days up and down 395 mixed in there. The Cat efficiency is what triggered the code but they were unsure if the debris caused the O2 sensor to fail. The Cat itself was ~$1200
  19. Aug 19, 2019 at 10:04 AM
    ImBillT
    2010 4x4 base
    IIRC AutoZone had 50-state OEM quality cats already installed in the pipe between the collector and the muffler for under $700. Just four rusty bolts and two gaskets is all it would take to swap.
  20. Aug 19, 2019 at 10:08 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    02 simulator isnt going to help with the flow of exhaust out of the engine.
    The catalyst material was broken into chunks and blocking the exit of the exhaust pipe. Its rare but it does happen and it will absolutely cause a lack of power.
    BassAckwards[QUOTED] and dlarpre like this.
