Rhino "recovery" strap vs ARB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phdog, Jan 14, 2019.
  1. Jan 14, 2019 at 12:04 PM
    phdog
    phdog [OP] Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I've been trying to find a recovery strap to use when I or someone else is stuck in the snow. It's more something to have along just in case rather than something I expect to use very often.
    I've been reading about the difference between recovery and tow straps and seems the right one is a nylon recovery "snatch" strap that has some stretch to it like the ARB strap.
    So what is the poly/slik Rhino "recovery" strap for? They seem to imply it's good enough for "snatch" recovery but won't stretch as much as nylon and could also be used as a tow strap. Kind of a middle of the road strap for multiple uses. Since it's a bit cheaper and seems well made I was going to get the Rhino one, but not sure.
    Has anyone used the Rhino strap for "snatch" recovery? How did it work?
  2. Jan 14, 2019 at 12:16 PM
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    Rhino straps aren’t snatch straps. I have a 20 and 30 foot rhino that I’ve used on many occasions in the snow. It’s a tow strap. Do not use these as a snatch strap, they don’t flex. If your looking for a proper snatch strap, the ARB is the proper one of your options. I have the Rhino and the ARB and think they are both good for different applications. You also don’t want to tow with the snatch strap, or get it wet.
    xXDeadfishXx and Azza like this.
  3. Jan 14, 2019 at 12:27 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    What happens if it gets wet?
  4. Jan 14, 2019 at 12:33 PM
    Pella
    Pella
    209
    SSMDCSBORFTMFW
    It reduces the effectiveness of the stretch. I remember reading it on the instruction card the ARB snatch strap came with.
    doublethebass[QUOTED] likes this.
  5. Jan 14, 2019 at 12:33 PM
    Oscar I
    Oscar I No longer a toyota driver
    Yanking you want a snatch strap or uses kinetic energy to assist with pull.
    For general use ie tow strap. Pulling and securing to a tree or running snatch block you need a stay that does not stretch.
    Get a 3in wide 30k lb rated.
    I have ARB snatch and tow and Teraflex tow. The tera tow gets used the most.
    Slashaar likes this.
  6. Jan 14, 2019 at 12:50 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    If you’re looking for a kinetic recovery rope, I would recommend something from Treaty Oak Offroad
  7. Jan 14, 2019 at 12:51 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Good to know. Thanks
    Pella[QUOTED] likes this.
  8. Jan 14, 2019 at 12:52 PM
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    get a bubba rope.... :crapstorm:
    Mully, BrianPVan and Paul631 like this.
  9. Jan 14, 2019 at 2:03 PM
    mcdean
    mcdean Well-Known Member
    San Jose, CA
    2016 DCLB TRDOR 4x4 A/T
    LED int lights, Morimoto HID lows, Philips LED fogs
    Would second the Bubba Rope. It's a bit pricier then some of the options out there, but they work well.
    Toywoodsguy82[QUOTED] likes this.
  10. Jan 14, 2019 at 2:23 PM
    Oscar I
  11. Jan 14, 2019 at 3:51 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
  12. Jan 14, 2019 at 3:54 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    That's more or less my question. Rhino implies it is just with less stretch than 100% nylon. So for purely pulling out of snow ocassionally is it "enough" stretch or totally inadequate for anything other than towing an unstuck vehicle to a gas station?
    dmurph1996 likes this.
  13. Jan 14, 2019 at 6:07 PM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
  14. Jan 14, 2019 at 6:34 PM
    Tacoma2020
    Tacoma2020 Well-Known Member
  15. Jan 14, 2019 at 7:02 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    LOL, that's actually the article I read that caused my confusion. They quoted Rhino as saying:
    "Our poly silk webbing is an 80% polyester and 20% silk blend so it is closer to a polyester strap, but has more softness and flexibility, however, it does not stretch to the same degree as a nylon snatch strap. I hope this answers your question, contact me directly if you need anything! Thank you! – Cameron Repic, Rhino USA, Inc."
    That didn't answer my question. It "does not stretch to the same degree as a nylon snatch strap." Okay, so how much does it stretch and can it be used similar to a nylon snatch strap? I think I read a nylon strap stretches about 10% of it's length and poly about 2%. So is this in the 5% range or something or no different from poly.
  16. Jan 14, 2019 at 7:09 PM
    Tacoma2020
    The Rhino strap is a good starter strap. It’s better than nothing. For someone like me that doesn’t offroad as a weekend hobby, it’s fine to have in case a strap is needed. Relatively low cost and handy if needed.
    If you are going offroad frequently, it would be smart to invest in the proper equipment.
  17. Jan 14, 2019 at 7:19 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    I have Rhinos at work and have snatched forklifts with them. Haven’t had any issues and they have a lifetime guarantee no questions asked
    jmneill and Tacoma2020 like this.
  18. Jan 15, 2019 at 2:40 AM
    Oscar I
    That just means its softer and more pliable. Nice for handling. Sucks when everything gets stuck in it. The ARB are like that and cockelbures and other flora sticks to it alot.
    In those environments I much prefer the teraflex fully nylon. The blend will roll up and still be pliable like you can make an egg shape to fit some bags better. The full nylon will not. Its round and like a brick.
    To do it right you really need both kinds of strap. A kinetic and tow. I've been teaching recovery techniques for several years now and there is no such thing as to much equipment. I've used 5 snatch blocks and 3 winches to save a vehicle that slid off a trail from further damage.
    One thing to seriously consider is where are you attaching this strap. Do not hook it over a ball. If you dont have a good rear recovery point the best place is the receiver hitch with the strap pushed in then a pin thru the loop. Double sheer on the hitch pin is substantially stronger than the ball.
    Warning.
    If you use a tow strap and yank on the ball you have a high chance of that ball snapping off and heading directly at the other vehicle. Shock load is different than working load.
    I highly suggest finding and I4WDA (international 4 wheel drive assoc) recovery training program. Deffinately worth the time.
    BigJanko, BRFab, Hiker trash and 4 others like this.
  19. Jan 15, 2019 at 10:31 AM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Thanks. I picked up a bow shackle for the hitch to use as a recovery point. The Rhino strap is about $45 and the ARB about $65. The ARB is rated lower - 17,000 lbs vs 31,000 for the Rhino. The ARB is nylon snatch strap though.
    I'm not a hard core off roader so just looking for something keep with me in case I get stuck and need a hand or lend one to someone else. I did pick up a "recovery" strap from Auto Zone when I first got the truck but I think one is just a tow strap. It might work with gentle pulling, but thought I should get something more appropriate for recovery.
  20. Jan 15, 2019 at 1:10 PM
    Oscar I
    Two biggest things. NO hooks in the strap. Double your weight minimum.
