Reviews of this Hypertough Impact drill
Discussion in 'Sports, Hobbies & Interests' started by Newtacoma19, Apr 25, 2025 at 5:39 PM.
  1. Apr 25, 2025 at 5:39 PM
    Newtacoma19
    Newtacoma19 [OP] Well-Known Member
    SSM utility 19
    Evening,
    looking to get my first impact Drill… For how much I’ll probably actually use it.: don’t want to spend a lot.. just would like one to keep wotI the battery charged in my truck.. for out and about and on road-trips. anyone have experience with this one? Hyper tough 20v max.. 1/2 inch.. with one battery and charger. $59.00 If no good.. what is one someone would recommend hopefully under $100.00 with battery and charger.. if those are even in fact of quality.
    https://www.walmart.com/ip/Hyper-To...-and-Charger-350-ft-lbs-Torque-New/5589753969
  2. Apr 25, 2025 at 9:00 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Torque test channel on YouTube gives them extremely high praise fir the cost. As a throwaway/spare or if you're not committed to any battery platform, there's no reason not to.
    https://youtu.be/qBNplsklWvY?si=4iKA32GZ1HFjAQs1
  3. Apr 25, 2025 at 9:15 PM
    MGMDesertTaco
    83ft lbs isn't very much. OP could probably get away with any brand of stubby impact wrench in 3/8 or 1/2 drive.
  4. Apr 26, 2025 at 5:12 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    So a coworker of mine had a real low tire, and pulled out his "battery operated" air pump. And guess what? His Battery didn't have much juice it it, when he needed it the most. He was stranded.
    Unless you constantly use battery operated tools, (like on the job), you would also have a 2nd one charging when needed.
    Plugin is the way to go...
  5. Apr 27, 2025 at 12:10 PM
    Newtacoma19
    SSM utility 19
    Lookin at getting torque wrench.. Would this be the best recommendation for an entry level torque wrench … Is this the Torque wrench I should get for my tacoma lugs 83 psi and a 04 Jeep Wrangler? Given the lifetime warranty as well.
  6. Apr 27, 2025 at 12:15 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    I have the Icon version of this one. Mine works great for me over the last 5ish years.
