Reverse wire- kick panel for back up camera
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rolan74, Aug 26, 2018.
  1. Aug 26, 2018 at 4:57 AM
    Rolan74
    Rolan74 [OP] New Member
    2004 Tacoma 2004 dbl cab
    I’m installing and aftermarket Boss audio unit with back up camera (2004 Tacoma). Which wire is the reverse light under my kick panel? I need to hook up a purple wire from the unit with the reverse lights, so the camera will come up when I put the reverse. Photo or diagram will be appreciated..
  2. Aug 26, 2018 at 5:53 AM
    lalojamesliz
    lalojamesliz Well-Known Member
    Ed
    02 dbl cab V6 pre-runner trd
    Tundra brake upgrade (in progress)
    :popcorn:
    This would be nice to know
  3. Aug 26, 2018 at 7:20 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    BN7 connector under the driver seat pin 22. It's a Red-Black wire. You should be able to follow it forward to the kick panel but I'm not sure if it's actually in a connector there.
  4. Aug 26, 2018 at 7:52 AM
    Rolan74
    I would like to know which is the cable behind the kick panel; is hard to follow it from under the seat to the kick panel.
  5. Aug 26, 2018 at 9:01 AM
    nzbrock
    Noah
    San Marcos, TX
    Well you just need to find the R-B wire that goes toward the back of the vehicle.
  6. Aug 26, 2018 at 2:42 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I used a different wire coming out of the integration module to activate my reverse camera trigger.
    It’s behind the lock panel, directly under the plugs for the power doors.
    Don’t recall the color however.
  7. Aug 26, 2018 at 2:50 PM
    nzbrock
    Noah
    San Marcos, TX
    I have attached the back up light wiring diagram for a 2003 tacoma, it should be very similar to a 2004.
    As far as I can tell the back up light circuit does not go through the integration relay. Also, the wire is the same color on my 99, so I doubt anything has changed over the years. Prior to 01 the connector under the driver seat is referred to BN1 and has a few different wires running though it.
  8. Aug 26, 2018 at 3:16 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    I just ran it from the rear taillight and loomed it together with the bckup camera wiring. Had a wireless unit before, but I'd get feeds from baby monitors and CC security cam footage. Probably because they had a better signal?
    BartMaster1234 likes this.
  9. Aug 26, 2018 at 3:17 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I did this about two years ago, but I do recall it going through the integration module. In my picture I spliced to the reverse light power wire that turns on in Reverse. You’re right about it going under the seat, but I spliced the line behind the kick panel.
    See: Solid Yellow Wire with Yellow Splice and two row terminal block, don’t recall original OEM wire color, but it’s red. Lower left hand corner.
    btu44 and Mipajo923 like this.
  10. Aug 26, 2018 at 3:21 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Random aside: I used to work in a theatre and it had obscure 1980’s era Shure wireless microphone transmitters that were disconnected in the early 2000’s. One day our replacement microphone transmitter system went down, so we re-connected the Shure system. It didn’t work either for some reason and that’s the last we heard of it until much later.
    About a year later I was talking to the Master Electrician. Apparently the frequencies the old Shure unit put out were re-assigned from voice transmission to government entity use some time in the mid-2000’s. For apparently, Missile guidance systems.
    Don’t know if it’s true but it’s an interesting story nonetheless.
  11. Aug 26, 2018 at 3:29 PM
    License2Ill
    Ian
    Yikes
  12. Oct 2, 2020 at 9:35 PM
    Cutter_
    Cutter_ I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    I am in the process of doing the same thing. That red wire is the reverse trigger wire?
  13. Oct 2, 2020 at 9:36 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yes, but it may be different for your year. The wire colors varied year to year, model to model.
    Cutter_[QUOTED] likes this.
  14. Oct 2, 2020 at 9:38 PM
    Cutter_
    Do you know any way I can find which is the correct wire? There are SO many coming from under the seat and up to all those harnesses/connections
  15. Oct 2, 2020 at 9:52 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You’d need a factory service manual. I have the paper one for my 1998 but it’ll be different from a 2002.
  16. Oct 2, 2020 at 9:53 PM
    Cutter_
  17. Oct 3, 2020 at 1:56 PM
    Cutter_
    You were right, it was the only red and black wire in the bundle of wires that runs under the seat
  18. Jan 17, 2021 at 1:30 PM
    craigqwerty
    craigqwerty New Member
    Craig
    2000 tundra
    Guys the Reverse wire according to the diagram is BLACK WITH A RED STRIPE, (according to the diagram listed below) not the other way around. I've been looking for this for a few days now for my 2000Tundra. I tapped the Red with Black stripe, and it DOES NOT WORK.
    It's the wiring harness going under the driver's seat, but it's the BLACK WITH RED STRIPE. a number of forums are saying it is the other way around, but that is not the case at least for a 99-04,(as best I can guess the year spread).
