Reverse gear sucks. What to do?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spanker67, Aug 31, 2017.
  1. Aug 31, 2017 at 12:48 PM
    Spanker67
    Spanker67 [OP] New Member
    2017 Tacoma TRD Sport Access Cab Manual
    Having a touch of buyers remorse. My 2017 Access cab, TRD sport, 6MT, can barely back up a modestly steep driveway much less back my boat up it into the garage.
    My boat and trailer weigh ~5000 lbs. The dinky reverse gear doesn't have enough grunt to back this load up a 1 % grade without lots of RPM's and clutch smoke. Is there a gear fix I could do?
    Although the engine and tranny are ok around town, I feel like Toyota didn't get it right on towing ability. This truck would struggle to pull buttered string out of a pigs ass. Would the auto have been a better choice? I really need a granny gear for first. Reverse feels like 2nd gear ratio. Manual says this truck should pull 6500 lbs. Help.
  2. Aug 31, 2017 at 12:50 PM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    The reverse ratio was a huge fail by Toyota. I bet you could do 35mph easily in reverse. When I am just backing up the truck, I can't even let the clutch out fully. Only work around it to pop it in 4 low, but that doesn't work when turning on dry pavement.
  3. Aug 31, 2017 at 1:05 PM
    Cold_Toad
    Cold_Toad Well-Known Member
    Yeah they really missed the ball on the gearing for reverse, no idea what they were thinking there.
    I do find it interesting that you don't think first gear is low enough for starting out, or maybe I'm miss interpreting what you are saying. I've never felt that first wasn't geared low enough, if anything I feel that the ratio between first and second is two large. But I've also never tried towing anything actually heavy before.
  4. Aug 31, 2017 at 1:06 PM
    brentw59
    brentw59 Well-Known Member
    Brent
    Clovis CA
    2017 Tacoma 4x4 DCSB Manual Inferno
    Basic Shit. Floor Mats, Seat Covers
    Thats the only reason I would consider going to 4.88 gears on my MT reverse is complete crap. I only plan on running 285's at the most so I dont really need the 4.88 but I plan on getting a boat and the backing up is a big problem.
    Joe23 likes this.
  5. Aug 31, 2017 at 1:17 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Reverse does suck being unloaded. I can't imagine what it's like backing up a loaded trailer. I try not to slip it the whole time, I will give it some clutch in short bursts. What you can do is line your truck up and put it into 4lo and backup as straight as possible. Then just switch back to 2hi.
    BearB likes this.
  6. Aug 31, 2017 at 1:19 PM
    specter208
    California
    Would be nice if we could mod in 2lo like on the 2nd gens. And no, other than reverse, the 6MT is much nicer transmission than the auto.
    Kilokato likes this.
  7. Aug 31, 2017 at 2:26 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Toyota missed the mark on the gear ratios in both man trans and auto. They also missed the mark on the auto transmission itself and the 3.5L motor. The JBL audio is nice though.:thumbsup:
  8. Aug 31, 2017 at 2:36 PM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    It's really just reverse, and I wish maybe 1st wasn't as short - but that's helpful the 1 time a year I tow something. Everything else about the MT gearing is great!
    I use @specter208 's method of short bursts of clutch rather than slipping the whole time.
    OA
    MCDavis likes this.
  9. Aug 31, 2017 at 4:30 PM
    thdrduck
    thdrduck Well-Known Member
    When asked by Toyota if I had any complaints... it was this one. 4 low would be very useful if there was a way to keep the front diff from locking. Folks with 2wd are just screwed as far as backing a trailer goes.
  10. Aug 31, 2017 at 4:35 PM
    Spanker67
    The spread between 1st and 2nd is too much but I can live with that, the reverse gear is a complete joke. Reverse should be a granny gear or a ratio equivalent to 1st. However, it's more like 2nd. I took 3 years off the clutch plate in 5 minutes backing that boat up driveway. Can reverse gear be swapped for better ratio?
    MooseSD, ssmith0480 and Boxerocks like this.
  11. Aug 31, 2017 at 4:41 PM
    schmack b
    schmack b Well-Known Member
    Clarksdale, Mississippi
    2016 DCSB TRD OR M/T
    Yes. I hate reversing with a trailer in this truck. U either have to smoke the clutch or ride the brakes and be on the verge of stalling. Way to high.
  12. Aug 31, 2017 at 4:52 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    2nd gen 6 MT here, but my solution has been to let the clutch all the way out then control speed with just the brakes instead of smoking the clutch. Not always possible but it really helps. With the variable timing or whatever they call the electronic system the truck is hard to stall even when revs are way under where they should be. "Back in the day" when I learned to drive the reverse gears were generally the same, or very close, ratio to first gear. But you couldn't lug the motors because they would ping (detonate) damaging the motor and stall out. My Tacoma just grunts along revving way below where it should. If that's still too fast there really isn't much of a risk with dropping into 4H or even 4Lo for a minute or two. Just don't spend the day in 4Lo and everything should be just fine.
    Casper66 and OpelGT like this.
  13. Aug 31, 2017 at 5:06 PM
    Omar RVA
    Omar
    OR
    Maybe it's just me or maybe it's the third generation, but if I let my clutch out all the way, I'd be doing like 15mph in reverse (exaggerating). Any slower and it'll stall/bog.
    OA
    Spanker67[OP] and specter208 like this.
  14. Aug 31, 2017 at 5:17 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Could be. At times I'm sure the truck will stall but it just sputters along. Worth a try. Or just go 4H or 4Lo.
  15. Aug 31, 2017 at 5:57 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Can you retrofit locking hubs on these trucks? If someone came up with a clean-looking locking hub kit, that would solve a lot of the "wish I could do 4lo things without being in 4X4lo" type issues.
    Might add a few MPG too.
    Shellshock and Spanker67[OP] like this.
  16. Aug 31, 2017 at 6:02 PM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    You don’t really gain much, you already have an ADD so it disconnects the front drive axles when you are not in 4WD.
    I do wish we could do the “gray wire mod” on our trucks though...that would be great. Mostly for the 2HI locker.
    Stocklocker[QUOTED] likes this.
  17. Aug 31, 2017 at 6:03 PM
    bradshawnh
    Boston, MA
    Also have a 6MT, reverse is definitely geared high, but never really bothered me. But also never backed a heavy trailer up a hill so...
    If it’s that bad or common for you to do this, maybe a front hitch or something? We use a front hitch to reverse hay wagons...
    Spanker67[QUOTED][OP] and hiPSI like this.
  18. Aug 31, 2017 at 6:18 PM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    I just use 4low when backing my trailers.
    Haven't had issues with binding the drivetrain even on pavement doing this. I do however realize that binding can happen. I purposely clutch and unload the drivetrain to make steering corrections to avoid this.
  19. Aug 31, 2017 at 6:45 PM
    Jeff1795
    Jeff1795 Well-Known Member
    Panama City FL
    LT 2017 TRD Sport 4x4 Access Cab 6-Speed
    I feel like tow mater in reverse. There is no slow speed. And as far as a boat goes I think marina fees will be cheaper than replacing the clutch that often.
    chrisrocks300 and tcjacado like this.
  20. Aug 31, 2017 at 6:46 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Took me one time of backing up a trailer to put it in 4lo. No big deal as I've had to do this in other trucks too. I didn't even think twice about it. Anyone who has been off road in the rocks knows a little bit of 4lo on pavement won't hurt anything.
    Kilokato and RedBeard1 like this.
