Reverse Camera Anytime Mod SOLD OUT
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by brendanwebster911, Jan 8, 2017.
Thread Status:
Not open for further replies.
  1. Jan 8, 2017 at 6:44 AM
    brendanwebster911
    brendanwebster911 [OP] Well-Known Member
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Hey there TW! Just as the title says! Reverse Camera Anytime! They work great and are very easy to install. I personally will be using mine ALL the time. I tow quite frequently and would love a way to check trailer connections while driving. Your specific use may vary.
    This kit "tricks" the Head unit and backup camera into thinking the vehicle is in reverse at anytime you flip the switch. It can be activated ANYTIME or even all the time. This kit is especially awesome because it has the ability to activate the reverse camera without triggering the reverse lights. The reverse camera and lights still work as normal while shifting the vehicle to Reverse.
    https://youtu.be/Du322YnjFZA
    Free shipping is included on all kits. Its about a 30-60 min install and you can mount the switch anywhere you would like. (may require extending wires in certain circumstances) All you need is the ability to follow instructions, cut, strip, and splice some wires and you're all set! This kit includes all required equipment prewired, soldered, and shrink wrapped with the diode in the harness. This is not a "plug" and play kit. You WILL need to cut one wire, and splice into a couple more.
    $20 Basic kit Includes
    -Step by step installation guide and wiring diagram
    -1x Illuminated 3/4" round toggle switch. Round switches will mount in any 3/4" hole. 12" pre soldered and shrink-wrapped leads. Leads are long enough to mount switch above radio. Available in RED, AMBER, BLUE, and GREEN.
    If longer leads are needed please specify.
    -1x Inline "Y" harness with pre soldered and shrink-wrapped diode
    -1x Wiring diagram and step by step full color installation instructions.
    CLICK HERE TO ORDER BASIC KIT Ensure to leave shipping address and color choice in notes.
    $50 OEM STYLE Kit includes:
    The basic kit with a substituted "rear camera" push button OEM illuminated style switch. All switches are black with white lettering. Illumination is available in WHITE, BLUE, RED, and GREEN. White illumination is standard. The switch is pre wired, soldered, and shrink-wrapped 5' long lead wires. Long enough to reach the cubbyhole on the left side of the steering wheel. This switch will fit inside the "blank" spots. No trimming required to fit. SPECIFY WHERE YOU ARE MOUNTING THIS SWITCH, CENTER STACK AREA OR CUBBYHOLE AREA ON DRIVERS LEFT. There are two sizes/shapes of the OEM Style Switches.
    Screen Shot 2017-01-10 at 6.21.27 PM.jpg IMG_2612.jpg IMG_1891.jpg IMG_1957.jpg
    CLICK HERE TO ORDER OEM STYLE KIT Ensure to leave shipping address and color choice in notes.
    $5 NAV IN MOTION OVVERIDE TOGGLE W/LEADS
    -Can be added to any order. This includes 1x 3/4' toggle switch. With 12" pre soldered and shrink-wrapped leads. Leads are long enough to mount switch above radio. Available in RED, AMBER, BLUE, and GREEN. If longer leads are needed please specify. Note: Due to the nature of this specific switch, illumination will pulse while the switch is activated due to the
    signals from the SSW wire. Illumination of the switch is not recommended. Instructions and wiring diagram included.
    Each harness and switch is tested for function before shipping. A detailed installation writeup is included.
    PayPal: BRENDANWEBSTER911@GMAIL.COM
  2. Jan 8, 2017 at 7:39 AM
    maviolli
    maviolli Well-Known Member
    Houston
    2012 DCSB 4x4
    Will this work with the unupgraded radio unit?
  3. Jan 8, 2017 at 7:41 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Yes. The wire location and colors may differ though
  4. Jan 8, 2017 at 2:20 PM
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    Thanks Brendan!
    brendanwebster911[OP] likes this.
  5. Jan 8, 2017 at 3:12 PM
    TacoSharky
    TacoSharky Well-Known Member
    Socal
    Thanks Brendan! Can't wait
  6. Jan 8, 2017 at 4:25 PM
    ChaseUA
    ChaseUA Well-Known Member
    Chase
    Bama
    Present: 2016 White TRD Sport DC Past: 2010 MGM TRD Sport AC 4x4
    Brendan - possibly interested but I have two questions. Can you post a close up photo of the switch installed? Also, is the blue switch close to the OEM look of the blue backlit buttons? Thanks in advance.
  7. Jan 8, 2017 at 4:34 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    I attached two pictures.
    One of a "lit" switch to show the color. The switch is a bit brighter than the surrounding blue colors. But, it's the same blue color.
    The second pic is the mounting location I chose. You can mount the switch ANYWHERE you want, Even the tailgate, you'll just need to extend the wire If you choose to mount it more than 12" away from the head unit. I did not choose to light the switch due to possible glare issues on my windshield due to where I mounted the switch. My instructions include directions to light your switch, or keep it unlit if you choose.
    69TACO16 likes this.
  8. Jan 8, 2017 at 4:36 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    @ChaseUA
  9. Jan 8, 2017 at 4:43 PM
    DoooDahMan
    DoooDahMan Active Member
    WS/NC
    2017 BBP DCSB Tacoma TRD OR
    how to buy?
  10. Jan 8, 2017 at 4:48 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Shoot me a PM and i will provide My PayPal info!
  11. Jan 8, 2017 at 7:03 PM
    maviolli
    Houston
    2012 DCSB 4x4
    Thanks Brendan!
  12. Jan 9, 2017 at 7:35 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    This doesn't affect the standard operation of it automatically coming on when shifting into reverse, right?
  13. Jan 9, 2017 at 7:44 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Nope.
    With the switch in the "off" position everything works 100% like normal reverse lights and all.
    In the "on" position the camera will engage at anytime. No reverse lights will illuminate.
  14. Jan 9, 2017 at 7:46 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    Awesome, sign me up. $20 is the price, correct?
  15. Jan 9, 2017 at 7:52 AM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Yes sir. $20. All you have to do is splice her in then mount your switch where you want and you're set. All instructions and wiring diagram is included.
  16. Jan 9, 2017 at 7:55 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    Money sent (correctly, I hope, let me know if not).
  17. Jan 9, 2017 at 4:48 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Les go, Crazies! I have plenty more kits left to ship!
    mcwalke2 likes this.
  18. Jan 9, 2017 at 7:55 PM
    jluu44
    jluu44 Well-Known Member
    Jon
    North County San Diego, CA
    2016 Tacoma DCSB 4x4 off-road
    Can I wire it to work with a more OEM-like switch?
  19. Jan 9, 2017 at 8:29 PM
    kamil
    kamil Well-Known Member
    Kamil
    Los Angeles
    2016 Access Cab SR 4x4 Manual
    THIS IS NOT NORMAL bumper sticker
    Will this work with manual transmission? thanks
    Calvin2727 likes this.
  20. Jan 9, 2017 at 10:38 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Yes, it will!
Thread Status:
